20 Most Recent LG LD40E Dehumidifier Questions & Answers
Discharge air is HOT!! - not cool
A Dehumidifier will not cool your basement, just make it seem cooler at the same temp. Your dehumidifier may be undersized even for that purpose. You need an AC outlet of a central AC in your basement, or a window unit if there are windows. Warm air at discharge is normal.
10/3/2017 5:18:49 PM • LG LD40E... • Answered on Oct 03, 2017
I have a LG dehumidifier
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
8/13/2011 5:01:44 AM • LG LD40E... • Answered on Aug 13, 2011
Unit is not collecting any water in bucket (it has
There are 5 basic things cause the problem you're having. Number 1, you have already taken care of.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder
level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I hope this helps you to troubleshoot and solve the problem. Thanks for choosing FixYa.
7/21/2011 2:35:01 PM • LG LD40E... • Answered on Jul 21, 2011
The light indicating that "bucket
This usually happens when either the Float Valve in the bucket is stuck in the UP position (if yours is so equipped. Jiggle it to get it to return to the DOWN position.
If you humidifier's bucket is not so equipped. It's usually an indication that the bucket was not reinstalled properly, after it was removed. To check and correct this, turn the Master ON/OFF Switch to OFF and unplug the unit. Remove the bucket and reinsert it, making sure that it fits "squarely" in the bucket holder from Top to Bottom. Once installed, make sure the bottom of the bucket is not tilted down in any way. Plug the unit back in and turn the Master ON/OFF Switch to ON. If it was reinstalled correctly, the bucket full light should have gone off and the unit will run as it should, if the humidity extraction level is set low enough.
Hope this helped you to troubleshoot and solve the problem.
6/23/2011 6:22:57 PM • LG LD40E... • Answered on Jun 23, 2011
I have the LG Humidifier
Hi
Error code CH 01 means temperature sensor assembly gone bad. To resolve the error code you would need to change the sensor assembly. To check unplug it and take off all the covers. Now access the control board and remove the old temperature probe by pry T-well open with small screwdriver. Close the back when when new sensor is installed.
Hope this helps... Please post back if you need more information.
Daniel
4/1/2011 12:46:27 PM • LG LD40E... • Answered on Apr 01, 2011
Our dehumidifier is making a loud noise, it is
The most common source of noise is the handle on the water bucket. I'd just remove the handle.
1/15/2011 9:10:28 PM • LG LD40E... • Answered on Jan 15, 2011
This unit continues to run but no water is found
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
10/7/2010 1:49:20 AM • LG LD40E... • Answered on Oct 07, 2010
Dehumidifier not working
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
5/18/2010 2:28:30 AM • LG LD40E... • Answered on May 18, 2010
Dehumidifier not cycling on
Here is a tip that I wrote to help people with just that dehumidifier problem..
Dehumidifier2_bing.gif Problem It shows Bucket Full
http://www.fixya.com/support/r4688381-dehumidifier_problem_shows_bucket_full
heatman101
5/15/2010 7:05:09 AM • LG LD40E... • Answered on May 15, 2010
My dehumidifier LG LHD 45 EL runs, but does not
Here is a tip that I wrote about that problem...
heatman101
4/30/2010 11:24:26 AM • LG LD40E... • Answered on Apr 30, 2010
heatman101
4/30/2010 4:27:51 AM • LG LD40E... • Answered on Apr 30, 2010
Not taking down humidity this year as much and lastl year
Here is a tip that I wrote that will help you...
http://www.fixya.com/support/r3877515-dehumidifier_problems_dehumidifier
heatman101
4/16/2010 3:50:54 AM • LG LD40E... • Answered on Apr 16, 2010
She was a little noisy with the fan sounding like
The capacitor should not be hot, so the motor could be drawing high amps do to a worn bearing which could cause the rubbing sound.
With the power off try to move the motor shaft from side to side, it shouldn't move any that way, if it does the bearings are worn and you need to replace the motor and the capacitor. The other cause for the hot capacitor would be a bad capacitor.
If the motor is bad you should also replace the capacitor at the same time.
8/7/2009 2:54:59 AM • LG LD40E... • Answered on Aug 07, 2009
Compressor cycles on and off
capacitor or low on gas
6/21/2009 2:28:33 AM • LG LD40E... • Answered on Jun 21, 2009
AFTER RUNNING CONTINOUSLY, THERE IS NO WATER IN
What is the dry bulb temp in the room? what is the wet bulb temp in the room? what are you working in temp (in room)
6/9/2009 6:23:31 AM • LG LD40E... • Answered on Jun 09, 2009
Why isn"t my dehumnidifier
It could be that it is just too cold still. Typically these units don't work well if it is under 70 degrees. However....we have had a lot of problems with these machines. Many of them have either sealed system problems (leaks) or the fan motor fails. I would suggest that you take it to an authorized repair center if possible. I believe there is a five year warranty on the machine.
4/17/2009 1:17:56 PM • LG LD40E... • Answered on Apr 17, 2009
Fan
Depending on the ambient temp/humidity and how its set it could definitely run continually. If you don't hear it it's possible the blade is broken or just stuck.
Call 800-243-0000 or go to www.aic.lgservice.com
1/8/2008 5:26:24 PM • LG LD40E... • Answered on Jan 08, 2008
2answers
LG Dehumidifier model LHD459ELY9. No power to the display?
Question edited, toss in a load of CAPS. The capacitor is likely to have failed internally. It can still produce voltage. Or the transformer that supplies power has failed. No one else has recorded this issue https://www.google.com/search?q=LG+Dehumidifier+model+LHD459ELY9.+No+power+to+the+display ..
2/26/2024 6:37:19 PM • LG Dehumidifiers • Answered on Feb 26, 2024
I picked up an LG LDF7551ST dishwasher used, there is a white plastic thing on the left side, assuming water inlet mechanism?
https://www.searspartsdirect.com/manual/44av6atl6i-003204/lg-ldf7551st-dishwasher-parts?sid=sem:ggl:dsagroupb:141452280898::c&keyword=&gclid=Cj0KCQiAtICdBhCLARIsALUBFcHCsKc_OEAYHAPPbyS-9LcLCYIAojCvzFzeIbtp7dOcMwOBVditVK8aAhxCEALw_wcB
12/19/2022 4:08:55 PM • LG Dehumidifiers • Answered on Dec 19, 2022
LG LD40E Dehumidifier Logo
22 questions posted
Top LG Dehumidifiers Experts
ZJ Limited
ZJ Limited
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
View Most Popular
LG Dehumidifiers
  • LG Dehumidifiers
Most Popular Question
unit not collecting any water in bucket
  • Dehumidifiers
