20 Most Recent
Logitech Harmony 1000 LCD Touchscreen Remote Control Questions & Answers
No softwere dvd setup
Hi. You can download the software to set up your remote for free at http://logitech.com/myharmony.
Regards,
D
When i callobrate the touch
Hi. This sounds like an error in the remote's Operating System. Try connecting it to your computer and updating the firmware. To do this, click "Downloads" in the Harmony software application and then click "Firmware." This will update the firmware (operating system) of your remote, and solve any software issues.
Regards,
D
My logitech harmony 1000 doesn't
When was the last time u replaced the litium battery?If 2 years or more the litium battery has not been change.Yes,it is the litium battery issue.
Mu harmony 1000 doesnt respond
Try pressing the reset button, or holding the power button until it turns off. If that doesn't work take out the batteries and wait then put them back in.
Battery will not charge. One of the contact in
thanks for your additional information. This really helped to detect quickly where the fault was coming from.
Its very obvious that the fault is from the battery of the unit. The battery cell is weak such that it cannot be revived by charging.
To solve the problem, I would suggest that you look forward to getting a brand new battery. Once this is done, the unit will charge the new battery without any problem.
The battery presently in the unit is bad and it cannot hold charge. So do a battery replacement and problem would be solved.
Good luck.
Harmony 1000 will not keep
Use a multimeter to chack the charging cradle. volts must be within half volt from specifications.
If the newly tested battery charges in full , then the battery is not the problem. More likely the battery draining problem is due to a contact ccausing a parasitic drain inside the unit.
Screen went out now remote does not, come on,
HI! Here's what to do if your Logitech Harmony remote's LCD screen has gone blank.
1. Remove the battery, press and hold the 'OFF' button, and re-insert the battery. The screen will display 'Safe Mode!', or the 'Activities' button will be lit.
2. Connect your remote to the computer.
3. Launch the Harmony Remote Software, and log in.
4. Click "Downloads" at the top and click "Firmware".
5. The remote will go through the firmware update.
6. Select "Yes", and click NEXT to update the remote.
If the screen is still blank after you complete these steps, then it is a hardware issue and you should contact Logitech's wonderful support team, given that the remote is still under warranty.
Updates
http://www.audioholics.com/reviews/remote-controls/logitech-harmony-1100-rf
http://www.logitech.com/en-us/remotes/
also if u can hook it up to the comp while online it might do a auto update not sure just an idea
