20 Most Recent Cisco ASA 5500 Firewall Questions & Answers
http://www.cisco.com/en/US/support/tsd_cisco_worldwide_contacts.html
From the US, you can call: 1.800.553.2447
From there, Cisco will be able to tell you what your warranty status is by the device's serial number, and can also provide you with a quote if your warranty has expired.
Cisco ASA 5500... | Answered on Nov 12, 2015
Yes, it is possible and Yes you have to purchase it from Cisco.
Sorry, that is how they make the big bucks.
Consider a service contract on the unit, then you can download the firmware much cheaper.
Cisco ASA 5500... | Answered on Aug 25, 2014
Easiest way to is so issue the following command on the cli:
more system:/run
This will get any preshared keys you have in the config.
Cisco ASA 5500... | Answered on Mar 01, 2011
if it is really deleted from FLASH, you will need to connect to ASA with a console cable, start up TFTP server on your pc, and in TFTP copy your ASA image file (.bin - on your CD that you got with ASA) so that you can get it from pc to asa.
then use tftpdnld command to set all the parameters on asa and start the download of the file from your pc .... after it has been done - just reboot asa :)
Cisco ASA 5500... | Answered on Jan 10, 2011
You can do this, For your ref i hv given you a link
http://channel9.msdn.com/forums/9GuyAroundTheWorld/251722-Cisco-Pix-to-Windows-Vista-Native-Client-Using-L2TP-IPSec/
Cisco ASA 5500... | Answered on Mar 19, 2009
Use a web browser and point it to the private IP address of the ASA. Download ASDM and run through the wizards.
Good Luck!
Cisco ASA 5500... | Answered on Feb 01, 2009
It is not possible to block the BitTorrent protocol, as the client applications have the ability to use different port numbers.  I suggest one of the following courses of actions:
1)  Added deny entries to your outbound access-list that block the specific IP addresses of the torrent trackers.  For example: tracker.thepiratebay.org = 77.247.176.145
tv.tracker.thepiratebay.org = 77.247.176.154
tracker.mininova.org = 87.233.147.137
2)  Re-configure your outbound access-lists to allow only services required for business activities.  For example, allow only http, https, and ftp, instant messaging from all your network.  Allow only dns from your DNS servers.  Allow only smtp from your mail server.
Cisco ASA 5500... | Answered on Sep 28, 2008
hello ,
try this http://www.ecommercetimes.com/story/21764.html
it will helps you ,
thanks.
Cisco ASA 5500... | Answered on Sep 04, 2008
take this site address u will get all the commands of firewall
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/asa80cfg.pdf
Cisco ASA 5500... | Answered on Jun 24, 2008
PPPoE is not supported when failover is configured on the security appliance, or in multiple context or transparent mode. PPPoE is only supported in single, routed mode, without failover.
http://www.cisco.com/en/US/docs/security/asa/asa81/config/guide/pppoe.html
Cisco ASA 5500... | Answered on Jun 06, 2008
You seem to have the last resort (o.o.o.o) set to VLAN1 which is set as an inside interface.
Is VLAN1 connected to the outside router or internet backbone?
If not, change the last resort to the outside Ethernet port.
Cisco ASA 5500... | Answered on May 09, 2008
This is for the pixes, I haven't upgraded an asa yet...should be close or the same
* find latest version of code, these are usually *.bin files located on http://www.cisco.com/cgi-bin/tablebuild.pl/pix
* confirm the flash and RAM requirements of the PIX OS software versus what the PIX has (”sho ver”)
* make sure you have a backup of the old PIX OS and PDM to the tftp server (or at least confirm the software is there)
Note: You cannot back them up from the PIX, so you will need to download them and put them on the tftp server * put in a change control form
* once change controls confirms date/time do the upgrade:
wri mem*** only if you save your configs via tftp wri net conf t ca save all copy tftp://your tftp server ip/pix635.bin flash:imageskip this if you don't use pdm copy tftp://your tftp server ip/pdm-304.bin flash:pdm *** if this is a failover pair, upgrade the other pair reboot
Cisco ASA 5500... | Answered on Nov 11, 2007
If I understand you right, you want to setup a ASA firewall.( VSNL broadband is a company in India I believe) but once you get a static IP
you can assign that ip address to the outside of your asa. Put your dsl
router in pass through mode. This will then allow you to nat your inside
network and for you to accept vpn requests. To set all this up you need to get documentation from Cisco.
Cisco ASA 5500... | Answered on Nov 05, 2007
this has been nicely explained here:
http://www.computerfreetips.com/Cisco_router_tips/ASA-VPN-tunnel.html
Cisco ASA... | Answered on Mar 12, 2012
DO NOT CALL FAKE NUMBERS OR GO TO FAKE WEBSITES. These phony support numbers send you to criminal call centers where they will install malware, steal ID and/or extort money from you. Please only ever use the support contacts from the official company website.
Cisco Computers... | Answered on Oct 21, 2019
Cisco ASA 5500 Firewall Logo
21 questions posted
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Ekse
Jeffrey Groves
Jeffrey Groves
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
ASA Cisco
  • ASA Cisco
Most Popular Question
cisco asa 5505 firmware
  • Computers & Internet
