20 Most Recent
Conair Gs4 Iron Questions & Answers
Conair GS4 Steamer
this is from conair instructions included with steamer, finally found it, hope it helps some!
Rowenta 1500 garmet steamer no longer makes steam
Someone else had this fix and it worked for me: (yay!)
*Remove water tank and collapse the hanger bar.
*Remove two screws at base of hose and work the hose off. It will come out.
*Unplug unit and hold over your kitchen sink with the hose inlet pointing into the sink.
* use your kitchen sink sprayer to forcefully spray water into this hole and it will come back out again releasing the gunk that has been stopping up the unit.
* for good measure, I also used the sink sprayer to flush out the hose.
Put everything back together. And make sure it is dry before you plug it in.
VOILA!!! WORKS GOOD AS NEW. HAPPINESS!
Conair steamer GS4 reconnecting wire on switch relay
Safety First: Before attempting any repairs, ensure the steamer is unplugged from the electrical outlet to prevent electric shock.
Access the Switch Relay Area:
Remove the water tank from the steamer.
Open the casing or access panel where the switch relay is located. This may involve removing screws or clips.
Inspect the Wires:
Look for any loose or disconnected wires near the switch relay.
If you find a wire that has come off, identify its original position.
Reconnect the Wire:
Strip a small portion of the wire insulation if needed.
Reattach the wire to the appropriate terminal on the switch relay.
Ensure it is securely fastened.
Test the Steamer:
Reassemble the casing or access panel.
Plug in the steamer and turn it on.
Check if the switch relay works properly.
Secure the Casing:
Once everything is in place, secure the casing back onto the steamer.
Remember to exercise caution while handling electrical components. If you're unsure or uncomfortable with the repair, consider seeking professional assistance or contacting Conair's customer service for guidance.
CONAIR GS4 SERIES INSTRUCTIONS FOR USE Pdf Download ' ManualsLib
3/10/2024 9:04:04 PM •
Conair Irons
Answered
on Mar 10, 2024
Conair GS33 fabric steamer spews too much
Are you setting the body of the steamer on a table? If part of the hose sits lower than the steamer body steam will condense in the hose and collect in the low spot. Steam pressure will push the water out through the nozzle. If your steamer starts to sputter lift the hose so that it is completely above the level of the water reservoir and let the water drain down. Its a good idea to keep the steamer body on the floor so the hose can never get lower than it.
6/25/2021 3:12:41 AM •
Conair Irons
Answered
on Jun 25, 2021
My handheld Conair garment steamer is heating up but not producing steam. How do I fix this?
A handheld steamer uses hot steam to relax the fibers in clothing. A jet of steam is directed at the cloth suspended on a hanger. A steam wand at the end of a hose is held a short distance from the cloth - providing a smooth look without the application of scorching heat to the clothing.Steamers are ideal for soft and delicate fabrics like silk, satin, polyester and jersey. Because a garment steamer does not actually touch clothing - there is little
6/26/2018 10:10:55 AM •
Conair Irons
Answered
on Jun 26, 2018
