20 Most Recent
ASUS P5NT WS (P5NT WS GREEN) Motherboard Questions & Answers
What is the beep code asus p5ntws
AMI (American Megatrends International) BIOS Beep Codes.
AMI BIOS uses beeps of the same length and pitch. The error is displayed as a number of beeps. For example, 4 beeps indicated a timer failure.
BEEP CODE MEANING POSSIBLE CAUSE
1 Beep (No video) Memory refresh failure Bad memory
2 Beeps Memory parity error Bad memory
3 Beeps Base 64K mem failure Bad memory
4 Beeps Timer not operational Bad motherboard
5 Beeps Processor error Bad processor
6 Beeps 8042 Gate A20 failure Bad CPU or Motherboard
7 Beeps Processor exception Bad processor
8 Beeps Video memory error Bad video card or memory
9 Beeps ROM checksum error Bad BIOS
10 Beeps CMOS checksum error Bad motherboard
11 Beeps Cache memory bad Bad CPU or motherboard
Award BIOS Beep Codes
Award BIOS uses beeps of varying duration. A long beep will typically last for 2 seconds while a short beep will last only 1 second. Award BIOS also uses beeps of different frequency to indicate critical errors. If an Award BIOS detects that the CPU is overheating it may play a high pitched repeating beep while the computer is running.
1 Long, 2 Short Video adapter failure Bad video adapter
Repeating (Endless loop) Memory error Bad memory or bad connection
1 Long, 3 Short Video adapter failure Bad video adapter or memory
High freq. beeps (while running) CPU is overheating CPU fan failure
Repeating High, Low beeps CPU failure Bad processor
Phoenix BIOS Beep Codes
Phoenix BIOS uses beep code patterns to indicate problems. In the table below the '-' indicates a brief pause between beeps.
Example: 1 - 1 - 2 would sound like BEEP <pause> BEEP <pause> BEEP BEEP
1 - 1 - 2 CPU / motherboard failure Bad CPU / motherboard
1 - 1 - 3 CMOS read/write failure Bad motherboard
1 - 1 - 4 BIOS ROM failure Bad BIOS chip
1 - 2 - 1 Timer failure Bad motherboard
1 - 2 - 2 DMA failure Bad motherboard
1 - 2 - 3 DMA failure Bad motherboard
1 - 3 - 1 Memory refresh failure Bad memory
1 - 3 - 2 64K memory failure Bad memory
1 - 3 - 3 64K memory failure Bad memory
1 - 3 - 4 64K memory failure Bad memory
1 - 4 - 1 Address line failure Bad memory
1 - 4 - 2 Parity error Bad memory
1 - 4 - 3 Timer failure Bad motherboard
1 - 4 - 4 NMI port failure Bad motherboard
2 - 1 - 1 64K memory failure Bad memory
2 - 1 - 2 64K memory failure Bad memory
2 - 1 - 3 64K memory failure Bad memory
2 - 1 - 4 64K memory failure Bad memory
2 - 2 - 1 64K memory failure Bad memory
2 - 2 - 2 64K memory failure Bad memory
2 - 2 - 3 64K memory failure Bad memory
2 - 2 - 4 64K memory failure Bad memory
2 - 3 - 1 64K memory failure Bad memory
2 - 3 - 2 64K memory failure Bad memory
2 - 3 - 3 64K memory failure Bad memory
2 - 3 - 4 64K memory failure Bad memory
2 - 4 - 1 64K memory failure Bad memory
2 - 4 - 2 64K memory failure Bad memory
2 - 4 - 4 64K memory failure Bad memory
3 - 1 - 1 Slave DMA failure Bad motherboard
3 - 1 - 2 Master DMA failure Bad motherboard
3 - 1 - 3 Interrupt controller failure Bad motherboard
3 - 1 -4 Slave IC failure Bad motherboard
3 - 2 -2 Interrupt Controller failure Bad motherboard
3 - 2 - 3 <RESERVED>
3 - 2 - 4 Keyboard control failure Bad motherboard
3 - 3 - 1 CMOS batter failure Bad CMOS battery
3 - 3 - 2 CMOS configuration error Incorrect setting
3 - 3 - 3 <RESERVED>
3 - 3 - 4 Video memory failure Bad video card or memory
3 - 4 - 1 Video init failure Bad video card or memory
4 - 2 - 1 Timer failure Bad motherboard
4 - 2 - 2 CMOS shutdown failure Bad motherboard
4 - 2 - 3 Gate A20 failure Bad motherboard
4 - 2 - 4 Unexpected interrupt Bad processor
4 - 3 - 1 RAM test failure Bad memory
4 - 3 - 3 Timer failure Bad motherboard
4 - 3 - 4 RTC failure Bad motherboard
4 - 4 - 1 Serial port failure Bad motherboard
4 - 4 - 2 Parallel port failure Bad motherboard
4 - 4 - 3 Coprocessor failure Bad motherboard or CPU.
9 - 2 - 1 Video adapter incompatibility Use a different brand of video card
Hello.
My Asus p5nt ws motherboard
hi remove ur proceesor and cpu fan clean the sudfwace of the fan and processor apply a hin coating of heat sink solvent and place back the processor in the socket and tightly place the processor bank int its place if still not working change the proceesor with your freind that fits the socket if still not working you have problem with MOSFET in your motherboard use a multimeter and check the MOSFET
P5NT won't boot
Have you tried clearing the CMOS by removing the battery with PSU off and then shorting the 'reset cmos" (or similar) pins on mobo?
Also found this on the ASUS web site under the specs for the P5NT WS board...
ASUS CrashFree BIOS 2 The CrashFree BIOS2 feature now includes the BIOS auto-recovery function in a support DVD. Users can reboot their system through the support DVD when a bootable disk is not available, and go through the simple BIOS auto-recovery process. ASUS motherboards now enable users to enjoy this protection feature without the need to pay for an optional ROM.
Have you tried this?
Got problems with lan drivers,Is it possible that
The drivers CD that came with the MoBo should contain all the necessary drivers.
It is possible that you have unkowingly skipped the LAN driver instal.
Put the CD in again and exit the setup, then go to My Computer and open the CD, find the LAN driver folder and install from there.
ASUS P5N T
First of all disconnect the Hard Disk do a check of switching on your comp and leaving it in on condition till you switch it off , repeat this exercise to ensure that there are no hardware problems . If your checks yield positive results then all you have to do is clean your hard disk thoroughly of any prevoius installations using the hard disk prep tools which you can download or obtain from vendor and then reinstall the OS .
How do I enhance my Asus PadFone X mini speaker loudness?
Look for a program called Sound Booster or one called DFX. DFX is my favorite because it not only boosts the volume, but lets you add other effects to enhance you sound as well. There is a free version. but to get all the effects you have to upgrade to the paid. If audio is important to you, check it out.
How to fix sound is not working in my asus laptop?
Try going into sound select and test reinstall driver off Asus website..if you installed new windows or update drivers may not work right...see if you can roll back driver in device manager ..if not lookup your laptop model and reinstall...
Graphics card no picture on monitor when connected via HDMI or any cable?
The issue you are experiencing with your graphics card and monitor can be caused by various factors. Here are a few troubleshooting steps you can try to identify and resolve the problem:
1. Check power connections: Ensure that the graphics card has the necessary power connections properly connected. Some higher-end graphics cards require additional power connectors, such as 6-pin or 8-pin PCIe power connectors. Make sure they are firmly plugged in.
2. Verify BIOS settings: Access your motherboard's BIOS settings and check if the primary display output is set to the PCIe slot where your graphics card is installed. It should be set to prioritize the discrete graphics card instead of the integrated graphics (if applicable).
3. Update BIOS and drivers: Visit the Gigabyte website and make sure you have the latest BIOS version installed for your motherboard. Additionally, download and install the latest drivers for your graphics card from the XFX or AMD website. Outdated firmware or drivers can cause compatibility issues.
4. Reset BIOS: Try resetting the BIOS to its default settings. Locate the CMOS battery on your motherboard, remove it for a few minutes, then reinsert it. This action resets the BIOS settings to their defaults and may resolve any conflicting configurations.
5. Check for physical damage: Inspect the graphics card for any physical damage, loose connections, or faulty components. Ensure that it is securely inserted into the PCIe slot and that there are no visible signs of damage on the card or its connectors.
6. Test with a different monitor and cable: Connect your graphics card to a different monitor using a different cable (e.g., DisplayPort, DVI) to rule out potential issues with the HDMI cable or the monitor itself. This helps determine if the problem lies with the graphics card or the specific combination of monitor and cable.
7. Check for motherboard compatibility: Verify that your graphics card is compatible with your motherboard. Check the manufacturer's website for compatibility lists or consult the user manual for your motherboard. In some cases, a BIOS update might be necessary to ensure compatibility.
8. Seek professional assistance: If none of the above steps resolve the issue, it's advisable to contact the technical support of your motherboard or graphics card manufacturer. They may have specific troubleshooting steps or recommend further action, such as warranty service or component replacement.
Remember to handle your hardware with care and take necessary precautions, such as grounding yourself and disconnecting the power supply, before performing any physical checks or adjustments.
I am using an Asus Vivo mini computer approx 5 years old. Since December I often receive error message across top, "Microsoft Edge (not responding)"
Question edited for clarity and toss in a load of CAPS as needed.
Microsoft Edge is one of the worst browsers ever invented. It is flashy and looks pretty, but is not user friendly and is glitchy.
The most likely issue for that Error Message is your Internet Wifi signal dropping out. You can test this theory two ways.
Do you have a smartphone? Download the Free App Speedtest. When you get the Edge Error, whip out your phone and do a Speed Test. If it stalls or only returns a speed of 5 to 10 mbps, that is your issue.
Or Download Google Chrome which is FREE and a much more robust browser and easier to use. Keep both Edge and Chrome open, when Edge collapses, try to do things on Chrome. If Chrome works, then the issue is Edge. If Chrome also fails, the issue is your Wifi and Router. A Router reboot should be done about once a month.
Google Chrome Download - Download Google Chrome
google.comhttps://www.google.com
Continue your browsing experience from desktop to phone on Chrome. Download today. Now more simple, secure, and faster than ever - with help from Google built-in. Google Address Bar. One browser, all devices. Type less with autofill. Chrome support.
Download Now
Get a new and fast web browser. Download Chrome and start browsing.
My asus laptop turns on but there is just black, the power indicator says its on.
If you are experiencing a black screen issue on your laptop, the first thing you should do is to make sure your laptop is powered up correctly. Check the cable from the power adapter to the laptop, and make sure it is firmly plugged in. If it is, then you should try resetting the power supply on your laptop. To do this, unplug the power adapter from the laptop, press and hold the power button for 30 seconds, and then plug the power adapter back in. If the laptop still does not display any images, you should try reseating the RAM chips. First, try to turn off and unplug your laptop, and then remove the battery. After that, open up the RAM memory slot, and use a screwdriver to press down on the RAM chip securely. Then, replace the RAM chips and the battery before turning on your laptop. If these troubleshooting steps do not work, then it is likely that your laptop may have a hardware issue, and you should take it to a repair shop.
