20 Most Recent
MSI P4M900M-L Motherboard Questions & Answers
Al iniciar o reiniciar con
The first thing would be to uninstall the Wireless device and software. I would then look for a BIOS update for the mother board it may not be set up to work with a USB wireless device as it is an older model. You may have better luck using a PCI wireless card directly on the Motherboard.
Translated:
Lo primero ser?a desinstalar el dispositivo y el software inal?mbricos. Luego buscar?a una actualizaci?n de la BIOS para la placa madre que podr?a no estar configurada para funcionar con un dispositivo inal?mbrico USB ya que es un modelo anterior. Puede tener mejor suerte usando una tarjeta inal?mbrica PCI directamente en la placa base.
No video from on board video connector or video card.BIOS issue?
did you check your RAM for this video problem because 90% no video problem because of RAM ....
if you check your RAM and if its ok then 100% problem comes from *********** board but first check your RAM for this problem......
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
manish
UnKnow Bios error
Error Code =8302
Sr,
Hi, this can be caused by a BIOS update or a faulty motherboard battery. You can reset BIOS to default settings by pressing the F1 key during bootup, which will take you to the BIOS screen.
Al iniciar o reiniciar con teclado conectado aparece
google translate When you start or restart with keyboard attached display
try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines or a can of compressed air.
dust causes static which causes lots of problems with a computer and its parts
you might have to uninstall your keyboard restart your computer then reinstall it
make sure the ps2 lead connection is secure and dust free (if applicable)
make sure the usb device is inserted correctly into the usb port (if applicable)
click start control panel administration tools computer management device manager scroll to keyboards also mouse you might see a yellow exclamation or question mark ! ? or red x you will need to update driver right click to update driver
if your computer came with a motherboard disk the drivers could be on it
hope this helps
How can i get the
you can get the drivers here:
http://www.driverstart.com/start576314.html
Cheers!
I need drivers for BIOSTAR
You can download all the drivers for your motherboard from Bios Official website. Open this link
(BiostarGroup P4M900-M4), and download the drivers from the available lists. You need to click the "winzip" icon to download the respective drivers.
Note: there's no drivers for Windows this motherboard.
If you need further help, let me know.
Good luck.
Thanks for using
FixYa.
Every time I on my
You need to flash your bios before it becomes totally corrupted. You are losing small bits of information that your motherboard needs to continue functioning.
I have what i believe is the proper page for your bios, but your exact model doesn't show up when I search the site, so the best solution for your problem is the MSI live bios update located at the bottom of this webpage:
http://www.msi.com/index.php?func=downloaddetail&type=bios&maincat_no=1&prod_no=1150
Simply install that and allow it to automatically fix your bios for you.
NO DISPLAY
Hi m_o_redz,
If you are using the on-board (integrated video), S3 Graphics Chrome9 HC Integrated Graphics core. Than check you're video cable, video cable connection. Try another monitor. If all check out ok than the MSI integrated video is defective. Suggest you install a PCI-E video card.
If you are using a PCI-E card, try removing it. Clean the copper contacts using a cotton swab & alcohol. (Let it dry) Than reseat the PCI-E card.
Try booting again.
Good Luck!
Mike
Error code =8302
check your bios settings that the vid output is set to boot from the right device that you want it to be from. try reseting defaults
No post to bios on new pc build
FIRST....... Make sure you remove the stock thermal compund (pasty/sticky stuff) from the bottom of the heat sink as well as from the top of the cpu.........
Second APPLY some ARCTIC SILVER 5 compound-ust a thin coat of it over the top of the cpu......use an old credit card.....keep it ff the sides and bottom though......it's important not to use too much........one little tube will do anywhere from 3 to 5 CPUs...!!!
(stock thermal paste/thermal compunds......**** BADLY and can cause a cpu to burn up)
reseat (properly) the cpu and carefull
Now make sure you're 24 pin or 20+4Pin Power connectors are connected, as well as your fans..........disconnect all your SATA Devices, and remove everything but the video card , CPU, and fans.......Now it should post (if all your jumpers are set correctly...........
IF it still doesn't post, remove the video card and reboot.
If it doesn't beep at all......... You have one of 2 things.........A DEAD CPU, or a DEAD MOBO
