20 Most Recent
GE WWSE5240G Questions & Answers
GE squeeks to loud to use when starting to AGITATE
The front "bracket apron" as probably be come bent. Remove the front panel and look at the part the shocks hand from. When the tub is full of water, the bracket is bending so much that the motor is rubbing on the bottom frame. You should wear marks there also if I am correct.
Here is a link to the new bracket. Here is a video to show you how to open the washer panel.
With the panel off, run a load laundry and see if it is rubbing.
10/22/2012 1:52:13 AM •
GE WWSE5240G
Answered
on Oct 22, 2012
Bearings sound rough
Could you please describe the problem you are having a little better?Do you hear it all the time or during the spin cycle?
10/22/2012 1:44:23 AM •
GE WWSE5240G
Answered
on Oct 22, 2012
Remove agitator
Remove the cap and there should be a visible screw ,take that out and uou should be able to lift the gitator out
9/22/2011 2:10:27 AM •
GE WWSE5240G
Answered
on Sep 22, 2011
Washing machine will not spin
It sounds like it might be the belt. You should unplug the machine, take the bolts and screws off of the back and lift the cover off. Look for the belt and see if you notice any damage or anything wrong with the belt.
Hope this helps! Please rate my answer :) Thanks!
6/12/2011 4:59:43 PM •
GE WWSE5240G
Answered
on Jun 12, 2011
Washer wants to start at the Wash portion of the
Hi this is a bad pressure switch, it is located in the control panel behind the knobs, its the switch that changes the water level, sometimes you can switch it back in forth real fast from small to large size load and it will start working. But it will eventually need replaced, that part usually runs around $30-50.00.
Sean
3/26/2011 8:40:00 PM •
GE WWSE5240G
Answered
on Mar 26, 2011
Cold water will not stop running
I am assuming that you are having a problem with the cold water overfilling the machine. If only the cold water is overfilling and not the hot, then the fill valve is sticking.
If both hot and cold are contributing to the overflow when the washer is set to 'warm', then it is also possible that the fill valve hose (that goes from the tub to the fill valve switch) may be loose or disconnected (or possibly clogged).
3/1/2011 3:48:14 AM •
GE WWSE5240G
Answered
on Mar 01, 2011
GE model wwse5240G washer suddenly
Problems
with a washing machine not spinning or not draining are often inter
related..
If you are having a problem with your top load
washer then check out this tip...
Washing
Machine
does not Pump or Spin
If you are having problems with your
front load washing machine then checkout this tip...
Front
Load Washing
machine not draining and or not spinning
heatman101
2/19/2011 6:31:26 AM •
GE WWSE5240G
Answered
on Feb 19, 2011
All the lights light up, but washer won't fill
Unplug the machine for one minute. Plug back in and raise and lower the lid six times within 12 seconds. You may need to do it several times before it resets. After resetting the inverter board, put the machine in a spin cycle and see if it runs. If not, check for a green blinking light on the inverter board. It will flash failure codes according to the picture above. If no light you probably have a blown fuse built into the neutral side of the harness on the white/red wire.
GE Hydrowave notes If you need further help, reach me via phone at
https://www.6ya.com/expert/dan_73bbd84fe1d95b61
2/10/2011 1:22:36 AM •
GE WWSE5240G
Answered
on Feb 10, 2011
