20 Most Recent Canon XH A1 Mini DV Digital Camcorder Questions & Answers
3answers
Get Final Cut Pro 5.04 to communicate with my XH A1
Many HDV cameras and decks are able to play and record DV as well as the higher-resolution HDV format. Additionally, many of these HDV devices will attempt to automatically change their settings to match the format of the tape that it's playing. Here are some tips for using these types of devices with Final Cut Pro / Final Cut Express.
Tip: Make explicit settings on your HDV device. Instead of using an "Auto" setting, make your own settings on your HDV device to keep the communication going between it and Final Cut Pro / Final Cut Express. This also helps Final Cut Pro / Final Cut Express keep things running smoothly with HDV devices that handle both DV-NTSC and DV-PAL.
For example, say you're using an HDV deck to capture footage from a tape that was recorded as DV-NTSC. Before capturing in Final Cut Pro / Final Cut Express, make sure that you set the deck to DV mode specifically—don't rely on Auto mode. With some devices, you may need to disconnect it from FireWire to change the mode.
For a common capture workflow, this sequence of steps can provide the best results:
  1. Quit Final Cut Pro / Final Cut Express if it's open.
  2. Insert your tape into your HDV deck or camcorder.
  3. Use the device's menus to set it to match the format that's recorded on the tape.
  4. Connect your HDV device to your computer with a FireWire cable.
  5. Open Final Cut Pro / Final Cut Express.
  6. Choose an Easy Setup for DV or HDV (whichever matches the format recorded on your tape).
  7. Proceed to Log and Capture.
Tip: Quit Final Cut Pro / Final Cut Express before changing modes. It's generally a good idea to quit Final Cut Pro / Final Cut Express before you change the mode on your device from DV to HDV, or from HDV to DV, and then re-open the application again.
Tip: Use an Easy Setup to play back non-default HDV format footage on your HDV device. You can use Final Cut Pro / Final Cut Express to make your HDV device play back footage in its non-default HDV format. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as 1080i50. Or perhaps you have a 1808i50 HDV device and you want to play back footage that was recorded as 1080i60. To do this, follow these steps:
  1. Connect your camera to your computer.
  2. In Final Cut Pro / Final Cut Express, choose an HDV preset Easy Setup that matches the format of the tape's footage (you don't need to restart Final Cut Pro / Final Cut Express).
  3. Your device's LCD display should automatically display a switch to 60 or 50, indicating the type of media that's being played.
Playing back non-default DV format footage on your HDV device You can also use your HDV device to play back footage in its non-default DV format too. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as DV-PAL. Or maybe you have a 1080i50 HDV device and want to play back footage that was recorded as DV-NTSC. If so, follow these steps:
  1. Make sure that your device is in DV/DVCAM mode.
  2. Put your device into Play/Pause mode, then open the Log and Capture window in Final Cut Pro / Final Cut Express.
  3. Make sure that your device's LCD (or other readout screen) displays the same format as your tape or Final Cut Pro / Final Cut Express will misinterpret what type of device you have.
Tip: Avoid recording both HDV and DV formats on the same tape. Use separate tapes whenever you want to record in a different format. If you need to record over existing footage in a different format (for example, you have a tape with DV-PAL on it, but you want to record over it with HDV 1080i50), it's a good idea to black and code the tape, or completely record over the old footage with contiguous recording in the new format. If the tape contains even a second of, say, DV in the middle of an HDV tape (or vice versa), it could cause unexpected results later when you try to capture video from that tape.
For more information, see HD and Broadcast Formats and the Final Cut Pro / Final Cut Express User Manual, available under the Final Cut Pro / Final Cut Express Help menu
9/29/2022 9:36:51 AM • Canon XH A1 Mini... • Answered on Sep 29, 2022
Can't change playback Std to HDV
Mine was grayed out and for the life of me I couldn't get it to work UNTIL... I tried removinf the firewire cable I had connected to the camera. That solved the whole issue for me. Hope this helps.
11/20/2021 7:38:41 PM • Canon XH A1 Mini... • Answered on Nov 20, 2021
2answers
Canon xha1 won't turn on
Same Problem, same day, have you found any solution?, i stored the camera for abut 6 months following the Manual specifications, keeping the camera away from humidity, dust, even light and unmounted batteries, but it didn't turned on when i really needed it, I tried changing batteries, power source, i've already checked the lock/standby and the main dial, anyone help please!
10/22/2020 11:19:58 PM • Canon XH A1 Mini... • Answered on Oct 22, 2020
High static noise on my external mic
95% of the time, it's a poor ground connection. Some of the time though it can be caused by a defective op amp on the audio board. Last thing that I can think of is the version of the adobe and the other audio programs, if they are not the pro/ paid versions, they sometimes introduce all sorts of noise. If the noise sounds like an old dial up modem, this might be the problem.
10/24/2017 6:49:03 AM • Canon XH A1 Mini... • Answered on Oct 24, 2017
Some Buttons does not Operate
Send it for service or repair
8/1/2017 2:06:35 PM • Canon XH A1 Mini... • Answered on Aug 01, 2017
3answers
My Canon XH A1 will not turn on to record
Check your little lock and standby lever at the back of your hand strap, its likely positioned between standby and lock.
11/17/2015 10:44:44 PM • Canon XH A1 Mini... • Answered on Nov 17, 2015
Canon Xh a1 won't turn on, HDV and Power are blinking
It could be the blown fuse that located on the main circuit board.
1/20/2015 4:39:10 PM • Canon XH A1 Mini... • Answered on Jan 20, 2015
2answers
Firewire worked once but not anymore...Canon XHA1
Solution? Maybe, but PC's vary greatly. Pass it on if it works for you. If Win-XP. Device manager. Un-install IEE1394. Close & Restart. Let the system restore the 1394 then try to reconnect the unit, cable to the PC first, then to the powered down camera. Power up the cam. What are you using to ingest? I recommed http://scenalyzer.com.
9/29/2014 9:40:01 PM • Canon XH A1 Mini... • Answered on Sep 29, 2014
My XHA1s records but won't play back any tapes
Sounds like the edge of the tape has been damaged. The edge of the tape has the speed encoded so the playback will know what speed to play the tape. Look at the edge of the tape for wrinkles. If present, throw away the tape so you won't use it for an important recording.
5/11/2014 9:21:56 PM • Canon XH A1 Mini... • Answered on May 11, 2014
2answers
What do i do if I get condensation in my canon xh
This is usually caused by a failed component in the moisture detection circuitry within the camera. This will require disassembling the camera to remove the tape mechanism and repair. This can usually be done fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
4/15/2014 12:02:17 PM • Canon XH A1 Mini... • Answered on Apr 15, 2014
Please help me...When I connect
Try playing the tape before connecting up to the mac with the firewire and before loading FCP up. Usually fixes it for me when using either iMovie to import or FCP
11/27/2013 9:39:15 PM • Canon XH A1 Mini... • Answered on Nov 27, 2013
2answers
When I capture HDV footage
Make sure the properties for the project you start after the ingest match the frame rate you used to record. Reads like 29.97 speed setting looking at images recorded at 24f.
7/4/2013 1:17:46 PM • Canon XH A1 Mini... • Answered on Jul 04, 2013
2answers
Has blue in areas of low light
Add light or increase gain incrementally( gain=grain ). The unit is not known for low light finesse. Few in that chip range are.
4/7/2013 5:52:09 AM • Canon XH A1 Mini... • Answered on Apr 07, 2013
0answers
Canon XH A1 Mini DV Digital Camcorder Logo
82 questions posted
Top Canon Video Cameras Experts
NOEL
NOEL
john h
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
View Most Popular
XH Canon
  • XH Canon
Most Popular Question
canon xh a1 turn hdv power blinking
  • Video Cameras
