20 Most Recent
Whirlpool GS5SHGXLS Side by Side Refrigerator Questions & Answers
Cleaning pan under freezer
see if it can be pulled up then out in the front. if not, then you will just have to settle with putting the dry rug inside and then let it sip the dirty liquid on the pan and you can pour water and detergent inside the pan in order to wash it then rinse it after wards.
tnx 4 using fixya,
drcool
9/29/2008 4:44:10 AM •
Whirlpool...
Answered
on Sep 29, 2008
Ice maker not getting water
PULL THE TUBE BEHIND THE ICEMAKER OUT AND SEE INSIDE IF IT IS FROZEN,IF NOT ALL THAT'S WRONG IS THE WATER INLET VALVE ON LOWER BACK OF FRIG.IS BAD,YOU HAVE A WATER DISPENSER HOSE ON ONE SIDE AND A ICEMAKER HOSE ON THE OTHER,THE ICE MAKER SIDE OF THE VALVE IS BAD,THANKS-MIKE
5/29/2008 9:46:31 PM •
Whirlpool...
Answered
on May 29, 2008
Ice Maker
Yes it could be... The valve is blue in color and located behind the appliance at bottom. It should have two water lines going to it. One from the wall and one from the ice maker. Also check the fill tube that feeds the ice maker to make sure its not frozen up. to check it you "could" unplug the power wires going to it and wire it into another source of power, but I would say just replace it.
12/17/2007 10:09:43 PM •
Whirlpool...
Answered
on Dec 17, 2007
I have a whirlpool WRF40 IX all refrigerator. The ...
WHIRLPOOL WRF40 Solution to this problem!!! very easy ----I assume you have a problem with the control board switching on and of erratic when you pass setting 3 on the LED display, the designers of this fridge left the calculator at home that day, ask a technician to replace the Resistors 5, 6 & 7 (330 OHM 1/4 watt) on your electronic control board with 680 OHM 1/4 watt. This would solve the problems with this board, the LEDs will not be as bright as they were but still highly visible. Questions?
[email protected]
10/7/2023 6:12:17 AM •
Whirlpool...
Answered
on Oct 07, 2023
Whirlpool refrigerator is not getting cold but freezer is freezing. Can someone help, please?
As the freezer is working you can probably discount that the reason is low refrigerant gas. The other reasons would be that the fridge circulation fan has failed.
or
The channel that directs cold air from the freezer is blocked with ice at the rear of the freezer. It happened to my GE and was caused by a failed defrost timer that was icing up the evaporator coils at the back of the freezer.
A service call lasts about an hour including melting the ice with a heat gun..
10/3/2023 2:45:18 AM •
Whirlpool...
Answered
on Oct 03, 2023
