20 Most Recent
Dewalt 18 Volt Compact Drill Kit Questions & Answers
Keyless Chuck releases bit when reversed
hi
open the chuck all the way and then look down in the centre of the chuck you should see a cross head screw
unscrew and the chuck should pull out as this is on a taper system ( note the screw is left hand thread )
Removing the dewalt DC925 'rohm' chuck
I simply placed the chuck into a large vise and turned the drill counter clockwise and the chuck spun right off no problem without damaging anything!! It does have some thread lock on the chuck but just use your man strength and its as simple as turning the lid off the pickle jar! Do not waste your time or money with the removal tool...YOU DONT NEED IT!
How to change a keyless chuck dw958
DEWALT DW958 Power Tool Battery ReplacementType: Ni-MHVolt: 18VCapacity: 3000mAhColor: BlackWeight: 1160gDimension: 136.80x85.43x113.00mmhttp://www.drillbattery.com.au/buybattery.php/dewalt_DW958_power+tool+battery.html
Replaceing chuck on a Dewalt Dw511 1/2" hammer drill.
Open the chuck jaws and you will see a screw in the center of chuck, it is left hand thread. remove it and use a large bent handle allen wrench putting the short portion in the jaws and tightening. Shift the drill to the low position and have the clutch in the drill only position. place the handle of the wrench at about a 30 degree angle to strike it counterclockwise. put the chuck on a block of wood or workbench and hit it, this might take a couple times but it will come off. Let me know if you still need help
Chuck problem
If it is a keyless chuck, try resting the chuck on a wooden work bench, and with a dead-blow hammer aka: shot hammer, slant-strike the chuck in the unscrew direction.
