20 Most Recent
Xerox DocuColor 3535 Copier Questions & Answers
116-325 error code on docucolor
Hi the 116-325 error for the 3535 is a 24Volt communication error.
The 24V power supply 105E18641 is probably bad, or possibly some wires that connect them.
Whit
Item, Inc
How do I recover the operating system after replacing a damaged disk?
unfortunately , unless you have the data saved on another hard drive , gig stick etc , it is all lost
you will have to install a new operating system from a cd or download from the net
everything that you view , save on a computer is all on the hard drive initially so when that drive fails --all is lost
there are companies that can remove the disc from a failed hard drive and then recover the data but , the cost has to be considered as it is not cheap
Transparecy issue
+24 VDC power is failed. Status Code 102-319 is displayed after 116-325 is displayed.
+24V LVPS is failed. Perform following:
Remove Rear Cover (REP 14.2).
Remove cover from +24V LVPS (PL 9.1).
Disconnect P502 on +24V LVPS (Figure 1).
Check that power is switched off. Measure resistance of fuse on +24V LVPS. Resistance is 1
ohm or less.
if no Replace +24V LVPS (PL 9.1).
if yes Switch on the power. Measure the AC voltage between the white and black wires in P2 on the
+24 VDC. 110 or 220 VAC is measured.
Error code 116-365 on dc
Solutions for Fault Code 116-365: Fatal Error of the SPL (Spooler / Spool Queue) is Displayed With a Power the Machine Off and On Message:
> Power OFF the Printer, Wait 45 Seconds, Then Power ON
For more details of the problem, visit:
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=397,E=0000000001527486692,K=5902,Sxi=6,Case=obj%2845960%29
Hope this solves your problem,
Thanks.
Xerox 5225 fault code 010-320???
If you have a Xerox WC5225 with Error Code 010-320, then you have a fuser problem. The fuser is the heated item which bonds the image, just before it exits the unit. The machine monitors the temperature sensors and heating elements on this part.
The fuser is sold as PN 126K24980. It is easy to replace yourself.
Whit
Item, Inc.
