20 Most Recent SRT-35R Radar Detector Questions & Answers
I have a Whistler 35
All Whistler's that are not battery powered run on 12 volts with the center tip postive. You can order a power cord by calling 800-531-0004 or whistler's online store at www.whistlergroup.com.
2/23/2011 5:13:29 PM • SRT-35R Radar... • Answered on Feb 23, 2011
A friend gave me a
That model is not battery powered. It requires a 12 volt power cord connected to your lighter socket to operate. You can purchase a power cord at any electronic parts store or from Whistler by calling 800-531-0004.
10/6/2010 2:10:02 PM • SRT-35R Radar... • Answered on Oct 06, 2010
What are the intructioms for it
You can download the manual from Whistler's website - www.whistlergroup.com and click on the red button labled "MANUALS". Then click on additional models link and select your model.
9/24/2010 5:15:14 PM • SRT-35R Radar... • Answered on Sep 24, 2010
Power is there but no visual display
does the unit beep at all? Is the fuse ok in the units' power cord? Check these out. If the fuse is bad you can replace it with a 2 amp fuse from an auto parts store.
2/22/2010 8:41:20 PM • SRT-35R Radar... • Answered on Feb 22, 2010
The screen wont staylight lit but power from the
Check to see if the unit is in dim or dark mode
1/7/2010 10:59:46 PM • SRT-35R Radar... • Answered on Jan 07, 2010
Whistler 35R just quit. fuse and pwer cord is fine.
Orginal whistler power cords do not have LEDs lights in them and there is no electronics in the plug - 12 volts in, 12 volts out. Sounds like you have a bad cord or a cord that is meant for a GPS unit or other 5 volt device.
11/19/2008 3:38:25 PM • SRT-35R Radar... • Answered on Nov 19, 2008
Whistler35r ops manual
its the bracket release button - if you're talking about a button on the left side of the unit. This allows the unit to properly be removed from the windhsild bracket.
2/11/2008 9:04:28 PM • SRT-35R Radar... • Answered on Feb 11, 2008
Need help with 35R
checked the lighter socket fuse? Does anything else run ok on the lighter socket?
2/11/2008 8:38:07 PM • SRT-35R Radar... • Answered on Feb 11, 2008
Specs for whistler 975 power cord what's the output
Product detailsCar charger For Whistler 925 945 975 1125 1200 Series Radar Detector Power Cable Power Payless All products are new and fully-tested OEM equivalent replacement parts Input voltage: 100V ~ 240Vac 50/60 Hz Overload protection Short circuit protection Over Temperature protection Power Saver Protection 100% HI-POT tested 100% cycling burn-inContact us for any question before leaving none-5 star feedback.Specialty Service in Power Supply,Satisfaction guaranteed ! How much power does a dash cam usePlease note that this is a quality compatible adapter, picture is justfor reference. It may looks different from the physical adapter youreceived. Sometimes, we even will send you a brand name adapter that is compatible with the one advertised.Source Link:https://www.newegg.com/toplab-hrnbl-b07kdjxn9l/p/0FB-06J3-00046?Description=cr93,whistler&cm_re=cr93,whistler-_-0FB-06J3-00046-_-Product
11/14/2022 10:11:22 AM • Whistler Vehicle... • Answered on Nov 14, 2022
I need a whistler 1140 superwideband 2.6 Lazer manual
Model doesn't exist :>( https://whistlergroup.com/pages/user-guides
11/12/2022 6:14:36 AM • Whistler Vehicle... • Answered on Nov 12, 2022
I have a whistler ws101 it says call a number what's wrong and how do I make it work
U need arepair book from company. Haynes or Clymer publish them also. Checout Pinterest or utube first
10/12/2021 4:32:07 AM • Whistler Vehicle... • Answered on Oct 12, 2021
Whistler WS-1065
Whats the problem?
12/19/2020 4:38:53 PM • Whistler Vehicle... • Answered on Dec 19, 2020
How to perform a factory reset on whistler WS1025 scanner
Configuring Your Scanner
Preprogrammed Frequencies
Your scanner includes 153 preprogrammed frequencies, which you can load into Channels 1 to 153. For a list of these frequencies, see "Preprogrammed Frequency List" on page 23. To load the pregprogrammed frequencies: 1. Turn off the scanner and then turn it on again. 2. While WELCOME message appears, press PGM. 3. Load -Fr- appears, then YES--Ent and No -- CLEAr appear alternately. 4. Press ENT to load frequencies or CLEAR to cancel.
Programming Channels
If you do not have a list of frequencies in your area, refer to www.radioreference.com. 1. Press PGM. PGM appears. 2. Enter the channel number (1-200) where you want to store a frequency, then press PGM again. 3. Use the number keys and • to enter the frequency (including the decimal point), then press ENT. 4. To program the next channel in sequence, press PGM and repeat Step 3. To program a specific channel repeat Steps 2 and 3.. • Your scanner automatically rounds down to the closest valid frequency. For example, if you enter 151.473, your scanner rounds it to 151.470. • If Error appears and the scanner beeps three times when you press ENT, start again from Step 2. • If the frequency is already stored in another channel, the scanner beeps three times and displays -dUPL- (duplicate) and the lowest channel number where the frequency is already stored. Press TUNE/CLEAR to cancel. Press ENT if you still want to store the frequency.
1/27/2020 7:02:30 PM • Whistler Vehicle... • Answered on Jan 27, 2020
Whistler wbu 900 activation bypass S
Use the serial number from the device and contact customer relations. It worked for me.
7/11/2019 3:51:11 PM • Whistler Vehicle... • Answered on Jul 11, 2019
Whistler 1010 is a year old, it worked good till unplug now it does not come on like no power , I have a tester and i'm getting power but it does nothing why ?
check and see if there is a fuse in the plug on the end of the wire, sometimes when you unplug those the fuse can blow in them
4/15/2019 1:02:35 PM • Whistler Vehicle... • Answered on Apr 15, 2019
What's vg2 mean on 1530 Whistler
The VG-2 button is to engage VG-2 Cloaking Technology. From what I can see VG-2 Cloaking Technology is a way the detector has of avoiding being detected by authorities in areas where the use of radar detectors is prohibited. I am not in a position to say how effective this is, I suggest you refer to reviews. I have only researched the meaning of VG-2.Rider here: Please do your own research on the effectiveness of this technology on this - or any - detector.Of course the best way to avoid being picked up for speeding is not to speed. (But you knew that..)
3/6/2019 10:46:30 AM • Whistler Vehicle... • Answered on Mar 06, 2019
NEED CODES AND HOW TO SET A WHISTLER XRT 335
Some fixya user told me a website reliable-store it is very good.. I used it to repair my shredder it had some spark issue which wasn't easily fixed. you can go there and try free
1/23/2019 11:54:17 AM • Whistler Vehicle... • Answered on Jan 23, 2019
Planning on buying a trx2 Whistler , what web sightncan I find frequencies in zip code
looks like it's hard to get.. why don't u try online some websites deal in it real time.. along with solutions to problems how to repair fix service nd all let me know if u need some help in this
1/22/2019 11:43:06 AM • Whistler Vehicle... • Answered on Jan 22, 2019
SRT-35R Radar Detector Logo
Popular Tags
10 questions posted
Top Whistler Vehicle Parts & Accessories Experts
Ngoro
Arnie Burke
Arnie Burke
Are you a Whistler Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Whistler Vehicle Parts & Accessories
Most Popular Question
friend gave me
  • Vehicle Parts & Accessories
