20 Most Recent Xerox CopyCentre C128 Black and White Copier Questions & Answers
3answers
Photo copier c128 balck& white
That is an issue with the scanner.
1. When you turn the machine on, with the document feeder do you see the lamp coming on?
2. Shut the machine off and disconnect the cables from the scanner and document feeder, reconnect them and turn it back on.
If that is not it, A service call is the best thing to do, it is a calabration error in the scanner.
arrwup.gifDescription At the adjustment of CCD output after power on, CCD does not make a correct output which it should when it receives a specified amount of light.
arrwup.gifInitial Action
  • Refer to BSD 6.3.
  • Power OFF/ON
arrwup.gifProcedure Check the lamp, lens, mirror and the white correcting plate for abnormalities such as contamination and deterioration.
Abnormality such as contamination or deterioration of the lamp, lens, mirror or the white correcting plate is found.
2/9/2022 12:57:36 AM • Xerox CopyCentre... • Answered on Feb 09, 2022
2answers
Fault code 027-452
It's a fault relate with IP address. There is a PC which take the IP of Printer. Find this PC and turn off it in moment just restart Printer before restart PC
3/17/2021 9:44:14 AM • Xerox CopyCentre... • Answered on Mar 17, 2021
2answers
Fault code 047-211
There is a loose connection on the finisher. The fault code does not appear if the copy/print is delivered to the middle tray I think.
The code means that the "offset catch tray home sensor did not turn on in specified time". You may manually move the offset mechanism and see if it moves smoothly.
10/12/2018 5:20:18 AM • Xerox CopyCentre... • Answered on Oct 12, 2018
Error code 027-452 Please see user guide
A PC with the same IP address exists on the network.
arrwup.gif Procedure Inform the customer that the IP address of the machine is the same as the IP address of another machine on the network.
11/21/2017 7:25:13 AM • Xerox CopyCentre... • Answered on Nov 21, 2017
What is the solution to solve Error code 027 452
10/18/2016 5:18:33 AM • Xerox CopyCentre... • Answered on Oct 18, 2016
3answers
Error 010-327 workcentre 5230
machine show error code of 010-327. how to correct this error
7/7/2015 4:59:41 AM • Xerox CopyCentre... • Answered on Jul 07, 2015
Erorr code 10-327
reset ur fuser module press 0 and hold for 5 second than press start button enter passcode 6789 and press confirm press machine status and press tools on touch screen press maintenance and diagnostics nvm read /write type chainlink 744-220 enter new value 0 and save after close the log restart ur machine
12/6/2014 12:43:37 PM • Xerox CopyCentre... • Answered on Dec 06, 2014
Xerox 4595 error code 062-380
Platen AOC Failure. Power off completely and then power back on. If the problem persists please Call for Service.
7/14/2014 5:11:05 PM • Xerox CopyCentre... • Answered on Jul 14, 2014
0answers
0answers
0answers
0answers
I have put the cartridge, a brand new one, and it
there is a toner counter chip for 128 .check if u have replaced with new one that it might have been out of position.if possible call a rep as it is a bit tricky
9/15/2011 3:24:40 PM • Xerox CopyCentre... • Answered on Sep 15, 2011
Xerox CopyCentre C128 Black and White Copier Logo
52 questions posted
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Xerox Office Equipment & Supplies
Most Popular Question
fault code 047 211
  • Office Equipment & Supplies
