20 Most Recent
Frigidaire 20.3 cu. ft. Upright Freezer GLFU2067F Questions & Answers
How do i install a new door gasket/seal on my Frigidaire upright freezer model # LFFH21F7HWA ?
Good Morning Friend,
I understand you want to know how to install a new door gasket on your Frigidaire freezer, model# LFFH21F7HWA. Typically this is not a do it yourself repair, as there are no step by step instruction manuals that will tell you how to do this. I suggest either contacting the manufacturer or your local authorized technician for further assistance. The technician has been trained on your specific appliance, and should be able to replace the new gasket with ease. Hope this is helpful.
-Best Regards-
WP
What is the orange light for at the top of my freezer
Your freezer seals on door are bad causing it to ice up and the light is telling you to defrost,these models have a design flaw that causes this,seals around door have to be replaced to fix.Call your local appliance company and see if they can order you some new seals.
My upright freezer Frigidaire model
You are absolutely correct.
The compressor is leaking its Freon.-----------
What is Freon?
The Freon is a cooling refrigerant in the compressor.Its like a gas.The unit starts cooling with the refrigerant in the compressor.-------
There is a leak in the compressor and that's causing the refrigerant to leak.You will need to get your compressor replaced.In some cases the leak can be sealed by a silicon sealant and required refrigerant can be again charged in compressor.----------
This job has to be done by special licensed tools.The HVAC repair techs have all this tools.They will first detect the leak , if the leak is major get the compressor replaced.But if leak is very minor then the leak has to be sealed by the sealant.The HVAC techs have this sealant with them.After the leak is sealed the pressure in the compressor is checked by the pressure tool.As per the pressure, additional refrigerant will again be added to the compressor and you can use the same compressor.---------
But as per me, if you get compressor replaced, then it will give exact required cooling.
To get new compressor for you Frigidaire upright freezer, please click the link below:---
http://technoanswers.blogspot.com/2011/06/frigidaire-upright-freezer-glfu2067fw4.html
This should help.Thanks.Helpmech.
