20 Most Recent
Acer Aspire L100 PC Desktop Questions & Answers
Restore factory settings
what i would do is go into dos. If you cant get into dos find a windows 98 setup disk 3.5" this will have the dos files that will allow the computer to reconize a generic cd rom. This should allow you to get your recovery disk working. Your software problem could of created a firmware problem also. Not reconizing the cd rom. This solution will provide the basics to get your cd rom loading the recovery disk for you. If you have questions or more problems feel free to contact me and i will take you through it step by step
I have a disk error how do i fix it?
Could be the HDD or even just the boot sector itself. Basically, it's not able to read the Operating System Boot...or it got damaged somehow. If you have a disc for the exact version that is on the system, you may be able to fix it through the Advanced Options using the command prompt. (bootrec.exe /fixboot /fixmbr /scanos /rebuildbcd)
Acer L100 connecting to tv with hdmi
Try adjusting the screen resolution by right clicking on an open spot, going to properties and clicking on settings. Change the screen resolution to 1024x768 or better.
Hi, I am trying to
You can download the windows installation from the Microsoft website, and run it. Select the Custom Install option to run a Clean Install and select to Reformat the drive, this would clean the drive and reinstall windows, which would reset everything to the factory settings.
That's an alternate route to go if the recovery software on your computer is not functioning properly.
Hope this helps!
Can anyone advise what might be wrong with my
I am assuming you weren't plugged into a surge protector when you lost power. During power outages, spikes in voltage occur, so what happens is there's no mechanism to interrupt that spike by grounding, which surge protectors are designed to do. Any laptop/computer components cannot handle this voltage spike as they are delicate to certain voltage tolerances. I hate to say it, but your laptop is toast.
My tower will not turn on
It sounds as if your power supply is having issues, I would recommend replacing it. If your good with computers, you can test the power supply:
1. Open the computer tower.
2. Find the main plug which runs from the power supply to the motherboard.
3. There should be 16 wires.
4. Find the green wire, short it to the black wire with a paper clip.
5. If the computer seems to turn on, its your motherboard having issues and you will probably need a new computer. If it does not turn on, your power supply has failed, and you need to replace it.
I hope this helps!
Acer L100 Overheats
You will need to ser your pc . The CPU needs new thermal past every 3 months and then you will have to make sure all the fans are working properly. All fans can be fixt with q20 oil . If thy still don't work after that then you will have to replace them. Add me on facebook Nic fourie for a complete guide on how to service. Your own pc
Why does Acer l100 PC shut down?
You need to service you pc ar laptop. The cpu needs to get new thermal compound every 3 to 6 month's add me on facebook Nic fourie for complete guide to how the service your own pc or laptop
Acer aspire l100 will not boot but fans run
Try removing/disconnecting the hard drive and see if the BIOS boots up, if it does the HDD is causing the problem. Are you getting any beeping codes on start up, if so how many and hoe long in between?
Desktop pc
could be all manner of things, from just the graphics card, to the PSU or even the CPU, itself,
I would start trying to test the graphics card (may just need reseating)
and then test the PSU, then take it from there
Why after i download an app onmy tablet i can't get a short cut
Go to the play store and search for the app. If it is installed, youshould see an 'open' button. If you click it, you wil start the app. After that, you just need to add a shortcut:
http://droidlessons.com/how-to-add-or-remove-app-shortcuts-from-the-android-home-screen/
The computer will not boot into normal mode
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
AL100 wont turn on
You are plugged into the DC adaptor. Have you checked the mains wall power is working and if your DC adaptor is working? May need a tech with a multi meter. Also there is a fuse on the motherboard, but thats getting tricky
