20 Most Recent
Whirlpool GS6SHEXNL Side by Side Refrigerator Questions & Answers
WHIRLPOOL GS6SHEXNL00 SIDE BY SIDE REFRIGERATOR LIGHT
funny you asked this question i just had this same problem this week at a customers home. you need the electronic control board located in the compressor compartment behind the refrig. it is mounted in the white box on the left hand rear corner. the whirlpool part number is 2304095 and it is around 175.00 i'm not sure who a local part supplier around you would be if all else fails you could get thru sears..
8/7/2019 4:59:37 PM •
Whirlpool...
Answered
on Aug 07, 2019
Tighten door handle on refrigerator
normally no,,,, at the ends of the handle you pry off a cover exposing the screws that hold it on.then snap the cover back on or they slide up and off
9/1/2014 11:53:47 PM •
Whirlpool...
Answered
on Sep 01, 2014
Where do I find the
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5152884&diagram_id=28179385#d28179385
Download and look at # 7 on the bottom
7/20/2011 10:44:16 PM •
Whirlpool...
Answered
on Jul 20, 2011
Need to know what switch
Can you tell me the switch name you need or the problem you're having with your unit and how did you came up with the switch been defective??
Thanks
10/12/2010 2:05:35 AM •
Whirlpool...
Answered
on Oct 12, 2010
Water dispenser stopped dispensing water but ice
I had the same problem. Ice maker works fine. Removed the kick plate at the bottom of the fridge to expose the water line. I disconnected it and then pressed the dispense button. Water pumped out of the line so i know water was getting all the way to the freezer door. I went overkill but it worked. I removed the freezer door and placed it outside. (disconnected the power to the door by disconnecting the plug at the top. and then removed two screws/bolts at the top and the door lifts up and off) I set the door on a patio table with the bottom facing up. I picked up some 16 gauge wire ($6 at Home Depot) and ran it up the water tube from the bottom of the door. The bottom is more of a straight shot up the water line. I also took a turkey syringe used to inject juice into a turkey and i shot very hot water up the line with the door upside down. This allowed water to run up the line and unfreeze it if it was frozen. I let it sit outside for 30 minutes and put the door back on and now it works like a champ. The line was either frozen or it was obstructed. The water line is surprisingly small. Took less than an hour and I now have water again. Not tough at all...
10/7/2010 2:18:23 PM •
Whirlpool...
Answered
on Oct 07, 2010
