20 Most Recent
JVC HD-61G787 61" Television Questions & Answers
My screen has a green tint that will not adjust out ?????
The light engine on this TV uses a 3 lens DLP system. You probably have a section of the DLP engine that is dirty or going bad. I have one that is overly yellow the way yours is green. I tried to clean it out, that helped but did not cure the problem. The actual DLP lenses are nearly impossible to get to. That is a good thing because they are very fragile, too! It is watchable but not perfect. Life is hard... with the age of these TV's watch classified ads or Craigslist. Sometimes you can find them for a very low price or even free! They are very easy to work on and really a pretty good tv with working correctly.
How do I remove the screen from a JVC HD-61G787?
May I ask why you need to remove the screen? There are a lot of screws around the back and along the bottom of the front after the speaker grill is removed. you will have to unplug the control panel before you remove the screen assembly....tks
Lamp button flashes on and off
Suspect set has a bad lamp---light is there to indicate lamp or something associated with it has failed.Lamp life varies but is usually 2,000 hours or 2 years average use.
I have audio cables going from HD 61g887 jvc tv,
hi
you didn't mentioned the model number of your surround sound system, for a better solution its important. any why try the following.
if you are connected the analog audio output of your tv to the system using RCA cable, then go to the setup of the surround sound system and change the input assignment setting from digital to analog.
If your connected the digital output of your tv to the digital input of your surround system using optical cable then, goto the setup of your surround system and change the input assignment to digital (optical) input.
if u need any further assistance fell free to contact through fixya
AFTER REPLACING LAMP THE LAMP LIGHT IS STILL
Look in the manual under "resetting the lamp timer"
This must be done with most any replacement
Browse to:
http://www.retrevo.com/r/391dj496/48/Lamp+Timer+Reset#q=JVC+HD-61G787
On that page is the (lower) is the exact procedure on resetting the lamp timer. You can also down the entire manual in PDF format.
Cheers
Is there a way to clean the inside of the front
Not without removing most of the chassis. I am wondering if what you think is dirt is actually screen deterioration. One has to be carefull cleaning even the outside of the screen, except with a damp and then dry soft cloth. The inside of the screen is even more delicate and any pressure can rupture it easily and replacement is astronomical
pleae rate my help++++Thanks for using FIXYA
Cant program digital channels.
Nothing. Digital Tuners Broke. I wouldn't be suprised if your TV freezes up momentarily (or for a long time) when you switch over to the Digital Channels.
This TV has 1 tuner for analog channels and 1 tuner for digital channels. You can probably find the Digital Tuner on Ebay and replace it.
Im not getting my video
You cannot do a factory reset. If the HDMI doesn't work because it was deactivated or something
1. press "sleep" on remote so that "sleep 0" is displayed
2. press "video status" and "Display" simultaneously
3. You should be in the Service Menu
4. go to "self check"...i think it is #3
5. press the "power" button on the remote
6. unplug TV and wait 5 seconds to plug it back in
7. check to see if it worked
This reactivates the HDMI input if it gets deactivated. Also, make sure you got the PS3 setup right. Set it to Auto....I don't think this TV does 1080P so don't expect it. I know it can't do 1080p/24 which is what the PS3 puts out with some 1080p movies.
Screen
The part # is 61SC-006A-M2 with a cost of around $439.99 with free shipping.This will include all 3 screens. 1-866-925-PART (7278)
My tv screen is green
there is a code to reset the HDMI video, i think it is--hit Display on the remote, then sleep timer and video statice at the same time, then the number 2, then turn the tv off, after it shuts down all the way, turn it back on, should take care of it
JVC HD-61G787 IR receiver location
I took the front of the tv off. the IR receiver is beside the lens. I stuck the IR emitter directly on the receiver and reinforced it with hot glue and then fed the cable out through the back off the tv. Not a hard job just lots of screws.
JVC 43" (109cm) HD Ready Plasma TV PD43N30A. Chunghop universal remote codes for JVC pd43n30a
Question edited for a lot more clarity, plus
Chunghop not chungCHOP :>D
JVC: 089, 161, 909
CHUNGHOP Universal Remote Control Codes
codesforuniversalremotes.com
https://codesforuniversalremotes.com > chunghop-univer...
Jul 25, 2019 -
CHUNGHOP Universal Remote Control Codes ; Aiwa: 009, 057, 058 ; Samsung: 618, 619, 620, 621 ; Philips: 013, 023, 024 ; Hisense: 676, 677, 707, 898
