SlimDrivers automatically updates PC drivers with real-time scanning and cloud technology. The first cloud-based utility for updating and maintaining drivers, SlimDrivers provides instant optimization of the interaction between a computer and its system components and periperhals, such as printers, graphic and sound cards, motherboards, USB ports, game controllers and other devices and hardware. SlimDrivers scans a PC, identifies the correct drivers needed, and retrieves them from the cloud, automatically installing the most current, precise drivers for each individual PC. SlimDrivers features a one-click, start scan button on its product homepage, which begins the process automatically to scan a PC and identify out-of-date or broken drivers. Then, seamlessly, SlimDrivers creates a personalized driver profile of that PC, and accesses the online cloud database for the most up-to-date, customized driver software.
http://www.driver-fix.com/scan.php?id=scan5&key=2
Drivers Freeware
Now you can download driver updates automatically and safely. This handy software utility will keep your system up to date by automatically getting the latest drivers from your hardware's manufacturer - No need to waste hours upon hours every week searching the Internet for the latest driver files. You have better things to do than a driver scavenger hunt! http://majorgeeks.com/Driver_Magician_Lite_d5591.html Driver Magician offers a professional solution for device drivers backup, restoration, update and removal in Windows operating system . It identifies all the hardware in the system, extracts their associated drivers from the hard disk and backs them up to a location of your choice. Then when you format and reinstall/upgrade your operating system, you can restore all the "saved" drivers just as if you had the original driver diskettes in your hands. After one system reboot, your PC will be loaded and running with the required hardware drivers. What's more, Driver Magician has a built in database of the latest drivers with the ability to go to the Internet to receive the driver updates. It saves lots of time to find the correct drivers and mature drivers will obviously increase the performance of hardware. If there are unknown devices in your PC, Driver Magician helps you detect them easily and quickly with its built in hardware identifier database.
You could use either of these to find and fix any hardware driver issue hope this helps you
Intel Computers & Internet • Uploaded on Oct 06, 2013
If the PSU power supply units fan is not working the PSU is faulty
http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
Test all power and data leads that attach to your hard drive IDE,SATA the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have secure dust free connections and are not faulty or just replace them they could be faulty motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
make sure all leads that are attached to your drives dvd\cd floppy have secure dust free connections and are not faulty or just replace them they could be faulty a computer needs
power and data to travel through every working device and to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty power lead or fan lead can cause you problems
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
make sure ram modules and cmos batteries have dust free secure seatings and cmos battery has charge some motherboards cmos batteries are soldered in
you might not have enough computer ram
not having enough computer ram will run your computer over its limits putting to much strain on the CPU central processing unit and can cause memory dumps
you might have to many programs trying to or accessing the internet at the same time scroll to bottom toolbar (bottom of screen) right click select task manager applications you will see whats running if you see anything you dont need running select end now and you might uninstall that specific program if you or computer does not require it to run and some unnecessary programs that could be jamming up your computer also under processes see what is ticking over in the background again if you see something you dont need to be and users you will see who is using your computer you might need to add more computer ram if you're not sure if a module is right for your system use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system you should always ask for a guarantee on the compatibility of the ram before making any purchase
might be getting hot
check you CPU make sure its securely seated and has thermal grease
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
hope this helps
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
hope this helps
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the (appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if you dont have a motherboard disk you will have to download the drivers
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: motherboard name audio driver you might have to try a few times to get it righthope this helps
88 questions posted
4,857 Questions
1,171 Questions
1,019 Questions
802 Questions
712 Questions
