20 Most Recent Celestron NexStar 5 SE (300 x 44.45mm) Telescope Questions & Answers
I am unable to illuminate my Hand Control, either
Get a new hand controller cable. They fail regularly. If it still does not work then it is a problem with the hand controller or the internal circuit board.
If after you replace the cable it still does not light up-- borrow a hand controller and see if it works with a different controller. Beyond that you must return the scope to Celestron for repair.
10/6/2010 9:48:49 PM • Celestron... • Answered on Oct 06, 2010
New batteries put in....It doesn't power up
Are you SURE you installed the batteries correctly? I once installed them with ONE battery reversed. !
Jiggle the cable to the hand controller, you might just have a bad cable. You can buy a new one from Celestron.
If you can get a 12 volt power pack and the proper power cable or the 110 volt power pack-- try it on direct power. If this is a new scope I would return it to the deal if these simple fixes do not work.
4/10/2010 1:22:59 AM • Celestron... • Answered on Apr 10, 2010
Just got a celestron nextstar 5
You are NOT in focus. You are seeing the central obstruction in the lens on the front of the tube. Put the eyepiece with the largest number written on it into the telescope. Go outside during the daytime and practice focusing on a distant object.
Once you are focused properly you can see the obstruction.
Read my GOTO scope TIps on my profile page.
4/8/2010 6:40:30 PM • Celestron... • Answered on Apr 08, 2010
The pointer don't works, don't turn on. Where
This has a battery inside -- replace the battery. If the actual ON OFF switch is broken it's not worth fixing. You can buy a new one here--
http://www.telescope.com/control/accessories/telescope-finder-scopes/orion-ez-finder-II-telescope-reflex-sight
3/8/2010 3:29:22 PM • Celestron... • Answered on Mar 08, 2010
I have a celestron nexstar 5 the begins to move on it own
Many times a bad cable will cause this. Also low batteries can cause this.
Contact Celestron and order a new cable. Use an external 12 volt power pack.
http://www.celestron.com/c3/page.php?PageID=37
11/6/2009 2:29:44 PM • Celestron... • Answered on Nov 06, 2009
The azimuth adjustment keys don't work
Send it back along with the hand controller describing the problem. Could be several things including a bad hand controller. If there is a local astronomy shop nearby take the scope there and ask to try one of the hand controllers in the shop and test it. If it now works you just need to buy another hand controller.
Otherwise send it in for repair
7/5/2009 1:43:07 AM • Celestron... • Answered on Jul 05, 2009
2answers
Black spot in the center of the image viewed in telescope
If this is a Newtonian reflector or a catadioptric scope (Schmidt Cassegrain or Maksutov) you may be trying to use it at too low of a magnification. Your magnification needs to be high enough that the exit pupil is less than 5 mm; to figure this divide the focal length of the eyepiece by the f-ratio of the optical tube. If this quotient is 5 mm or more the black spot you are seeing is the shadow of the secondary mirror.
1/29/2009 4:52:09 PM • Celestron... • Answered on Jan 29, 2009
2answers
Focus knob turns but nothing moves
The Celestron manual for this scope has nothing to say, but on the underside of the focuser assembly, between the 2 focus knobs, you may see 2 screws.They might be thumbscrews or some other screwhead type. One is the adjustment for the focuser internal clearance, or looseness, and the other is a focus travel lock.If present, try backing both off 1/2 turn from tightness, and then experiment to see which is which. The focus lock will have no effect until tight, when the focuser will cease moving, as is now. The other screw will gradually remove looseness and rattle from the focuser until it just moves smoothly, with no back and forth loose feeling at the knob.If neither of these screws is visible you will have to take it to a binocular and telescope shop, where they should not charge much.
12/7/2021 2:09:26 AM • Celestron Optics • Answered on Dec 07, 2021
How to clean Celestron binoculars 15x70 lenses inside?
topbestjob.com
9/15/2020 3:08:57 PM • Celestron Optics • Answered on Sep 15, 2020
Battery size telescope celestron 114
Why not look at the old battery, or look in the manual ?
11/28/2019 12:20:02 PM • Celestron Optics • Answered on Nov 28, 2019
What is the weight of the celestron next star se 8
It is impossible to assess the weight (or more correctly Mass of a star, as weight is a perceived function of Earth's gravity) without knowing the chemical make up of the star. That is why astronomers use the star's measured albedo to qualify and quantify them.
9/16/2019 6:23:17 PM • Celestron Optics • Answered on Sep 16, 2019
How to use a celestron powerseeker 127EQ
Read the manual. Follow the instructions therein.
6/13/2019 9:27:53 PM • Celestron Optics • Answered on Jun 13, 2019
Hello i have a celestron astro fi telescope and it will not align correctly it seems to point to the ground even when the app is showing the night sky ?? can you tell me what i am doing wrong
You may find you have to aim it at the sky yourself - sounds as if the calibration may be 180 degrees out
12/12/2018 10:52:29 PM • Celestron Optics • Answered on Dec 12, 2018
0answers
Celestron NexStar 5 SE (300 x 44.45mm) Telescope Logo
8 questions posted
Top Celestron Optics Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a Celestron Optic Expert? Answer questions, earn points and help others
View Most Popular
Celestron Optics
  • Celestron Optics
Most Popular Question
new batteries put in doesnt power up
  • Optics
