20 Most Recent
La Crosse Technology TX61U-IT Solar Powered Wireless Temperature Sensor Questions & Answers
Sensor doesn't work
Mine stopped working about 2 weeks ago (May 2018) after about 8 years of service. I had tried the recommended procedure to depress the reset button on the sensor, but it still would not reset / reboot the temperature sensor. I suspect the non removable batteries to be the issue failure so I am about to crack the case open to try to troubleshoot the issue for confirmation.
6/2/2018 10:31:13 PM •
La Crosse...
Answered
on Jun 02, 2018
Need user manual for w5746
Same exact features, buttons and functions as this manual by Irwin.
http://www.irwin.com/uploads/documents/36_laser_tape_25.pdf
Will one of the newer sensors work in place of my 1457 sensor?
It's possible that one of the newer sensors could work in place of your 1457 sensor, but it depends on the specifications of the newer sensors and the compatibility with your base unit. The I MAX1457 sensor, which is a highly integrated analog-sensor signal processor optimized for piezoresistive sensor calibration and compensation. However, I have no information about its compatibility. If you're looking for a replacement sensor, I suggest contacting the manufacturer of your base unit to inquire about compatible sensors. Alternatively, you can check the user manual of your base unit to see if it lists compatible sensors. Garage door opener sensors are not universal. Safety sensors can only communicate with garage door openers from the same brand.
