20 Most Recent Sunbeam 3852 Waffle Maker Questions & Answers
3answers
No instructions for used Sunbeam#3856 waffle maker
download here:
http://www.retrevo.com/support/Sunbeam-3856-manual/id/952ag122/t/2/
5/9/2013 10:42:11 PM • Sunbeam 3852... • Answered on May 09, 2013
Goodmorning, I bought
Try preheating the griddle for 5 minutes, then spray a light coat of pam on the hot waffle iron plates, and then add the batter (standard batter should work) (I wouldn't add oil if it's not in the recipe). Good Luck to You with that....
1/20/2013 10:47:54 AM • Sunbeam 3852... • Answered on Jan 20, 2013
I lost the instructions for
Here is a direct link to the User's Manual for your appliance:
http://dl.owneriq.net/d/db0acd4e-57c1-43f0-a51b-4ef04ad30e2d.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
See page 2 of the manual for detailed operating instructions. Basically they read as follows:
Preparing Waffles
1. Close Waffle Maker and plug into outlet. Use only voltage specified on bottom of Waffle Maker. The Power light (Red) and Ready light (Green) will come on.
Caution: Touch Waffle Maker only by handles during use or directly after use. Take care not to touch hot surfaces.
2. The Waffle Maker is ready for initial use when the Ready (green) light goes out (approximately 2-4 minutes).
3. Open Waffle Maker, pour approximately 3/4 cup waffle batter onto grids. For best results, pour batter around outer edge of waffle maker. Close cover. It is very typical to have a small amount of batter run over grid and down Waffle Maker. However, if an excessive amount of batter runs over, use less batter.
4. Close the Waffle Maker by lowering the upper plate onto the lower plate and secure with the safety latch. Do not open cover while steam is escaping. Most waffles bake in approximately 2-4 minutes, depending on personal taste. Waffles are generally done when the Ready light (green) goes out and when steam no longer escapes from sides and front of Waffle Maker.
5. When waffles are done, remove with a fork or wooden tongs. Note: Be careful you do not scratch the non-stick cooking surface.
6. Close cover and wait for Ready light to go out before preparing another batch of waffles. The next waffle may be baked in less time because the plate will store heat.
I hope that was helpful to you, good luck and take care.
Joe.
9/2/2011 5:11:49 PM • Sunbeam 3852... • Answered on Sep 02, 2011
Looking for used "Sunbeam Waffle Baker &
I have a Sunbeam Radiant Control Waffle Baker and Grill with original care and instructional booklet dated 1954,
3/5/2011 8:56:55 PM • Sunbeam 3852... • Answered on Mar 05, 2011
I am trying to make
I found the coating on the sunbeam to be less than impressive in regards to nonstickiness, so I use pam with it and have way fewer sticking probs. As to the doneness issue, if it's not actually burning then try to let it cook longer even if the light goes out. Hope this was a little bit helpful at least:)
8/25/2010 8:10:02 AM • Sunbeam 3852... • Answered on Aug 25, 2010
I need parts for this waffle model 3852
I called Sunbeam and found out that they consider it out dated. No parts are available. It still works so I am ok. Now I don't have to keep looking for a part. Thanks
1/12/2010 9:40:23 PM • Sunbeam 3852... • Answered on Jan 12, 2010
I am looking for a replacement rubber foot for our
Go to:
http://www.sunbeam.com/ServiceLocator.aspx?section=kitchen
Then select your area from the drop down menu to find out where your nearest service center is.
Best wishes,
Graemevm
1/10/2010 9:12:13 AM • Sunbeam 3852... • Answered on Jan 10, 2010
Waffles drying out and sticking
Try getting a teflon coating for your cooking surface.
6/3/2009 2:54:34 PM • Sunbeam 3852... • Answered on Jun 03, 2009
I need wiring diagram for Sunbeam SPH111 please.
For this $20 Sunbeam Heater? You just dispose of it an buy another, they aren't repairable. The are made in China for the price of a cup of rice. https://www.walmart.com/ip/Sunbeam-Compact-Personal-Heater-SFH111-WM1/15126049 If it was online, this would find it. You could try Sunbeam direct, we are Fixya, not them. https://www.google.com/search?q=%22sunbeam+sph111%22+%22wiring+diagram%22 'make model (what it is)' in all questions please Shannon. .
10/19/2023 3:11:42 AM • Sunbeam Kitchen... • Answered on Oct 19, 2023
Sunbeam vegas electric pressure cooker instruction manual
You can find the manual for the Sunbeam Vegas Electric Pressure Cooker here: https://www.sunbeam.com.au/media/manuals/Vegas_Electric_Pressure_Cooker_Manual.pdf
2/22/2023 9:44:33 PM • Sunbeam Kitchen... • Answered on Feb 22, 2023
Hallo, I need a manual for a sunbeam smo-30s . Thx
I'd be happy to help you find a manual for your Sunbeam SMO-30S. You can try the following steps:
  1. Check the Sunbeam website, they may have a manual available for download.
  2. Contact Sunbeam directly and ask if they can provide you with a manual for the SMO-30S.
  3. Check online retailers such as Amazon or eBay if they have the manual for purchase.
  4. Look for user manual or instruction manual on third-party websites such as Manualslib, Retrevo, or Schematics Unlimited
  5. Check with the company where you purchased the SMO-30S to see if they can provide you with the manual.
  6. If you still can't find the manual, you may want to try searching for "Sunbeam SMO-30S manual" on a search engine like Google.
It's important to use the correct manual for your specific model and version of the SMO-30S, so be sure to double-check the model number before downloading or purchasing a manual. I hope that this information is helpful and please let me know if you have any other question.
1/26/2023 1:46:57 PM • Sunbeam Kitchen... • Answered on Jan 26, 2023
Sunbeam Bread Maker 5891 Won't Start - Replaced the Belt
If the bread maker's kneader still won't turn after replacing the belt, it is possible that the issue may be with the motor or the circuit board. To troubleshoot the problem, you could try the following steps:
  • Check the motor to see if it is functioning properly. You can do this by removing the motor and testing it with a multimeter to see if it is producing the appropriate amount of electrical current. If the motor is not functioning properly, it may need to be replaced.
  • Check the circuit board for any visible signs of damage or malfunction. You can do this by removing the circuit board and inspecting it carefully for any burnt or damaged components. If the circuit board appears to be damaged, it may need to be replaced.
  • Check the thermal fuse to see if it is functioning properly. The thermal fuse is a safety device that is designed to protect the bread maker from overheating. To test the thermal fuse, you can use a multimeter to check for continuity across the fuse. If the fuse is not functioning properly, it may need to be replaced.
If none of these steps resolve the issue, it may be time to throw in the towel and consider replacing the bread maker. It is also possible that there may be other underlying issues with the bread maker that cannot be easily identified or resolved, in which case it may be more practical to purchase a new bread maker.
12/30/2022 2:40:27 AM • Sunbeam Kitchen... • Answered on Dec 30, 2022
WANTED: vintage Sunbeam W2 waffle iron front lift handle
Unfortunately not on one that old. Repair the old one with Epoxy resin, or fit something newer. Click on images tab. https://www.google.com/search?q=vintage+Sunbeam+W2+waffle+iron+front+lift+handle+replacement
4/25/2022 6:47:49 PM • Sunbeam Kitchen... • Answered on Apr 25, 2022
2answers
Manual for Sunbeam Country Bakehouse Model BM4600WA
That model number in that 2013 question appears to be over 10 years old. Manuals for it were previously posted on the internet, but no longer appear on the manuals site that had them. Perhaps there is a similar model manual that would help. https://www.manualslib.com/products/Sunbeam-Bm4500-Bakehouse-2805175.html http://www.manualsdir.com/manuals/144612/sunbeam-bm3500.html
1/16/2022 3:47:09 AM • Sunbeam Kitchen... • Answered on Jan 16, 2022
I need the owners instruction manual for Sunbeam induction cooker sic31 please.
ask your retailer for it
5/20/2021 9:30:34 PM • Sunbeam Kitchen... • Answered on May 20, 2021
I need a manual for Sunbeam humidifieridek 1113
Contact Sunbeam directly and request the manual.
4/1/2021 3:56:49 AM • Sunbeam Kitchen... • Answered on Apr 01, 2021
Sunbeam 3852 Waffle Maker Logo
13 questions posted
Top Sunbeam Kitchen Appliances - Others Experts
Mike Cairns
Mike Cairns
Thomas Perkins
Thomas Perkins
Are you a Sunbeam Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Sunbeam Kitchen Appliances - Others
Most Popular Question
no instructions used sunbeam 3856 waffle
  • Kitchen Appliances - Others
