20 Most Recent Motorola Mobility MBP36 Baby Monitor Questions & Answers
MPB33 motorola baby monitor
Hi, For better assistance you can contact our Baby Monitors specialist. http://www.motorolacordless.us/ Best Regards, Katy Motorola Support
4/30/2015 7:23:49 PM • Motorola... • Answered on Apr 30, 2015
Ordered model:MBP33+7, did not have bonus digital Audio Baby Monitor
Hello, For better assistance you can contact us directly http://www.motorolacordless.us/ Regards, Kenny Motorola Support
4/30/2015 1:04:54 AM • Motorola... • Answered on Apr 30, 2015
I can't get my monitor to charge. The cord seems to be ok but I think it's the receptacle on the screen that has a problem. Where can I send it for repair?
You can also contact Looking For Help for assistance in the US or CONTACT US then pick your country and then look for the Baby Monitor Support number or Email. Please be sure not to pick phone support as it is not handled by the same contact center. Mark Motorola Mobility Support
2/25/2015 10:57:55 PM • Motorola... • Answered on Feb 25, 2015
Can a Samsun Galaxy Tab 3 SM-T110 tablet pair with a Motorola MBP36BU nanny cam? As a video monitor.
Contact Baby Monitor Support @ Looking For Help for assistance with your Baby Monitor. Mark Motorola Support
2/23/2015 12:42:19 PM • Motorola... • Answered on Feb 23, 2015
Baby monitor problems
For Baby/Home/Pet Monitors, Cordless/Corded Phones, Digital Photo Frames 1-888-331-3383 Mon-Fri 7:00AM-7:00PM CST (Baby/Home/Pet Monitor email)
7/22/2014 1:12:14 PM • Motorola... • Answered on Jul 22, 2014
Why does my monitor lose its signal all the time?
Baby monitors are not the top of the food chain when it comes to reliability which is strange seeing what it is used for. There is something interfering with the wireless. See if you can track it to what device. Microwave with screw with this as well as something as small as a smart phone. The constant updating of aps to the phone is a real bugger. Wireless internet is another thing to look at. Seeing how radio waves are everywhere it is not a guarantee but try removing everything from between the monitor and your camera that would have radio frequency.
7/21/2014 11:31:56 PM • Motorola... • Answered on Jul 21, 2014
2answers
The sound suddenly stopped working on the parent
Okay, a couple of things. This speaker issue seems to be a common problem, and I believe it most likely occurs due to rough handling of the unit. Although it seems to be fairly rugged, it should be treated gently. In general, I would only handle it as much as needed, and be careful when setting it down, and make sure it doesn\'t get dropped.With that being said, the unit can be opened, however doing so will break at least some of the "snaps" that hold it together. If it is out of warranty and you need to get into it, this is a necessary evil.Step one: Remove the battery cover (one phillips screw) and battery. There is a second, smaller phillips screw that also must be removed. Step Two: At this point, you are ready to separate the unit. Using multiple flat head screwdrivers, pry the unit open (starting on the right side when looking at the unit from the front) then "wedge" the pried open area with a second flathead screwdriver as it will naturally want to close back up. Continue working your way around the unit, being careful not to crack the screen. You will break some tabs along the way, but I see no way around this as they are not visible to try and release them any other way.Step Three: Once you have separated the two halves of the unit, the power button will have fallen out. This is okay as it will slot back into place when you reassemble the unit. Just set it aside and do not lose it.Step Four: I do not know the exact failure mode of the speaker, however you will find that it is apparently strongly secured in the housing with an adhesive (epoxy or some sort of resin) and if you had to remove it it would be difficult and not very fun. MY SOLUTION: I hooked the battery back up and turned on the music feature, which should play music from both the camera and the parent unit. In my case, I found that tapping hard on the speaker (it took more force than you would think) would cause the music to momentarily play. I found that wedging a screwdriver between the plastic housing and the speaker body would make the speaker play. I used a small nail (like a trim nail for small trim) and wedged it between the speaker and the housing, then trimmed off the excess of the nail.This solution is not ideal, but it was relatively quick and worked to keep the unit functioning for now. I imagine that there is some sort of connection that has failed internally in the speaker, and that wedging it has (at least temporarily) reformed the connection. I imagine that a new speaker could be installed with some work to remove the old speaker, and then a new one soldered in and glued into place. Once I got the speaker working, I disconnected the battery and carefully replaced the power button, then the two halves simply snapped back together. I replaced the screws and reinstalled the battery, and all has been working as it should. The case does show some damage from my prying, and it doesn\'t fit as tightly as it used to with the broken snaps, but it does hold together and doesn\'t have any issues in normal use.In all, it certainly beat buying a whole new unit, especially since it was working just fine other than the sound. Good luck!
3/7/2014 5:09:13 PM • Motorola... • Answered on Mar 07, 2014
0answers
0answers
Monitor won't turn on
Hi, most recently the reason of this event is that some electrical components of your monitor power board are defective. Prease refer to technical person to solve the problem.
12/3/2013 5:41:18 PM • Motorola... • Answered on Dec 03, 2013
0answers
0answers
Mbp36 not working
Be the first to answer 4/12/2013 2:56:49 PM • Motorola... • Posted on Apr 12, 2013Be the first to answer
Motorola Mobility MBP36 Baby Monitor Logo
Popular Tags
30 questions posted
Top Motorola Mobility Baby Gear Experts
Jennifer Rock
Jennifer Rock
ZJ Limited
ZJ Limited
john h
Are you a Motorola Mobility Baby Gear Expert? Answer questions, earn points and help others
View Most Popular
  • Motorola Mobility Baby Gear
Most Popular Question
monitor lose its signal all time
  • Baby Gear
