20 Most Recent Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Questions & Answers
3answers
Bios setup for MacBook?
Command Button(the one with the apple logo) + Option + F + 0 when it boots
5/13/2022 3:51:33 PM • Apple MacBook... • Answered on May 13, 2022
13answers
Import Outlook 2011 olm files in Mac Mail
An application on apple store might be helpful, please have a look:-https://itunes.apple.com/us/app/olm-converter-pro-apped/id522796199?mt=12 Thanks
5/5/2022 12:30:17 PM • Apple MacBook... • Answered on May 05, 2022
3answers
Slow mac computer
Generally, there are a couple of reasons that may cause a Mac computer running slow, but generally two factors: hardware part & system part. For hardware part: I guess it's OK if your Mac is not that old. For system part: there might be a lot of junk files, caches, registry errors... out there which largely slow down any Mac machines. about 80% slow Mac caused by this reason, if so, try cleaning the system. Learn more here: http://www.howtospeedupmac.com/
12/16/2020 12:23:09 PM • Apple MacBook... • Answered on Dec 16, 2020
2answers
Will not start up, has a flashing folder with a question mark
This means that your internal hard drive is not currently bootable. That can happen for a variety of reasons, which are:
  1. The disk has crashed and is no longer usable.
  2. The Mac OS X System Folder has become damaged due to permission problems, a botched software upgrade, or some other software-caused problem.
  3. The hard drive controller on your Mac's logicboard has failed.
Without knowing the model of your Mac, I can only guess what is going on here. To know for sure, you need to locate your original Apple software restore CD/DVD -or- a retail Mac OS X install DVD.
Do the following:
  1. Power on the Mac, insert the bootable CD/DVD.
  2. Hold down the power button until the mac turns off.
  3. Hold down the "C" key on the keyboard and press the power button to turn the unit on.
  4. It will take a while, but your Mac should start booting a copy of Mac OS X off of the CD/DVD.
  5. Once booted into the Installer, locate the menubar at the top of the screen. Click on the "Apple" icon (top left of screen) and click "About this Mac". Click the "More Info..." button.
  6. You should now see the Apple System Profiler.
  7. On the left panel, locate "ATA" or "Serial-ATA". You should have one of them contained within your Mac. When you click on the correct one, you should see the list of hard drive controllers (two), one with your CD/DVD rom listed, and the other with your hard drive listed underneath. If you don't see two controllers, one or both of your hard drive controllers have failed and you need to send the Mac to Apple for hardware repair.
  8. If you DO see your hard drive listed, then you hardware is at least working. That rules out a failed hard drive controller and mostly likely your hard drive is physically intact. The software on it might still be wrecked, but the hardware appears to work.
  9. Close "System Profiler" and get back to the MacOS X Installer. Click on the "Tools" or "Utilities" on the top of the menu bar. Locate "Disk Utility" and launch it.
  10. Within Disk Utility, locate your hard drive on the left side of the screen, click on it once to highlight it and then click the button "Verify Disk". This will do an exhaustive search against your drive to see if there are any problems with the Mac OS X installation. If there is still a copy of Mac OS X left to salvage, this will tell what the problem is.
  11. If "Verify Disk" finds an instance of Mac OS X with problems, you can try running "Repair Disk" and then "Repair Disk Permissions" to clean up any problems with the copy of Mac OS X. Keep in mind, when you have filesystem problems, sometimes fixing the problems can make permanent changes to your filesystem that have unintended consequences.
At this point, if your hardware is intact and you have a filesystem problem, the safest thing to do is to go find a firewire drive big enough to install a copy of Mac OS X on it (anything larger than 10GB should be fine), install Mac OS X to the firewire drive and then try to mount your internal hard drive while running from Mac OS X on the firewire drive. This assumes that you have files on the internal drive that you don't want to lose. If this is not the case, you can safely reinstall Mac OS X on your internal drive and start over again.
12/7/2020 11:31:33 AM • Apple MacBook... • Answered on Dec 07, 2020
2answers
Is there an application (for Mac' Leopard) to change region code?
You can 'flash' the Firmware of the drive.
or
buy a Mac-compatible external DVD Burner.
They are Region-Free and you dont have to mess with your mac
3/4/2020 2:01:32 AM • Apple MacBook... • Answered on Mar 04, 2020
3answers
How do i change my Apple ID
According to Apple you couldn't change the ID that ends with @icloud.com, @me.com, or @mac.com. for changing Apple Id follow :
  • Go to My Apple ID https://appleid.apple.com/
  • Click on Manage your Apple ID.
  • and Sign In
  • Select Edit next to Apple ID and change it.
  • Enter the email address to use as your Apple ID for verification Mail
  • Click Verify Now with given mail.
  • and Sign in with your renamed Apple ID. if still need any help then follow Apple ID Support .
1/23/2020 9:24:43 PM • Apple MacBook... • Answered on Jan 23, 2020
2answers
I accidentally set my mac 5.2 dvd drive region to
Easiest way is to put in a region DVD you want to switch to, and DVD Player will prompt you to change. Don't worry it will warn you that you have x number of changes before it becomes permanent.
11/12/2019 7:09:50 AM • Apple MacBook... • Answered on Nov 12, 2019
2answers
My macbook is not recognising/reading a disc and I
I think you can work the CD out with a piece of cardboard , but be very careful!
5/8/2019 2:50:57 AM • Apple MacBook... • Answered on May 08, 2019
2answers
Dvd drive wont work on macbook pro
Try this article, if you mean that it wont read your dvd..... Mac Forums "DVD not working"
5/8/2019 2:41:22 AM • Apple MacBook... • Answered on May 08, 2019
2answers
My computer keeps telling me that my startup disk
If you have a lot of video podcasts in your iTunes they take a lot of space on your hard drive. delete the one you don't want and make sure the empty the trash can.
Try a piece of software called "Disk Inventory X"
Disk Inventory X is a disk usage utility for Mac OS X 10.3 (and later). It shows the sizes of files and folders in a special graphical way called "treemaps".
If you've ever wondered where all your disk space has gone, Disk Inventory X will help you to answer this question.
1/25/2019 3:51:40 AM • Apple MacBook... • Answered on Jan 25, 2019
2answers
Mac book starts with blue screen startup disk full
your disk partition is having problem.if u have not taken backup then boot the system with FW mode with saperate Laptop and backup the data,then repartition the hdd and install freshly
1/25/2019 3:48:26 AM • Apple MacBook... • Answered on Jan 25, 2019
5answers
How do i turn off the dos mode on my mac
The quickest way to get out of DOS is to hold down the power key until the computer shuts off. Then during restart, hold down the option key until the drives icons appear on screen. Use the arrow keys to select your OS for start up and away you go..
K
8/18/2018 11:46:59 AM • Apple MacBook... • Answered on Aug 18, 2018
4answers
Mac DVD Ripping
Please also feel free to read this article about top 5 DVD rippers for ripping DVDs. The guide introduces some good apps to help you rip DVDs on your Mac for free. mac-dvd-ripping-oxaxc0rwhkhzilrwacqreyis-5-0.jpg http://www.leawo.org/tutorial/top-5-best-free-dvd-rippers.htm
6/13/2018 1:39:48 AM • Apple MacBook... • Answered on Jun 13, 2018
3answers
I have a new Apple Mac and am unable to access my
Detailed instructions for setting up Apple Mail to access Hotmail (now "Windows Live Mail" are here:
http://tinyurl.com/bdjzhm
4/18/2018 8:23:05 AM • Apple MacBook... • Answered on Apr 18, 2018
4answers
Macbook wont turn on
My computer used to do the same thing, I found out it was my motherboard / logic board and a hardrive combination. end cost $1500..so i bought a new Laptop. Go and get those things tested.
2/21/2018 10:19:48 AM • Apple MacBook... • Answered on Feb 21, 2018
2answers
I accidentally deleted my pictures from peru ,how can i retrieve them back?
GT Recovery for Windows Download: www.gtrecovery.net GT Recovery for Windows is a professional data recovery for PC. It can restore deleted photos, videos, audios, documents from PC Disk and USB storage. So if you want to recover your deleted photos from on your Computer. Claim it here. This video will show you the function to recover deleted photos.
7/4/2017 1:38:25 PM • Apple MacBook... • Answered on Jul 04, 2017
2answers
FIFA not working with Vista
download a crack form sites. go to google write crack : fifa 09 and press enter it will gave you crack then check for vista version it should help you. rate it plz
1/10/2017 5:14:40 AM • Apple MacBook... • Answered on Jan 10, 2017
Play movie ???
Can you please explain your problem with some extra words that states your Mac issue.
Thank you, Apple Care Technical Support
New Apple iPhone 3G Coming This Friday July 11!
12/1/2016 12:27:26 PM • Apple MacBook... • Answered on Dec 01, 2016
3answers
Java and Runescape??? HELP!!!!!!!
Usually, before starting up the game, when starting Java, there will be a notification asking if you trust the java applet. You must click Trust for Runescape to work.
10/20/2016 2:55:19 AM • Apple MacBook... • Answered on Oct 20, 2016
4answers
Runescape? No java? what?!
You may need to upgrade java.
java.com/en/download/manual.jsp
10/17/2016 3:30:20 AM • Apple MacBook... • Answered on Oct 17, 2016
Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
946 questions posted
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Apple Computers & Internet
Most Popular Question
slow mac computer
  • Computers & Internet
