20 Most Recent Black & Decker SpaceMaker ODC440B 12-Cup Coffee Maker Questions & Answers
How do i remove the back to replace the red elbow?
first... maybe possibly the model is imprinted on the bottom. it would help alot otherwise we can't help.
2/6/2018 10:13:53 PM • Black & Decker... • Answered on Feb 06, 2018
We have a Black and
Use your phone book or online yellow pages to search for a repair shop in your area. I suspect a thermal fuse has blown in your unit. Only an experienced repair tech can replace it. Sometimes, the cost of the repair is more than a replacement appliance.
1/6/2018 2:50:17 PM • Black & Decker... • Answered on Jan 06, 2018
2answers
I have a black and
Go to the links below:
From $14.50 and up
http://www.google.com/products/catalog?q=ODC440B-03&hl=en&client=firefox-a&hs=jEB&rls=org.mozilla:en-US:official&prmd=ivns&biw=1386&bih=906&um=1&ie=UTF-8&tbm=shop&cid=4892405382470279674&sa=X&ei=N2bxTbPkNY-isQPWh_y9Dg&ved=0CEkQ8wIwAA#scoring=tp
$18.97
http://buyitnow64.stores.yahoo.net/bldespcoodbl.html
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
8/19/2012 4:19:14 PM • Black & Decker... • Answered on Aug 19, 2012
Won't turn on- have a spacesaver
If the clock works and the hot plate warms up, check this solution.
7/10/2010 2:58:54 AM • Black & Decker... • Answered on Jul 10, 2010
Have to turn coffeemaker off/on to brew complete pot
The thermal cutoff switch is faulty.Check this solution.
7/10/2010 2:43:24 AM • Black & Decker... • Answered on Jul 10, 2010
Where can I buy one in burlington ontario
they are now selling these and newer models on Ebay 28 million people a day look @ Ebay . happy hunting !!!!!!!!
3/14/2010 7:03:33 AM • Black & Decker... • Answered on Mar 14, 2010
Leaking black and decker under counter coffee pot
the 90 degree red elbow has worn away of hot water temps and will leak some but all hot water to the bottom of machine. needs to be replaced or retrofit one
3/14/2010 7:00:12 AM • Black & Decker... • Answered on Mar 14, 2010
There is no power to the unit
the thermal fuse has blown.
be careful after replacing it because the reason it blew is probably because the unit overheated which means the thermal switch failed (stayed closed)
1/24/2010 6:50:10 PM • Black & Decker... • Answered on Jan 24, 2010
My Black and Decker Spacemaker coffee Maker will
We had this same problem and it turned out that the inside if display and circuit board caught on fire and melted inside. File a report with the USCPSC and call Black and Decker. They are sending us a new model free of charge but they are also telling me to send them the coffee pot free of charge wtih postage paid. I refuse to do this for 30 days because the Consumer Product safety commission wants me to keep it for 30 days to investigate
11/11/2009 4:44:00 AM • Black & Decker... • Answered on Nov 11, 2009
2answers
Water and coffee spilling from Filter Basket onto counter?
We used to have the same problem! try a better brand of coffee filter! It worked for us? Also make sure that the filters are not doubled up!
7/29/2009 2:23:55 PM • Black & Decker... • Answered on Jul 29, 2009
Water reservior spills the water trying to push button to put in also the light is not working i got it for xmas modelodc440white do i have adefective pot? not satisfied with it i loved the old space
Try contacting your warranty service at Black and Decker if your machine is under warranty. If you don't know then you should be able to call and find out. I don't have the number for them but a quick internet search should find it or if you have your user manual then all information should be inside.
Coffeediva22
1/15/2008 10:55:14 PM • Black & Decker... • Answered on Jan 15, 2008
I have black & decker pw1400s it is possible to connect the water faucet
It will depend on what kind of faucet it is. You can get adapters for the faucet on your kitchen sink but I find they are not very good for pressure washers. They can leak and spray water all over your sink and kitchen. For a pressure washer it is best to have an outside faucet fitted. This will give you the correct type of faucet to connect to and a good supply of water to the pressure washer. It is usually not very expensive to get one fitted.
3/2/2020 6:10:23 PM • Black & Decker... • Answered on Mar 02, 2020
Black & Decker CM1609 keeps shutting off in the middle of making coffee
I had my black& Decker for about 6 months or so and it started shutting off after a minute or two of brewing. I cleaned it by running 5 cups white vinagar through it twice and using a filter in basket. Then running 2 pots of clean water through. I had to keep turning it on but by they end of later last pot of water rinse it stay on all they way through .there was an incredible about of lime built up . try it worked for me.
1/14/2019 7:51:28 PM • Black & Decker... • Answered on Jan 14, 2019
Black & Decker AS 150 - water tank leaks. How do I fix it?
there is no fix or repair, just replace it
11/12/2018 2:26:45 AM • Black & Decker... • Answered on Nov 12, 2018
Black & Decker SpaceMaker  ODC440B 12-Cup Coffee Maker Logo
Popular Tags
24 questions posted
Top Black & Decker Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Black & Decker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Black & Decker Coffee Makers & Espresso...
  • Black & Decker Coffee Makers & Espresso...
Most Popular Question
leaking black decker under counter
  • Coffee Makers & Espresso Machines
