20 Most Recent
Canon imageRUNNER C3170U Color Copier Questions & Answers
Canon imageRUNNER C3170 Color Copier
http://www.usa.canon.com/cusa/support/office/color_imagerunner_copiers/imagerunner_c3100_c3170/imagerunner_c3170i if you print out the configuration page from the printer menu screens it will tell you the languages supported this tells you if pcl5 or ps drivers. Where you may come to grief is getting the fax and scanner to work which I have no idea on how this is achieved.
4/15/2014 11:18:53 AM •
Canon...
Answered
on Apr 15, 2014
Error code 0001
canon ir 2318 photocopierwhat is the solution of error code E00001-0001E000808-000
11/6/2013 2:40:44 PM •
Canon...
Answered
on Nov 06, 2013
Error 000045
OHP sensor error, clean or replace.
8/8/2013 9:41:19 PM •
Canon...
Answered
on Aug 08, 2013
Error code E00002-0081
in Canon IR3170C
you have fixing trouble, to be specific E002 Insufficient temperature rise of the fixing unit.
The non-contact thermistor fails to
reach standby temperature (normally
190 deg C) within 180 sec after reaching
180 deg C.
Try to clear the error by entering service mode:
press *
Press the 2 and 8 keys of the keypad at the same time.
press *
navigate trough service mode : COPIER>FUNCTION>CLEAR >ERR
If these doesnt helps, replace entire fixing assy, its most reliable way to get rid of complications.
Hope that helps!
6/11/2013 1:44:29 PM •
Canon...
Answered
on Jun 11, 2013
Getting error code e000748-4000
E744, means that Language file/BootROM error.
You need to upgrade the DC controller PCB version, wich is done over service support tool. That means that you cant do it on your own, call service.
Hope that helped
1/19/2013 3:07:59 PM •
Canon...
Answered
on Jan 19, 2013
