20 Most Recent
Amana AKS3040 Gas Cooktop Questions & Answers
Clicks but does not does not igite
Hello, thank you for your post. It sound like your saying the burners are not lighting up. Most of the time this is just a simple fix. Next time you turn on your burner notice were the igniter sparks this part of the burner needed to be cleaned. You should be able to take the burner cap off and the burner use a wire brush to clean the surface area so the spark has good contact. Take notice also of the igniter you will need to change it out if you see any cracks around the ceramic housing.
Happy Holidays!
Please rate me "4 thumbs" if this information was useful.
On occasion the ignighter on
From your description this problem is simple to understand and easy to fix. The wire harness has a loose contact from the sparking rod to the spark module. At either connection points the connection is loose so it sometimes make contact and sometimes not.
So you need to disassemble the unit by removing burner and the top unit so you will find the wires and spark module under top unit.
Here is the link with all above parts of your unit which will help you.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5167493&diagram_id=1320529#d1320529
One burner on gas cook to is not having gas flow through it.
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
