20 Most Recent LG LFX21960 Stainless Steel Bottom Freezer French Door Refrigerator Questions & Answers
No cooling
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
9/7/2011 2:10:41 AM • LG LFX21960... • Answered on Sep 07, 2011
We get no water or ice from control panel. On
Er IF - Ice-maker Fan Error - This can be caused by frost accumulation on or around the ice maker fan. Unplug the unit for 3-4hoursto allow this to melt off. If error code persists, call customer care to check & replace ice maker fan motor.Thanks.
1/29/2011 2:05:38 AM • LG LFX21960... • Answered on Jan 29, 2011
Inside light works intermittently
I would disconnect power to the refrigerator and pry the light socket out of the cabinet. Inspect the wire connections and the terminals inside the socket for discoloring. Most times the problem is in the socket connections.
If you have a volt meter and are comfortable measuring voltage, you can test for 120 volts ac between the orange wire that attaches to the light socket and the wires on the switch.
1/19/2011 12:22:45 AM • LG LFX21960... • Answered on Jan 19, 2011
The ice maker is not
1 keep the shut arm down position
2 check the water filter , water filter replace every 10 m
if water filter ok. check water valve
good lock
1/12/2011 7:22:51 AM • LG LFX21960... • Answered on Jan 12, 2011
Lights don't come on
the new bulbs may not be in tight enough . / try spraying them with pam them turn them in they will go in easer and maybe solve your problem .. mm
7/4/2010 8:17:17 AM • LG LFX21960... • Answered on Jul 04, 2010
Lg refrigerator gr-282 mvf NOT COOLING
Try pulling the cover off in the back of the fridge and see if the fan is still operating when you push the light sensor switch in but hold it down for at least 10-20seconds to see if it starts.
3/28/2024 12:01:33 AM • LG Refrigerators • Answered on Mar 28, 2024
2answers
LG GR-P197WVS. How do I keep the refrigerator side from freezing?
Fridge freezing up- and no fan or air circulation: AT TIMES The fan usually stops working due to ice obstruction when the defrost terminator has gone out and u get ice build up? u can check the terminator with a multi meter for continuity but do not check at room temperature. stick the terminator in cup of ice water for 20 minutes then check it for continuity, should be closed when cold and open at room temperature. May also need to check the defrost timer, The defrost timer is usually found behind the front grill "toe kick" of the refrigerator. Or in the fridge compartment near middle top section. u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad? Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next. Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance.. Another item to check with a meter is the heating element itself. Located under the evaporator coils. It should show continuity or resistance OHMS WHEN TESTED AT BOTH ENDS OF THE PRONGS . Lastly check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit? ALSO CHECK THE AIR FLOW VENT SYSTEM and THERMISTORS At times it can get stuck to far closed or open. Some units feature a digital electric adjusting vent system while others are manually set. Check for any ice build up or other obstruction in the vent damper, see if u can manually open or close it. Some times when u have the settings set to the highest it closes off one area while allowing to much cold air flow to the other area! THERMISTORS in the freezer and fridge section for continuity OHMS and for amount of OHMS current being put out. In most models around 1300 ( give or take 150 ohms) ohms is required God is so good: so this is why I give free advice so please thank him not me. lg-gr-p197wvs-prevent-refridgerator-iizpua1124tc1voeqjalmrl5-3-0.jpg lg-gr-p197wvs-prevent-refridgerator-iizpua1124tc1voeqjalmrl5-3-2.jpg lg-gr-p197wvs-prevent-refridgerator-iizpua1124tc1voeqjalmrl5-3-5.jpg lg-gr-p197wvs-prevent-refridgerator-iizpua1124tc1voeqjalmrl5-3-9.jpg lg-gr-p197wvs-prevent-refridgerator-iizpua1124tc1voeqjalmrl5-3-14.jpg lg-gr-p197wvs-prevent-refridgerator-iizpua1124tc1voeqjalmrl5-3-20.jpg
3/17/2024 4:40:23 AM • LG Refrigerators • Answered on Mar 17, 2024
2answers
LG fridge LFC25760ST beeps and increases temperature intermittently when door is opened.
1/2/2024 12:40:07 AM • LG Refrigerators • Answered on Jan 02, 2024
My LG refrigerator is flush to the wall, and I can't remove the bottom drawer that has a spill under it. How do I clean it?
You just pull it out 12" so the door will open fully.
10/23/2023 7:38:06 PM • LG Refrigerators • Answered on Oct 23, 2023
7answers
My LG fridge won't stop beeping? The doors are closed properly. We are getting 3 beeps every 30 seconds! Help....
Happened to me, too. I hadn’t placed the top hinge covers back on after removing the doors to move the fridge. The sensors that tell the fridge the doors are closed are in the hinge covers.
10/21/2023 10:54:08 PM • LG Refrigerators • Answered on Oct 21, 2023
Hi I'm using LG model GR-J268LSJV not cooling at all showing f d5 as an error
Error code list is given on LG Official website LG Refrigerator - Error Code List ' LG USA Support Error code P5 is not listed in error code list. Please mention exact error code.
10/11/2023 12:31:56 PM • LG Refrigerators • Answered on Oct 11, 2023
Does the LG LFXS28968S have a defrost timer?
It appears that it doesn't. It appears to have a Thermistor and a heater. That would mean timing comes from the control board. https://www.google.com/search?q=LG+LFXS28968S+defrost+timer ..
10/8/2023 9:13:16 PM • LG Refrigerators • Answered on Oct 08, 2023
LG Washer / Dryer Combo Model Number WM3987HW. Won't Turn On.
Do you have a test meter to check if the power button is working and has continuity? My advice with a suspected control board is always to get professional diagnosis due to the cost or control boards. It would be a shame to buy one and find it doesn't fix the issue. ..
9/6/2023 8:39:24 PM • LG Refrigerators • Answered on Sep 06, 2023
LG REFRIDGERATOR LFX25973ST / 06 : DOOR ICEMAKER EAU61843013: NOT DUMPING ICE INTO BASKET
unplug the power for 10 minutes then plug it back in. this seems to work on mine,
8/15/2023 5:37:05 PM • LG Refrigerators • Answered on Aug 15, 2023
Interchangeable lg ice maker models
While the LG AEQ57518210 and LG 5989JA0002Y ice makers may appear similar and have the same adapter, it's important to note that using a different ice maker model than the one specified by the manufacturer can have potential risks and consequences. Refrigerators are designed with specific components, including ice makers, that are tested and engineered to work together as a system. Using a different model ice maker may lead to the following issues:
  1. Compatibility Issues: Even if the adapter fits, there might be compatibility issues between the different ice maker models and your refrigerator. The electrical connections, mounting points, and water supply might not align properly, causing installation difficulties or functionality problems.
  2. Performance and Quality: Ice makers are designed with specific performance and quality standards. Using a different model ice maker might lead to subpar ice production, inconsistent ice quality, or even no ice production at all.
  3. Leakage or Water Damage: Improperly fitted or incompatible ice makers could result in water leakage, which can cause damage to the refrigerator, flooring, or surrounding areas.
  4. Electrical or Wiring Issues: Different ice maker models might have different electrical requirements or wiring configurations. Mismatched electrical connections could lead to electrical problems or even pose safety risks.
  5. Voiding Warranty: If your refrigerator is still under warranty, using non-standard parts like an incompatible ice maker might void the warranty.
  6. Long-Term Reliability: While the initial cost savings might be tempting, using an incompatible ice maker could lead to long-term reliability issues for your refrigerator.
8/5/2023 10:17:31 AM • LG Refrigerators • Answered on Aug 05, 2023
LG LFX21960 Stainless Steel Bottom Freezer French Door Refrigerator Logo
16 questions posted
Top LG Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
LG Refrigerators
  • LG Refrigerators
Most Popular Question
lights dont come
  • Refrigerators
