20 Most Recent
Numark ttUSB Turntable Questions & Answers
The plate on my numark tt USB is wobbiling
I find it hard to believe some of these answers. If the platter is wobbling, if you remove the platter, you'll find the spindle the platter rotates on. That will probably be loose. At the bottom of the spindle bearing, you will find a nut. Tighten that, and you should be in business. If you have further questions please visit my website at audioserviceclinic.com. You may contact me there.
High pitch noises.
It sounds like feedback hum. Most likely caused by the settings on your computer. Try adjusting all the sound settings. Especially record settings.
I've connected my turntable to
is the vinyl clean vinyl is supposed to sound weird thats what its all about. if the records not clean it could make it sound ****
How do I turn the volume up?
As it is a USB turntable it presumably connected via a computer. So the answer (if that is the case) is in the audio system of your computer. There should be an input control in it for the USB connection of your turntable. Adjusting that will increase the volume.
I cant get sound from my turntable. How do you hook it up?
As long as you can hear the record playing in the groove of a record, by ear, then the problem is that the connection to your computer is wrong. Since this is a USB turntable it will have to plug into a USB port. So you need to check that you have connected to the right type of USB port. That the port is working. See Control Panel on a Windows Machine. That the signal level from the port is set high enough and that it isn't switched off. You might also need to check the drivers for the device are installed and up-to-date.
BOTH SPEEDS PLAY WAY TOO FAST
Drive belt may have slipped, check speed on record, check if switch has another position or is not moving all the way, check if turntable is seated correctly.
I need to know the secondary output voltage of power transformer.
If the primary of the transformer has failed it doesn't follow that the main power supply parts are also faulty. However since the transformer is a safety part you need to replace it with the same thing.
However it seems from this website that transformers are not expensive compared to a new deck, so a look around here might solve the problem.
