20 Most Recent
Amana 24 in. ADB1200AW Built-In Dishwasher Questions & Answers
Amana ADB1200AWQ model dishwasher, built -in, bought replacement part for broken door lock handle. Any idea as to steps to replace it?
Just replace my door latch handle for the 4th time in 6 years. its very easy,,, you have the same as i do. latch and handle assembly i got from amana parts on the internet, # for part is W10130697. it is the same i think as a whirlpool part. call 877-827-5003 to order about 48 bucks. very easy to fix. Open dishwasher door and take out the tork screws ,you will see the latch with the 2 micro swithes on both sides, black on the right and white wires on the left. pull off the plugs , put the new door latch assembly in place and put the two plug bacl on micro switches, put back in all the tork scews and your set to go.... good luck... it is real easy.
WATER spinklers inside are not
Hello, answersfound
I was trying to help
you out here. I was going back to some customers that asked questions
in the past and it appeared that no one answered them, so I thought I
would take some of my personal time to see if I can help. Here is a link
to about everything you want to know about your dishwasher, from repair
to trouble shooting it,pictures, video's. Just scroll around and you
will see tons of information to almost any question you might have on
your dishwasher. If you go to this link and click around, I am sure you
will find out so much about your dishwasher, you will know more that the
company that made it. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time
to rate my help and some kind words written would be appreciated for my
free help , I would appreciate it. Here is also my direct link to my own
pages of other areas of my expertise for other problems you might have
in Automotive,Appliance, and Electronics. Drop In anytime for my help.
Thanks,Mike
http://beta.fixya.com/users/mc1bean
Dishwater will not fill...no water. Used to work
Not cleanable.Must replace.But check them first. They don/'t fail very often. Also check the obvious.Someone might have shut water off. Check for voltage at the fill solonoid .If voltage available then replace. If no voltage , Check ,door switch and,waterlevel switch. If ok, look at timer or controller.
Was this helpful?
My mugs and dishes are not coming out that clean
Try this first..
Go to your local Walmart and purchase a bottle of dishwasher magic.Follw the instructions on the bottle to clean the machine. in some cases this may take several attempts to clean out all of the hard water deposits...
Then use a product called Lemishine (about 1/2 full in the main wash receptacle and other half detergent) with a good powdered detergent this solves this problem 90% of the time.
If this does not help then further investigation would be required. Look for broken or damaged spray arms or anything the may be causing improper water flow.
Sandy grit left on dishes.
I was having a different issue with the same model but I think my issues solution might help yours. My dishwasher was not draining properly. It was the air gap that sits on top of the counter by the sink. It was clogged. We removed it and cleaned it out. Maybe if your air gap is slightly clogged as well it is not allowing the dirty water to flow out properly leaving you with gritty dishes. Hope this helps.
Grinding noise in amana dishwasher
From what I understand, when it grinds, something has fallen into the filter at the bottom of the dishwasher. If you can, look in the filter and see if anything is in there. Eventually, it should stop once the dishwasher has ground up what may/may not be in there. Hope this helps.
Water in tub bottom
You might put that disconnected hose into a bucket at the end of a cycle and observe the flow strength or quantity; you may have a pump whose internal seals or blades are worn and not pumping with enough speed to finish before the timer shuts it off.
I've ordered the parts to repair the latch on my
here is a web address to link you to it just happens to have a manual online here at www.fixya.com The link is posted below hope this works for you
http://www.fixya.com/support/p51530-amana_24_in_adb1200aw_built_in/manual-1748
