20 Most Recent
Mr. Heater MHU75NG Questions & Answers
Just installed big maxx mu75lp. When call for heat
Make sure you are getting 24 volts back from thermostat and you are getting good connections. If you have 2 wires running to stat, connect them together at unit and see if unit starts. Check for wires unplugged, but I think that a flashing green light means you have 120 volts supply and the stat is not calling for heat
My heater is brand new and worked for 3 days. i
There is something else that is causing the Overload/Roll Over Switch to trip. You can try unplugging the unit from it's electrical source and wait 30 minutes before plugging it back in. That may allow it to reset itself. Unfortunately the Overload/Roll Over Switch is preset at the factory and is not adjustable.
If the unit resets itself and starts working again, but then shuts down, check your Owners Manual for other causes. If you've misplaced your Owners Manual, here's a link to it, that you can download and print.
http://www.heaterstore.com/images_templ/mr-heater-heaters-mhu45-75lp-ng.pdfHope this helps to get you headed in the right direction. If all else fails, call the Technical Service Dept at the number listed in the Owners Manual.
Fires and runs for a few minutes then shuts off
There is a flame sensor located in the last burner that lights up. It is either not seeing flame or not getting flame to it within a certain time. Check the wire that comes from it and goes to the circuit board for a bad connection. Check any ground wire connections for a bad connection. Pull out flame rod (sensor) and polish it with a scrub pad or soft wire brush. If none of these recommendations help, replace the flame sensor. Make sure the flame travels to the last burner, if not, clean the flame tray that allows the flame to go from one burner to another.
Installed new heater it ran
the high limit is an over heat switch that could mean the unit is over fired. you would need to time input or check manifold pressure. the roll out switch is a switch that shuts the unit off if combustion is spilling at the divitor on the unit where the vent connects. with this you need to check your venting
My mr. Heater lights only stays lit for about 3 minutes and then it goes out
I had this same problem with my heater. I cleaned the propane tube where the flame comes out (after it’s off and cooled down) with a Qtip and some alcohol. After removing some cotton, it will fit all the way down to the end of the tube. Repeat until it comes out clean and stays lit. I had to repeat with 91% rubbing alcohol and more Qtips, and most of the cotton removed.
