20 Most Recent Irwin SDS-Plus Hammer Drill Bit 6in.L, 3/8" dia., ModelNo. 322024 Questions & Answers
There are cordless varieties of just about any type of hand drill, even the specialized hammer drill. These hammer drills work in the same manner as any of the core hammer drills or regular drills. Powered by a set of rechargeable batteries.
Irwin SDS-Plus... | Answered on Aug 27, 2008
You need to know the hole diam. where the key goes and the max size for the chuck. 1/2 3/8 Grainger has your key when you know what to order.
Drills | Answered on Dec 30, 2019
broken shaft not many places would have this but a salvage yard
Found Ryobi P505 18v battery. Compare it to what you already have. Stores have other brands if this does not match. Was listed at The Home Depot.
lots of WD-40 double channel locks and strong person. work it a little at a time to avoid damage.
it is possible that a chuck is spun on if it has fine threads. most likely if the chuck is frozen you would have to use spanner on key hole and put the outer ring in a vise. It should loosen up. Sometimes I use a pipe wrench and the large channel locks to spin the chuck open. Most have a screw but it can get rounded over which would require drilling it out.
Try Googling (test rite)(bench98)(manual) without parens.
Drills | Answered on Dec 05, 2019
What make and model drill is it, please? You can use the Comment menu to add information to your question, or to ask additional questions.
Drills | Answered on Dec 01, 2019
Contact Jobmate directly to inquire.
Did Someone Succeeded to Change the DC18RC from 110v to 220v ??
What are the component that should be replaced ??
Where can i get them ?
Thx ,
Lio
Drills | Answered on Nov 25, 2019
old and faulty replace .
Drills | Answered on Nov 24, 2019
Try Amazon or E-bay for starters.
Drills | Answered on Nov 11, 2019
More efficient sowing of the seed so crop was more evenly distributed
faster sowing of the crop less man hours
Drills | Answered on Nov 09, 2019
There are a great many similar items on the market these days at a variety of prices and in spite of the claims very few are truly heavy duty - most are copies of copies from a few manufacturers (usually China) and are label engineered and best suited to the home workshop and occasional user.
A true heavy duty version is very different - very much heavier and with a rack-and-pinion operated tiltable table, a more powerful continuous rated motor and many refinements that suits the machine to continuous workshop use. Such a machine as this would usually cost at least double and most commonly three, four or five times of the common imported type.
The first type has little value as a used machine other than what cash a purchaser can be persuaded to pay for it, in fact if it is bought with the usual accessories; a set of T bolts, a good machine vice and a collection of Morse taper drill bits, the price would more than double, the accessories being worth more than the pillar drill.
The industrial rated tool in good condition does retain a good used value but again it is worth only what the market will pay.
I suggest you peruse a variety of tool catalogues.
Drills | Answered on Oct 27, 2019
Usually drill motors have a reverse (left) thread retaining screw located in the center of the chuck. The chuck however is typically threaded in the normal right hand configuration. Once the retaining screw is removed place a 1/4" allen wrench short end into the chuck and tighten, next strike the allen wrench with a soft tip mallot (counter clockwise while holding on to the drill motor firmly. This should loosen the chuck, then simply unscrew the chuck by hand. Good Luck!
Drills | Answered on Oct 26, 2019
Irwin SDS-Plus Hammer Drill Bit 6in.L, 3/8" dia., ModelNo. 322024 Logo
1 questions posted
Top Irwin Drills Experts
Marvin
Marvin
john h
Are you an Irwin Drill Expert? Answer questions, earn points and help others
View Most Popular
Irwin Drills
  • Irwin Drills
Most Popular Question
hammer drills power supply
  • Drills
