20 Most Recent
Cuisinart CBK-200 Bread Maker Questions & Answers
Our bread maker doesn't heat
Contact
[email protected] for a service center near you.
Otherwise, try to reboot your breadmaker's computer by plugging it in then pressing and holding the
Stop/Pause button down
for at least 3 seconds.
Hope this helped. ;)
4/23/2023 9:00:16 PM •
Cuisinart...
Answered
on Apr 23, 2023
Cuisinart CBK-200 won't heat at all
Try replacing the small transistor 9013 on the lower circuit board. On the circuit it will say heater near certain wires and there will be a big black box relay that turns the heater on and off. I got my transistors from fairchild semiconductor. The circuits are below the control panel on the right hand side.
4/23/2023 8:45:50 PM •
Cuisinart...
Answered
on Apr 23, 2023
I can't get the Menu to change from 1 to anything else.
Hold in the stop/pause button for about 15 seconds - it will reset the breadmaker. Then you should be able to make your selections. Unplugging the breadmaker for longer than 15 minutes will also reset it.
-Tha Mp3 Doctor
2/25/2023 8:24:30 PM •
Cuisinart...
Answered
on Feb 25, 2023
Can't remove the bread pan
The same thing happened to me yesterday. I made my first loaf and then I couldn't get the bread pan out. We kept pulling and yanking on the bread pan until it felt like it was going to break! This morning, my husband called Cuisinart. The man on the phone said he has the same machine at home, and that you just have to pull it really hard. He said don't worry, it won't break, just pull it. My husband pulled it again and it came out. I guess he just got the right angle on it.
It was definitely stuck from the bottom, not from the side clamp things. The man on the phone at Cuisinart said that after you use it more, it becomes easier to remove the bread pan. We put the bread pan in and then pulled it out a few times, and it seems like now it comes out easily, the way it should.
I felt obliged to respond here, because I was very discouraged after reading this thread last night. I was about to return the machine. I hope this solution helps.
By the way, my first loaf yesterday was the Rosemary Bread from the cookbook that comes with the machine. It was AMAZING.
11/18/2021 7:54:28 PM •
Cuisinart...
Answered
on Nov 18, 2021
My new cuisinart breadmaker has
Hmmm... I'm back again. My machine still smells terrible! I live in a relatively small, open plan apartment and this bread machine is smelling up the place. I am very unhappy with this because I am otherwise pleased with the bread it makes.
I removed the bottom plate to see what is causing the smell. I have NO doubt whatsoever that the problem is the rubber belt, which I believe controls the kneading paddle. I've taken to leaving it outside to air but am stumped for a permanent resolution.
Any remedies for stinky rubber that I've come across involve liquids, heat or powders etc.. just things in general that wouldn't be prudent near the electrical panel, as well as not wanting to take the risk of damaging the machine and having it stop working altogether.
I got it at Costco in January, no hope of returning it there. Has anyone contacted Cuisinart about this? I wonder if they are aware of the issue if it seems to be widespread. I am in Ontario.
What happened with the B&D? Did the problem ever resolve? Irony is that I had returned a smelly B&D in order to get the Cuisniart! Same problem, but IMO I think it was worse with the B&D and the Cuisinart is a better machine over all (if it didn't smell so bad!)
1/1/2021 6:09:44 AM •
Cuisinart...
Answered
on Jan 01, 2021
The liquid leaks from the shaft of the bread pan.
Hi...The paddle shaft fits tightly on a sealed bearing. This allows the shaft to spin freely. Over time the sealed bearing wears out, the shaft gets loose and liquid will leak through. Unfortunately there is no fix for this and a new bread pan is needed. sorry...Hank
11/20/2020 1:54:29 PM •
Cuisinart...
Answered
on Nov 20, 2020
My Cuisinart bread maker CBK200 doesn't knead bread properly and has to be paused and resumed every few minutes.
Are you reading the instructions correctly? No bread maker kneads for 1 hour and 30 mins.as you say.
Normally the bread will knead, then sit for up to 20 mins, then continue mixing. then rising then a pause and the a small secondary knead, then rise again. Have you actually just put in the ingredients and left it to itself? If not. Put in the ingredients. Press settings and walk away. If the bread is done then you were perhaps a little too anxious. If it isn't then you know it needs servicing. Good luck.
7/11/2019 7:19:36 PM •
Cuisinart...
Answered
on Jul 11, 2019
The machine stops kneading in the middle of the program
Even Replacement May Not Help for Long.
After my six month old CBK200 had the same stop and start malfunction I was sent a brand new replacement by the company. Three months later the new unit started doing the same thing. I am putting up with it for now, but as soon as I have a little more time, I will go back to the authorized repair depot and request another replacement and hope for the best.
6/17/2019 9:14:28 PM •
Cuisinart...
Answered
on Jun 17, 2019
Why does bread deflate?
See if the paddle shaft in the bottom of the pan is frozen. If it is, free it up manually. Then get it good and dry and oil it with cooking oil. After that, every time you bake, put the oil for the recipe in first and turn the paddle until it moves freely. Once the oil is in the bearing, it will keep the water out and the machine will move properly. I have gotten away with this fix for hundreds of loaves.
6/7/2017 4:44:22 PM •
Cuisinart...
Answered
on Jun 07, 2017
How do i tighten the belt for the paddle?
It's a timing belt, so it isn't supposed to stretch. There is no tension adjustment that I can see. Are the 4 motor screws in place and tight? Is either the motor or the kneading paddle drive shaft turning in its drive wheel? Is the frame bent and causing the belt to walk off one of the pullies? Another problem can be that the bearing in the pan won't turn, then you'll get a loud bump as the drive mechanism tries to turn the paddle in the pan. If this happens, try to free up the paddle by hand so it turns. Then when you bake, always put the oil in the recipe in first and rotate the paddle a few turns to work the oil into the pan bearing. If the oil gets in first, it will keep the water out and the pan will work fine. I've been getting away with this approach for hundreds of loaves.
6/7/2017 4:38:04 PM •
Cuisinart...
Answered
on Jun 07, 2017
I need advise how to remove the machines cover and get access to the driving belt. Alternatively please give me the link for a service/repair manual
There are three exposed screws on the bottom of the machine that can be removed with a Phillips screwdriver. You also need to remove two of the four rubber feet with a Phillips screwdriver. The other two rubber feet also need to be removed, but they have some kind of specialty screw that needs a split-head screwdriver. I just removed them by twisting the entire foot with a pair of pliers. Then the panel pops off fairly easily, and there's the belt. As an aside, the drive belt on mine kept coming off, and just putting it back on didn't help because it would just fall off again. It turned out that the whole bottom of the machine was bent, so the motor gear wasn't lining up with the drive gear. Not sure if this is fixable.
10/15/2016 3:11:36 PM •
Cuisinart...
Answered
on Oct 15, 2016
My cuisinart bread maker is making a clicking
If the motor shaft is not turning it could be the belt has fallen off the pulley or the pulley is slipping, or the motor is broken. The motor, pulley and belts are located inside the base of the machine. Hopefully it's just a loose belt. Hank
12/16/2015 2:16:20 AM •
Cuisinart...
Answered
on Dec 16, 2015
