20 Most Recent Amana 15.0 cu. ft. / 425 liter Upright Freezer Deepfreeze AFU1567A Questions & Answers
0answers
Ice keeps forming on the bottom of the freezer -
When a refrigerator leaks water like yours, it is common for the problem to be nothing more than a clogged defrost drain. When the unit defrosts itself, the frost melt water drips into a pan underneath the evaporator in the freezer, and goes through a tube from there to the bottom outside of the unit. Since the water cant go down this drain, it backs up on the freezer floor, then eventually the kitchen floor.
9/20/2014 12:24:25 PM • Amana 15.0 cu.... • Answered on Sep 20, 2014
Our freezer is about 7 or 8 years old. We went to
Hi, Remove the buzzer.
12/15/2010 7:37:24 PM • Amana 15.0 cu.... • Answered on Dec 15, 2010
I have Ice on the bottom shelf of the freezer.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
10/27/2010 1:47:07 AM • Amana 15.0 cu.... • Answered on Oct 27, 2010
Stopped working and is making
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
10/10/2010 8:25:41 PM • Amana 15.0 cu.... • Answered on Oct 10, 2010
My amana deep freeze just quit if i tap on the
The symptoms you describe are a locked compressor. A compressor replacement on a deep freezer is usually around $400.00
4/24/2010 10:35:46 PM • Amana 15.0 cu.... • Answered on Apr 24, 2010
My amana upright gets cool but not cold enough to freeze
Good day,
Somewhat handicapped not knowing if it's a conventional freezer or frost free.
1. If it's frost free check to see if the fan motor is running in the freezer compartment.
2. As well if it has a fan motor in the compressor compartment, see if it is running as well.
3. If it is a conventional model, make sure it is turned on and make sure it is running. If running, then it has lost it's refrigerant charge or the compressor has lost it's pumping capacity.
4. If it is item 3, then unless it's less then 5 years old, the sealed
system/compressor problem is so pricey that it's not a practical repair. If under 5 years Amana will pay for these repairs, whether it's conventional or frost free.
11/4/2009 2:54:09 AM • Amana 15.0 cu.... • Answered on Nov 04, 2009
Kenmore Deep Freeze
sounds like just the bulb is going bad . the neon bulb you have goes bad that way ,it flashes and blinks sometimes for years before it goes out all the way . it will not hurt anything
3/9/2009 9:08:53 PM • Amana 15.0 cu.... • Answered on Mar 09, 2009
2answers
Amana bottom freezer, all working OK, but very noisy freezer. How do I fix it?
There are a few potential causes of a noisy bottom freezer. Here are some things you can try to fix the problem:
  1. Check for frost buildup: Frost buildup can cause the freezer to become louder as it has to work harder to keep things frozen. To check for frost buildup, remove all items from the freezer and unplug the fridge. Then, use a hair dryer to melt any frost that has accumulated on the evaporator coils (usually located behind the back panel of the freezer).
  2. Check for loose parts: Some common sources of noise in a freezer are loose screws, washers, or other small parts. Check for any loose items and tighten them as needed.
  3. Check the evaporator fan: The evaporator fan is responsible for circulating air within the freezer. If the fan is not working properly, it can cause the freezer to become noisy. You can check the fan by removing the back panel of the freezer and listening for any unusual noises. If you suspect the fan is the problem, you may need to replace it.
  4. Check the compressor: The compressor is responsible for circulating refrigerant and cooling the freezer. If the compressor is malfunctioning, it can cause the freezer to become noisy. You can check the compressor by listening for any unusual noises or by checking the compressor with a multimeter. If you suspect the compressor is the problem, you may need to replace it.
If you are unable to fix the problem yourself, you may want to consider contacting a repair service. They will be able to diagnose and fix the issue more accurately.
1/4/2023 5:58:02 AM • Amana Freezers • Answered on Jan 04, 2023
AMANA UPRIGHT 11.8 Cu.Ft. deep freeze model# ESUF15HW. Only freeze at the bottom. food on top and middle shelves defrosted.
Check the seal. Close door on a piece of paper, see if seal grabs it
6/10/2019 1:36:58 PM • Amana Freezers • Answered on Jun 10, 2019
I have an amana refrigerator model #sxd22s2w. The
Seems like a clog somewhere calcium deposits
3/18/2019 9:15:43 AM • Amana Freezers • Answered on Mar 18, 2019
ISN'T GETTING COLD NEED TO KNOW HOW TO ADD FREON PLEASE ?
Unless you have a lot of expensive refrigeration tools and a license to recover and buy freon, then you need a serviceman.
12/21/2015 6:17:02 AM • Amana Freezers • Answered on Dec 21, 2015
Can i wire a universal start relay on a aqf2013tew 04
No if you did work for few month
12/2/2014 12:35:54 AM • Amana Freezers • Answered on Dec 02, 2014
Frost builts up in the coils
Frost will normally build up if you do not have frost free freezer and in which case it is possible the frost free system is faulty. If it is not frost free then it has to be defrosted a few times in a month. However if the frost comes up very quickly then there are possible causes. You may be having leakage from the door seals or there are items in the freezer that are not properly covered to avoid moisture escaping. Other possibility is that your freezer is set too cold and there are not many items in it.
8/18/2014 9:47:26 PM • Amana Freezers • Answered on Aug 18, 2014
Amana 15.0 cu. ft. / 425 liter Upright Freezer Deepfreeze AFU1567A Logo
16 questions posted
Top Amana Freezers Experts
ADMIN Andrew
ADMIN Andrew
goneforever.
Are you an Amana Freezer Expert? Answer questions, earn points and help others
View Most Popular
Amana Freezers
  • Amana Freezers
Most Popular Question
ice keeps forming bottom freezer
  • Freezers
