20 Most Recent Frigidaire Gallery GLWS1339EC Top Load Washer Questions & Answers
3answers
Adgitator removal
Just follow these steps:
1. Remove the center dispenser from the top of the agitator. It should just pop off.
2. Locate the white plastic cap underneath and pull straight up to remove.
3. Locate the agitator bolt underneath and remove using a socket and ratchet (can't remember the size). Hold the agitator still with one hand in order to loosen the bolt.
4. With the bolt removed, grasp the agitator by the bottom flanges and pull straight up. It should lift off the center post.
NOTE: Sometimes these agitators will stick due to years of detergent accumulation. You may have to wobble it back and forth to get it loose.
If you have questions, please let me know. I hope this helps you.
12/23/2020 7:07:02 PM • Frigidaire... • Answered on Dec 23, 2020
My frigidaire gallery washer jumps around on the
Two thoughts come to mind;one is that the load is not distributed evenly in the tub, try distributing the load by weight more evenly; two perhaps the feet of the machine are not set for even contact with the floor.The machine should not rock from corner to corner
2/14/2018 7:16:06 PM • Frigidaire... • Answered on Feb 14, 2018
I have a 10 year
NOT A 100 PERCENT SURE BUT MOST WASHERS HAVE A PRESSURE SWITCH ON THE TO DETERMINE YOUR SIZE OF LOAD IF THIS SWITCH FAILS IT WILL KEEP THE WATER RUNNING.
4/28/2017 5:01:26 AM • Frigidaire... • Answered on Apr 28, 2017
Frigidaire gallery washer smoking and not spinning
Sounds like you either have something in the pump or maybe the belt is slipping on the pulley.
8/5/2015 2:18:10 PM • Frigidaire... • Answered on Aug 05, 2015
Water will not enter machine
WHEN U SAY THE WATER SWITCH IS GOOD Have u dont a voltage test as well as a OHMS meter reading? As it can test good for ohms and still be bad electronically. the only other thing to check is the water pressure switch but my bet is with the water inlet valve or bad control board issue Washer fills with water and overflows: The water pressure level switch is a pressure activated switch that is used to determine the correct water level in the tub. This part is normally located behind the control panel and will have a hose or air dome tube that connects it to the tub. On washers that use an electronic control, this switch may be located at the sump area below the tub. As the water fills in the tub it will compress the air in the tube and push against a diaphragm inside the switch. The switch will control the water inlet valve and turn the valve off at the correct water level. If the tube has a leak, not enough pressure may be created to activate the switch and the washer may overfill. If the switch is defective it may also cause the machine to overfill. To determine if the switch is bad, you should first eliminate the air dome hose as a problem. Look for signs of cracks or worn areas on the hose. Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well. If the air dome hose appears to be ok, then the water level switch may be defective. You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube. If the machine starts to wash. the pressure switch is more than likely good ( No wash- then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED). The other item to check would be your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board. You can also do a live volt test to see if it is getting the full 120 current, but be sure to unplug unit before testing as this is a live test. Also another trick to check the water valve, is to first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed By the way my advice is free cuz God is good! 24637619-vy3qd1rc3oikbunb5kfp1hkm-3-0.jpg 24637619-vy3qd1rc3oikbunb5kfp1hkm-3-2.jpg 24637619-vy3qd1rc3oikbunb5kfp1hkm-3-5.jpg 24637619-vy3qd1rc3oikbunb5kfp1hkm-3-9.jpg 24637619-vy3qd1rc3oikbunb5kfp1hkm-3-14.jpg 24637619-vy3qd1rc3oikbunb5kfp1hkm-3-20.jpg
5/15/2015 9:23:06 PM • Frigidaire... • Answered on May 15, 2015
My washing machine will not draw water hot or cold
are u sure the water valve is ok? is it getting the full 120 volts not just continuity? Also may want to check The water pressure level switch is a pressure activated switch that is used to determine the correct water level in the tub. This part is normally located behind the control panel and will have a hose or air dome tube that connects it to the tub. On washers that use an electronic control, this switch may be located at the sump area below the tub. As the water fills in the tub it will compress the air in the tube and push against a diaphragm inside the switch. The switch will control the water inlet valve and turn the valve off at the correct water level. If the tube has a leak, not enough pressure may be created to activate the switch and the washer may overfill. If the switch is defective it may also cause the machine to overfill. To determine if the switch is bad, you should first eliminate the air dome hose as a problem. Look for signs of cracks or worn areas on the hose. Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well. If the air dome hose appears to be ok, then the water level switch may be defective. You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube. If the machine starts to wash. the pressure switch is more than likely good ( No wash- then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED). The other item to check would be your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board. You can also do a live volt test to see if it is getting the full 120 current, but be sure to unplug unit before testing as this is a live test. Also another trick to check the water valve, is to first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed By the way my advice is free cuz God is good! 24640925-vy3qd1rc3oikbunb5kfp1hkm-3-0.jpg 24640925-vy3qd1rc3oikbunb5kfp1hkm-3-2.jpg 24640925-vy3qd1rc3oikbunb5kfp1hkm-3-5.jpg 24640925-vy3qd1rc3oikbunb5kfp1hkm-3-9.jpg 24640925-vy3qd1rc3oikbunb5kfp1hkm-3-14.jpg 24640925-vy3qd1rc3oikbunb5kfp1hkm-3-20.jpg 24640925-vy3qd1rc3oikbunb5kfp1hkm-3-27.jpg
5/15/2015 9:00:56 PM • Frigidaire... • Answered on May 15, 2015
Maytag washer
sign of bad motor coupler or broken transmission spring
4/1/2015 12:16:19 AM • Frigidaire... • Answered on Apr 01, 2015
Will not fill with water. no water will enter macg
check water inlet valve and water outlet at the house
3/31/2015 9:26:16 PM • Frigidaire... • Answered on Mar 31, 2015
Frigidaire washer repairs
it almost has to be the belt think the front comes off to check it out
9/8/2014 10:21:01 PM • Frigidaire... • Answered on Sep 08, 2014
Top loader washing maching stops at rinse cycle
I PRETTY SURE YOU HAVE A BAD LID LOCK NO LOCK NO SPIN
9/2/2014 3:05:56 AM • Frigidaire... • Answered on Sep 02, 2014
How much to install a timer in a washing machine
Good Afternoon Friend, I understand you want to know the cost to install a timer in your Frigidaire washer, model# GLWS1339EC. Typically, any quotes or prices, would be between you and the technician that comes out to service your appliance. There will probably be a diagnosis fee, as well as a labor fee, plus whatever parts might be needed. Hope this is helpful. -Best Regards- WP
6/27/2014 10:00:20 PM • Frigidaire... • Answered on Jun 27, 2014
The washing machine will ot fill with water
Good Afternoon Friend, I understand your Frigidaire Gallery washer, model# GLWS1339EC, will not fill with water. First, make sure that the water supply is adequate in area where your washer is located. Secondly, make sure the water supply faucets are completely open. Thirdly, make sure water is not being used elsewhere in the house. The water pressure must be at least 30PSI. Try to avoid running water elsewhere, while the washer is filling. Lastly, make sure the water inlet hoses are not kinked. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful. -Best Regards- WP
6/19/2014 9:00:21 PM • Frigidaire... • Answered on Jun 19, 2014
Washer will not fill with water
Good Morning Friend, I understand that your washer, model# GLWS1339EC, will not fill with water. I also see that you have checked the water pressure, the valve, and made sure there are no blockages. I suggest contacting your local authorized technician. They will be able to diagnose your appliance and determine what is causing your washer to not fill with water. Hope this is helpful. -Best Regards- WP
6/19/2014 3:54:08 PM • Frigidaire... • Answered on Jun 19, 2014
Will not fill with water cold or hot
Good Afternoon Friend, I understand that your Frigidaire washer, model# GLWS1339EC, will not fill with cold or hot water. I also see that you have tested the valve, the water pressure, and made sure that there wasn't any blockage in the water hoses. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine why your washer will not fill with water. Hope this is helpful. -Best Regards- WP
6/17/2014 4:41:48 PM • Frigidaire... • Answered on Jun 17, 2014
Frigidaire Gallery GLWS1339EC Top Load Washer Logo
169 questions posted
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Washing Machines
Most Popular Question
frigidaire gallery washer smoking not
  • Washing Machines
