If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can. If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa.
Most BIOS versions included a language option
Get the computer manufacturer and your computer model number.
If it is available, go to the manufacturer site and look for BIOS & Firmware upgrades.
When your PC is starting up, press the Setup key. This is usually Del, F2, or F12.
The key, however differs with each machine.
It should be stated on the screen for a very short time which key is the setup key
you can change the bios settings by using the ARROW KEYS select it press enter and exit then press the F10 key to save to cmos and restart
if your not sure or you have made any wrong bios changes you can set failsafe or optimised defaults
if you are unable to change the bios language settings the bios might need to be updated or bios chip might need to be changed or flashed
Before flashing the BIOS do a search on BIOS flash and read the caveats.
Backup your current BIOS and only flash if it is absolutely necessary!!
If the computer vendor is unknown or unavailable, try to identify the motherboard vendor and model number if you can, BIOS updates are specifically associated with motherboard versions:
you can change the language settings
click start control panel regional and language options select regional language options from the drop down list select the language you want also from the bottom drop up list you can select your present location location or another language
hope this helps
1,347 questions posted
126 Questions
101 Questions
81 Questions
23 Questions
