20 Most Recent
Samsung 46" Full Hd Led Lcd Slim 1080p Smart Internet Built-in Wifi Un46es6150 Questions & Answers
My samsung smart tv won't connect to my network
You need to setup all you computer network to home network not public network because in order to connect you need to have a password which you need for every system in your home. Consider which computer is your main system. Then go to control panel and select networking icon and select network status. Now click on where it says Public Network or even Home Network and re choose home network and right down the code password. Then click ok and you are set. Go to your TV and choose to setup network, then choose to detect network automatically and choose your network. Then type in your password and you are set. Try it now and you should be able to view your photos, videos and so on. Good luck and let me know you you go!!
Picture quality has suddenly degraded
Some time you get a bad one out of the store,still under warranty period.Yes best just return it to the store get a new one or get some store credits buy another one.Tried research if this brand and models of tv you have this problems happen to it more than the other tv brands out in the market.Tried to proof it to Samsung to get a replacement from them.U tries other incoming live tv broadcast make sure it it not the tv station signal or u tried tv with other media devices like BLURAY or DVD players see u have the same problems correct.
Hi, I'm using the Samsung HT-E330K. It works but does not speak out. The power display is fine but no sound
If your Samsung HT-E330K home theater system is not producing any sound even though the power display seems to be working fine, there are several potential causes and troubleshooting steps you can try:
1. **Check Volume Levels:** Make sure the volume on the home theater system and the connected TV (if applicable) is turned up and not muted.
2. **Check Audio Source:** Verify that the correct audio source is selected on the home theater system. If you're using multiple input sources (DVD, TV, AUX, etc.), make sure the right input source is selected.
3. **Audio Cables:** Ensure that all audio cables are securely connected to both the home theater system and the audio source (TV, DVD player, etc.). Sometimes, loose or faulty cables can result in no sound.
4. **Speaker Connections:** Check that all speakers are properly connected to the home theater system and that the speaker wires are securely inserted into the appropriate terminals.
5. **Audio Settings:** Go through the audio settings on both the home theater system and the connected TV (if applicable). Ensure that the correct audio output settings are configured.
6. **Mute Function:** Double-check that the mute function on the remote control or the home theater system itself is not engaged.
7. **Speaker Balance:** Check the speaker balance settings to ensure that sound is not unintentionally directed to one side or speaker.
8. **Reset to Default Settings:** If you've made any changes to the settings recently, consider performing a factory reset to revert to the default settings.
9. **Firmware Update:** If there is a firmware update available for your home theater system, consider updating the firmware as it might resolve any software-related issues.
10. **Test with Different Source:** Test the home theater system with different audio sources to rule out issues with a particular device.
11. **Test Speakers:** If possible, disconnect each speaker one at a time and test the audio to identify if a particular speaker or speaker wire is causing the issue.
12. **Check Speaker Impedance:** Ensure that the speakers' impedance matches the specifications of the home theater system. Mismatched impedance can affect sound quality.
13. **Contact Support:** If you've tried these steps and still have no sound, consider contacting Samsung customer support or seeking assistance from a professional technician for further troubleshooting and repair.
Remember to refer to your device's user manual for specific instructions related to your model.
