20 Most Recent
Nokia 1110 Cellular Phone Questions & Answers
Sir how to the PUK
With that issue, you need to contact TM's Customer Service, they sure have the copy of you PUK code. Just make sure to have physical SIM card itself. They might ask for the ICCID, thats the 16-digit code printed on the back of your SIM card.
Cheers!
I forgot my security code for my nokia
Hi if you forget the security code of your Nokia 1110 phone then try to reset your phone using default code like 0000 or 1234 to reset it .If this code didn't help to reset your phone then visit sites like
Unlocking4Free.com here they are generating master reset code for your mobile models at free of cost .After resetting your mobile you can assign new security code for your phone ....
I forget my nokia1110i security
Hi, i have checked your phone has not been reported lost or stolen so i can provide you with the phones master code but you need to know the following.
1 if you have entered the wrong code more than 5 times then the phone is hardlocked and no code will unlock it.
2 depending on the phones firmware will depend on wether the code will work or not.
you can try the master code for your phone but if this master code dont work it means your phone is hard locked and can only be unlocked using leads and software and you will be very lucky to find someone who does this as its now illegal to do this.
here is your phones master unlock code, enter this when asked when you switch the phone on ok
4202230746
plz rate this solution
How to unlock puk code for nokia 1110
Hi your only option is to call your phone service provider. No it doesn't come with the phone and the phone never has its own puk code because the puk code is about the sim card.
if you put in another sim card the phone will work just fine, its the sim card 3 times pin code wrong puk code enabled pin blocked, call service provider to get it and entry instructions.
Let me know if you need anything else.
Thanks,
Ekse
Reset security code 1110i my serial is
If you receive a code without the #pw+ at the beginning or EG +1# at the end, then you need to add this to the code before you enter it.
For example, if you receive 418636523456123, then the code is actually #pw+418636523456123+1# (Should normally be +1# on the end).Please note: You only have 3 attempts to enter this unlocking code.
MY SIM HAS BEEN BLOCKED, ASKING PUK CODE.
Just call your provider and tell them you need a PUK code, they will be more than happy to give it to you.
you may also get it from the company website or go into the provider store.
this is something they do all the time
Please unlock my mobile security code
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
type *#06# on your phone to get it.
Imei 356958016965575 how can i send a message if the phone is blocking me to send?
You always should be able to send messages to anyone. If someone does not want to receive the messages, he / she can block your number and won't see the messages you are sending. You can't change that. Some things are made for protection. Blocking an incoming message or call, would be worthless, if there was a way around the system.
When you can't send any message, contact your provider (you did not mention that detail) and ask what is wrong, why you can't send messages.
We can't see this and to my knowledge here are no volunteers with clairvoyance.
How to reset nokia 1110 imei:357947006847561
If your Nokia says 1110 invalid SIM, It must be your problem with SIM card. Try switching on your mobile with any other active SIM. If the problem still persists, You can do a master reset to your mobile. You can get the master reset code for Nokia 1110 from
www.Superunlockcodes.com this site provides accurate codes at low cost. all the best mate.
