20 Most Recent Whirlpool WTW6400SW Top Load Washer Questions & Answers
0answers
Washer out of balance in the spin mode
You will need to open the cabinet and check the suspension springs.
12/10/2012 5:53:07 PM • Whirlpool... • Answered on Dec 10, 2012
When washer starts agitating makes a whining noise
need to replace drain pump before its to late, this is the first signs of the pump getting ready to seize up
2/19/2012 1:20:06 AM • Whirlpool... • Answered on Feb 19, 2012
Unbalanced load
it could be your pump blocked and not discharging the water it will become unbalanced not spin
11/29/2011 7:38:53 PM • Whirlpool... • Answered on Nov 29, 2011
F-50 code
The F-50 code is directly related to the motor and the motor controller board, more than likely you need a motor controller
11/25/2011 2:48:33 PM • Whirlpool... • Answered on Nov 25, 2011
I replace the motor control becouse the O L
There are 2 codes which you may be mis-interpreting.
OL
and
DL
DL is a door latch/lock error
OL is a different beast....
OL error means the Motor Controller has sensed an Overload.
The oL code means the motor control board is struggling to power the motor up. If it recurs after removing some clothes - usually this means a new motor control.... or worse - a new bearing.
If it were a problem with the tub floating up, the unit would spin instead of nutate.
Bearing failure in this machine is very common.
I suspect the drive shaft and bearing are the problem. The bearing and shaft are part of the outer tub.
The new outer tub with bearing cost approximately $197 dollars.
If you can get access to the shaft it may be an Emory cloth will help smooth things down so that you no longer get the OL code.
This is an ambitious do-it-yourself project... as most appliance repairmen don't understand how this machine operates.
CLICK HERE
Thanks for using FixYa
3/4/2011 2:19:36 AM • Whirlpool... • Answered on Mar 04, 2011
Washer is leaking out of bottom, had appliance man
The Seal is not designed as separate item to be replaced. Note that water can also get into the motor if it is leaking and this will lead to more expense. You may want to think about replacing the complete machine.
3/2/2011 1:18:30 PM • Whirlpool... • Answered on Mar 02, 2011
Water is leaking from bottom
it sounds like you have a leaking pump, or a hose has been split, or chewed through by vermin
2/17/2011 4:01:10 PM • Whirlpool... • Answered on Feb 17, 2011
What does the code PO mean?
Hi, PO means Pump Out (lid opened).
Po flashes when drain pump begins pumping out water from tub upon activation by the door lid having been left open for more than 10 minutes.Close door lid to stop drain pump.
10/4/2010 5:43:39 AM • Whirlpool... • Answered on Oct 04, 2010
Whirlpool washer wtw6400 giving F50 error message.
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%
9/28/2010 2:11:28 PM • Whirlpool... • Answered on Sep 28, 2010
On the last 20 mins or so during the rinse cycle
This advice is for a washer that fills and will not shut off, resulting in an overflow. Or, water is leaking from the washer while filling. The symptoms can apply to either a TOP LOADER or FRONT LOADER washer. This may be able to save you from an expensive service call by making these simple visual checks.
Water Does Not Shut Off and Overflows: The water level in a washer is controlled by the Pressure Switch. The switch is usually cylindrical in shape and has an electrical connection and an air hose attached. In many cases, the small air hose comes loose from the Pressure Switch fitting and/or falls off. This air hose is required to detect the air pressure from the wash tub as tub fills. With no air pressure, the switch will not function and the result will be a wash tub that fills continuously to the point of overflowing. The same would be true, if the air hose has any cracks, splits or holes in it.
Water Leaking While Filling: The other end of this hose runs to the air dome fitting on the side of the wash tub. If the lower end of the hose comes off, the water will begin to spill onto the floor under the washer, but the tub will not fill.
What to Look For: Check for the obvious. Make sure the air hose is still attached to the pressure switch and air dome. Then, inspect the entire length of the hose, paying particular attention to areas where chaffing may occur and at the points where the hose connects to the pressure switch and air dome. Vibrations from the washer can cause some wear if the hose is rubbing against anything, and the ends of the hose can stretch over time and not seal properly.
On most top loaders the Pressure Switch is located inside the operator console behind the knob that controls the water level. This knob is commonly referred to as the "Load Level", "Load Size" or "Water Level". On front loader washers the pressure switch location is usually located in the back of the washer behind the wash tub, or along the interior cabinet wall adjacent to the wash tub.
How to Correct: If the hose has slipped off, cut about ½" off the end of the hose and reattach to the pressure switch and/or air dome fitting. Take a small zip tie and place it around the hose at the point where it connects to the fitting. DO NOT over tighten as this can damage the air hose fitting. Just make the zip tie snug enough to keep the air hose from sliding off. If the hose has any cracks or holes, you can attempt to seal them by using electrical tape. Replacement tubing can be purchased at any hardware store.
NOTE: This is not an all inclusive fix, as the Pressure Switch can fail in some cases and cause similar symptoms. This is merely a preliminary check for a common occurrence that I have discovered. It can give symptoms of a major problem, resulting in a call for a repairman, only to turn out to be a simple fix that any Do-It-Yourselfer should be able to check and correct themselves. I hope this information is found to be helpful and saves many of you a future service call.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
9/23/2010 1:44:33 PM • Whirlpool... • Answered on Sep 23, 2010
Cabrio washer F1 error
Hi
Thanks for using FixYa. Error code F1 indicates primary control failure and to resolve this you?ll have to replace the machine control assembly. Yes you are right, this error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
9/7/2010 8:01:20 PM • Whirlpool... • Answered on Sep 07, 2010
Whirlpool Washer, Fabric Softener Dispenser
THIS IS AN EXPENSIVE FIX FOR A SMALL PROBLEM I RECOMMEND BUYING A "DOWNEY BALL" IF YOU MUST HAVE FAB SOFT
2/7/2010 10:21:22 PM • Whirlpool... • Answered on Feb 07, 2010
My Cabrio washer was flashing the F50 code and we
F-50 or F-51 is the RPS sensor failiure or clothes stuck in between tubs. don"t overload it with small clothes. Sensor has been redesigned and whirpool released repair that it won"t happen again. F1 on begining cycle is pressure sensor which also have been updated but 99% of people are at fault themselfs cause they use regular detergent instead of HE. also, cleaning it once a month is a must......with washing machine cleaner like affresh....
1/8/2010 6:51:21 AM • Whirlpool... • Answered on Jan 08, 2010
Top loader washer wtw6400sw3 will not finish
"LD" stands for "long drain," meaning it took an excessively long time for water to drain out of the washer. Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose. Why, I've even heard of bra wires coming loose and getting stuck in that hose, collecting all sorts of gookus and pinching off the flow of water to the pump. Can you imagine? Yea verily, as surely as the Sacred Suds doth eternally pass my lips, the "LD" error code springs forth from such anomalies. Can I hear an Amen?
1/8/2010 6:31:42 AM • Whirlpool... • Answered on Jan 08, 2010
Whirlpool WTW6400SW Top Load Washer Logo
45 questions posted
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
View Most Popular
  • Whirlpool Washing Machines
Most Popular Question
water leaking from bottom
  • Washing Machines
