20 Most Recent Behringer FCA202 - FireWire Audio Interface Sound Card Questions & Answers
My behringer f-control audio fca202 do not install the drivers
This appears to be a very old device that was intended for use with Windows XP: https://media63.music-group.com/media/sys_master/h46/h33/8849495293982.pdf I suspect that the software is incompatible with Windows 7.
8/27/2019 7:40:16 AM • Behringer FCA202... • Answered on Aug 27, 2019
0answers
Wont recognize device
Go to bios to tweak it ! F2 , THEN AUDIO ! ENTER !
9/25/2012 5:00:18 PM • Behringer FCA202... • Answered on Sep 25, 2012
2answers
Fca 202 sound card driver not working with xp64
it won't work beacuse on windows xp64bit only 64-bit kernel mode drivers are supported.....
12/17/2011 12:49:41 PM • Behringer FCA202... • Answered on Dec 17, 2011
Hi. My iMac froze/crashed 4
Probably the driver was affected and it is not listing it ..(would' not recognize it ) ...If you have a time machine on your system and allows you to recover the settings and the drivers you use to have on it ..its the easiest way to do the recover..if not , I suggest to remove the device ...locate and delete all the traces of the old driver-software used to manage it ..and reinstall it from the disk ..or download the driver again from where you first install it ..It is the only way in this case..In normal case it will not need a driver to run it ..cause it has a Core Audio compliant as interface and this is a mac platform ..but ..you may have issues with the firewire driver itself ..and in this case read this article about the same issue ..You may need to reinstall the driver for firewire....
http://www.macgeek.co.za/2007/10/18/fixing-a-broken-behringer-fca202-external-firewire-audio-interface-which-breaks-on-os-10410-update/
This one is about the time machine ..and how to restore..if you used this feature..
http://support.apple.com/kb/ht1427
If there are still issues just reinstall the mac os ..and than it will see it automatically like the first time ..
8/6/2011 10:09:47 AM • Behringer FCA202... • Answered on Aug 06, 2011
Wont work with win 7
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enable windows 7
click start control panel hardware and sound manage audio devices playaback you should see your speakers right click select enable or you might have to configure them this option will be at the bottom of of the playback list windows7 click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further changes to your sound setting by right clicking on the speaker icon in the taskbar(bottom of screen) hope this helps
7/21/2011 10:21:41 PM • Behringer FCA202... • Answered on Jul 21, 2011
This product doesn't work with the Windows Vista
In windows you can find the program you want to run and then tell windows to emulate a previous version. If you are working within VISTA then you right click the actual program ICON (NOt a shortcut on desktop) and choose properties you wll see a tab called COMPATIBILITY. In the top you will RUN THIS PROGRAM IN COMPATIBILITY MODE FOR ######## here you can choose a previous version of Windows such as XP or earlier to use. Try having the program run in compatibility mode to determine if it can find the Sound Card. Its possible a driver update or other Windows update in VISTA is incompatible with the device.
6/13/2010 1:43:17 PM • Behringer FCA202... • Answered on Jun 13, 2010
Driver installation problem
Some computer firewire interface's don't work very well under Windows... However...
Make sure you follow the installation directions to the letter... especially in regard to whether the cable is plugged in while installing...
Also you MIGHT try installing the software in SAFE MODE.
Then in the audio editing software you often have to configure the audio in/out device.
This can realy be frustrating... I just fought a UA 25EX to get it to work and the problem was an incorrect switch to the sample rate.
5/26/2010 12:27:00 AM • Behringer FCA202... • Answered on May 26, 2010
No sound
What exactly is evrything?
Reinstalled sound drivers?
Checked your speaker cord to make sure it comes into the green hole on the back?
made sure your speaker wires are not broken?
Volum on the speakers?
Control pannel> Sound> Speaker Icon: Are the controls HIGHLIGHTED? If not sound driver is not loaded.
Check Volum MUTE. SOme programs MUTE your volume without a warning.
3/18/2009 4:26:53 PM • Behringer FCA202... • Answered on Mar 18, 2009
2answers
No Sound produced from my Behringer FCA202 Firewire soundcard.
what os are you using
9/9/2008 1:46:06 PM • Behringer FCA202... • Answered on Sep 09, 2008
Behringer F-CONTROL AUDIO... Problem:
I had a similar problem where as I could use the mic no problem at all but couldn't hear anything through the headphones. The simple solution was to disable the driver for my internal soundcard. It took me 48 hours to work it out! Good luck.
6/9/2008 12:18:39 AM • Behringer FCA202... • Answered on Jun 09, 2008
Sound problem
What os are you using.
1/6/2008 3:56:16 AM • Behringer FCA202... • Answered on Jan 06, 2008
Poor/fragile connection
Yes, it sounds like the ports may be coming loose, I would attempt to return, if out of warranty, find someone that can solder well, i've replaced ports on external hard drives, not fun.
10/23/2007 1:41:33 AM • Behringer FCA202... • Answered on Oct 23, 2007
Behringer Europower Pmp1280s, remove front panel
To remove the front panel of the Behringer Europower PMP1280S, you may need to follow these steps: 1. Ensure the device is powered off and disconnected from any power source. 2. Locate all the screws that secure the front panel to the chassis. Based on your description, it seems you have already removed the screws on the front side and the ones on the frame. 3. Sometimes, there may be additional screws hidden beneath labels or rubber feet. Carefully inspect the front panel for any hidden screws and remove them if present. 4. Once all the screws are removed, gently try to pull the front panel away from the chassis. It might be snug due to connectors or clips holding it in place. 5. If the panel still appears to be stuck in the middle, double-check for any screws that may have been missed or hidden. Make sure you have removed all the necessary screws to fully release the front panel. 6. If the front panel remains stuck, do not force it as it could potentially damage the device. Instead, consider consulting the user manual or contacting Behringer customer support for specific instructions or further assistance. Remember to exercise caution when working with electronic equipment and always refer to the manufacturer's instructions or seek professional assistance if you are unsure.
6/20/2023 7:09:13 PM • Behringer... • Answered on Jun 20, 2023
Behringer volume indicator LED lights 1622 and 1024 models
are your gain pots centered are they fully turned left?
11/20/2022 10:22:55 PM • Behringer... • Answered on Nov 20, 2022
Our new Behringer 2000 has stopped working. The green light doesn't come on when sound goes in microphone.
the green light is power indicator not mic level. the green light should come on when powered up. remove mike cable and the see if green light comes on, If it does power down and connect mike and cable (hopefully you have a good quality one and not a toy) Call Behringercustomer service. Where did you buy it from, if new it is under warranty and need to replaced with another new one. It is not an audio mixer the yellow and right lights are for clipping.
6/9/2022 2:46:07 PM • Behringer... • Answered on Jun 09, 2022
Behringer FCA202 - FireWire Audio Interface Sound Card Logo
24 questions posted
Top Behringer Computers & Internet Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Behringer Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Behringer Computers & Internet
Most Popular Question
driver installation problem
  • Computers & Internet
