20 Most Recent
Hannspree (K206-10U1-005) Television Questions & Answers
Hannspree tv is making a buzzing sound
First I am glad helped with the other issue.This issue needs to be defined: do you hear the buzz when sound is at zero? I not the issue is in audio circuit or signal to set----If you hear the buzz with sound off it is likely something in the set vibrating hard enough to make the noise.What causes this is a part that is not bad but noisy--there are ways to deal with this depending on set.My real concern is if set is opened etc it will void your warranty!If 5 days old most major stores will take it back or issue credit so you can replace the set----makers will often play a shell game--tell you it MUST go in for repair.Most major stores have an unwritten rule here: set can be returned within first 30 days and exchange/replaced for ANY reason.Seen ones returned because owner did not like the color of the cabinet etc.If I know what type of set it is (has a picture tube, LCD etc and you have no warranty I can tell you what to look for and a possible way to fix it---Don't void the warranty if you have one by just opening it.Saw a (will not call him stupid) person with a 1,000 set here yesterday which clearly had a problem and was 3 days old open the set and in doing so removed the labels there to indicate if someone has tampered with the set---now he has no warranty and a non working set.
11/15/2012 5:31:49 PM •
Hannspree...
Answered
on Nov 15, 2012
Universal code for the hanspree
Please check
here for information regarding Hannspree Universal Remote information. Basically, only the DirectTV Big Button remote has the Hannspree codes available.
9/25/2012 8:38:13 AM •
Hannspree...
Answered
on Sep 25, 2012
Volume off on some channels
Hi.
No sound on some channels only is quite unusual. If the TV is connected to an external receiver, then the problem is the external receiver box.
If you get the problem with TV connected directly to the aerial, then it is likely a faulty internal TV tuner.
In that case contact Hannspree at the number listed on the owners manual for repair.
See also:
Welcome to Hannspree
7/1/2012 11:49:10 PM •
Hannspree...
Answered
on Jul 01, 2012
My Hannspree TV volume goes
there's no faulty parts on your unit but sure that you have a dry joints on the sound amplifier section.
Look for a qualified technician to re-solder for a dry joint on the said section and it will fix the problem.
If you have knowledge in soldering then open the back panel of your tv.
Then observe first because you have to pull-out some connector from the main board.
Remember that anything you pull-out will be back to their position as you finished resoldering.
Try to trace the connectors of your speaker to the main board.
It is connected to ic which have a heat sink.That's the sound amplifier ic.
Find the cold solder around there then resolder it.
You can try the tv, if you hit the cold solder then intermittent sound will be cured.
Remember that before you try turning on the unit be sure that you returned the connectors to its original position. gud luck buddy...
Thanks for using fixya...
7/1/2012 11:46:57 PM •
Hannspree...
Answered
on Jul 01, 2012
Where are hannspree tvs made
Hi
There website isn't specific where there products are made but I would guess China. They have divisions all over the world.
10/24/2011 1:31:06 AM •
Hannspree...
Answered
on Oct 24, 2011
