20 Most Recent
Black & Decker DW682K Dewalt Plate Joiner Questions & Answers
Is there a 2
Because of standardized sizes of biscuits, the only blade you can and should use, is the same size that comes with the tool. Anything smaller will not create the right diameter groove for the biscuits to fit properly.
Blade guard for Atlas 6'' jointer
I can send you pics of the one I made from plywood for this same jointer. If you're looking for an original I can't help you there.
Need a manual for a
If you're still interested, please see
this answer and follow the links.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Tuckpointing brick, mortar won't stay in. have a
is the recess deep enough on the bed and perp joints if so is the mortar the right consistency.
a little tip is to wet the joints with water before jointing. it stop the mortar drying out to quick
What is the proper way to hold the masonry trowel?
On the website http://www.masonryforlife.comthey explain: "Learning to hold the trowel correctly is important and will make the job easier. Gripping the handle with four fingers and putting the thumb on top of the metal band (ferrule) on the handle is how most masons hold a trowel."
1 yard cement is how many cubic feet
kakima is 100% correct, but to add to it so you understand how he got that 27 cubic feet... you can picture a cube.
A cubic yard is 3 foot tall x 3 foot wide x 3 foot high.
(A cubic foot is 1 foot tall x 1 foot wide x 1 foot high).
So 3 x 3 x 3 = 27.
Rewiring switch
I do not have a clue as to what you have but a simple switch has two connections and you can connect either way.
