20 Most Recent Amana ALW780QA Questions & Answers
I had the same problem. You need a brake kit. it holds the drum still while in the agitate mode. the centrifical force of the water during that slow spin is causing the water to spill over the top of your drum. easy and cheap fix.
Amana ALW780QA | Answered on Mar 05, 2011
not only do you have a loud roar but it's leaking small amounts of water thru the top seal and into the spin brg . top brg and seal will have to be replaced .. the pump may be ok they donot make noise and the belt is normal mantaince . the idler just oil it . . the parts that you stated are in the lower part of the maching and the brg is just under the outer tub . .. and just for your info the pump runs both in spin and agit . so why does it not make noise in the wash ? so back to basic the top brg is only going in the spin and they get noisey whe water get s in them .. we do a lot of these and trust me the top brg is your problem . mm hope this helps ... feed back pls and thanks for ysing fix ya .
Amana ALW780QA | Answered on Nov 21, 2010
Hi
Thanks for using FixYa. From what you have described it seems that replacing the bearing should solve the issue however, you can also check the pulley and the brake pads. I dont think they should be bad as if they are bad washer should be making some noise but still would recommend you to check them. Also check this diagram for more information:
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Amana ALW780QA | Answered on Mar 30, 2010
If your washer does not drain you need to check this parts.
  1. Inspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch(some models)
  4. Inspect the water pump
  5. Inspect the drive belt(belt drive only)
  6. Inspect the motor coupler
The AMANA washer has an outer tub and a water pump. Please check these to make sure you can see where the leak is coming from and replace. Also, if your machine has a dispensing system, check all hoses for THAT system. If upon fill up the out tyub HOLDS WATER and DOES NOT Leak, then the outer tub is okay. Carefullky look at the water pump on drain.
Amana ALW780QA | Answered on Nov 16, 2009
hi it is the problem o outlet valve, clean it...... thank u.......
Amana ALW780QA | Answered on Jun 03, 2009
somewhere attatched to the tub/lower water hose is something called a pressure chamber- this will need cleaning out. its identified by a plastic/rubber tube leading from it to a higher switch/unit. in the first instance you can blow some compressed air down the tube to see if that helps. it seems that you may need to do more hot washes. remember isolate machine.
Amana ALW780QA | Answered on Jan 12, 2009
you may have blockage in the drain pipe several feet from washer. if you can run spin cycle with hose in different location ex. tub,sink or outdoors. if this works run long snake down washer drain pipe to clean gypsum residual.
Amana ALW780QA | Answered on Jan 29, 2008
no such thing
Amana Washing... | Answered on Dec 17, 2019
The model number is probably NTW4605EW0. Most appliance models from this manufacturer end with a number. Sears Parts Direct has the Use and Care manual for the NTW4605EW0 here: https://www.searspartsdirect.com/manual/sblu1hn6dz-001268/amana-ntw4605ew0-top-load-washer . Amana has addtional documents for the washer on their support page: https://owners.amana.com/user-manuals/ . Use the drop-down menu and search box to locate the manuals and installation guide. The current link to the manual (in English) is http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10740545.pdf .
I hope this helps. I don't see a printed copy of the manual available from Sears Parts Direct. You can print it yourself or take the file to a print shop (Kinkos, UPS store) later.
Amana Washing... | Answered on Nov 05, 2019
Washing Machines Logo
17 questions posted
Top Amana Washing Machines Experts
Mike
Gerry Harvey
Gerry Harvey
jimorris77
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Amana Washing Machines
Most Popular Question
amana washing machine will not spin
  • Washing Machines
