20 Most Recent Brother Multi-Function Center MFC-240C All-In-One InkJet Printer Questions & Answers
Brother mfc 240c machine error 40
The casing internal temperature thermistor has detected abnormal temperature in the machine. Check the thermistor for optimal operation.
6/3/2022 12:33:59 PM • Brother... • Answered on Jun 03, 2022
Change language
refer manual goto printer's setup function and change language
2/2/2022 7:22:16 PM • Brother... • Answered on Feb 02, 2022
7answers
Brother MFC-240C Change Unable 50
I also had this problem, your solution was spot-on, remove the top cover and control panel and re-seat the encoded strip. simple.
boy, are you guys good.
11/14/2021 7:40:33 AM • Brother... • Answered on Nov 14, 2021
2answers
Print unable 52 on Brother MFC-240C
Yes it works Thanks
11/14/2021 7:22:42 AM • Brother... • Answered on Nov 14, 2021
Error 4f brother mfc-j410
Unplug the device for 5 minutes. Plug-in and see if difference
8/1/2021 7:20:27 AM • Brother... • Answered on Aug 01, 2021
Clear "error 76 : Unable to clean" on brother printers mfc-j430w
Most likely, The machine has a mechanical problem or a foreign object such as a paper clip or ripped paper is in the machine
7/31/2021 10:59:58 AM • Brother... • Answered on Jul 31, 2021
Print unable 36 error
The 36 error mean: The machine does not work due to a paper jam. Clear the paper jam, if doesn't work maybe a sensor is dirt or bad. To disassambly the printer you need the service manual and some know how ( electronics knowledge).
All the best !
7/30/2021 9:50:33 AM • Brother... • Answered on Jul 30, 2021
Brother mfc-240c printer error message unit unable 43
http://support.brother.com/g/b/faqend.aspx?c=gb&lang=en&prod=fax2440c_us_eu&faqid=faq00000168_003
2/11/2021 6:55:18 PM • Brother... • Answered on Feb 11, 2021
12answers
Brother MFC 240C alignment problems
I have figured it out! I have a Brother MFC 240CN and I was having the same alignment problem and I followed the instructions from the printer prompt as well as the manual and it does not work.
So, this is what I did. I ran the alignment test print, then when it asked if it matches, I would say "No". And then I would pick number "8" to be the one that most closely matched "0" regardless if it did or not. I did this for the 600 and 1200dpi. Then when I ran the alignment test print again, it looked better! So I repeated it again and again picking "8" each time and it looked better with every test print. After about 4 or 5 tries, it looked normal again!
I hope everyone else with this problem will see this response and I hope it works too. I was getting so frustrated with this problem. Now I don't have to get it serviced or buy a new printer!
9/23/2018 10:24:14 AM • Brother... • Answered on Sep 23, 2018
15answers
Brother mfc845cw
See picture how to do that :-)
6/6/2018 12:57:36 AM • Brother... • Answered on Jun 06, 2018
Brother DCP 135C paper is dirtied with black smudges
At this website www.reliable-store.com I found so much of information on how to repair vehicles and technical issues in detail.. Also complete, much better language, and they also have live assistance feature
3/7/2018 6:43:09 PM • Brother... • Answered on Mar 07, 2018
Brother mfc 240c. just installed all new
Yes, you can manually clean the printhead. I can't provide step by step instructions, but the print head is the piece that your ink cartridges go into. There is probably a lever that holds it locaked into place. You will want to take out the ink, then open the lever and remove the print head. Then clean where the ink cartridges sit, then gently clean any coppor contacts you see and then clean the print nozzles on the bottom of the print head. Do all of this with distilled water. Dry completely and re-install along with your ink. If this doesn't solve the issue, you can buy replacement print heads.
11/11/2017 12:56:54 PM • Brother... • Answered on Nov 11, 2017
2answers
Brother MFC 240C yellow
Common error of brother mfc/dcp printers.
Unfurtunately there is nothing what you can do.
Call brother hotline ask for service/guarantee repair.
10/4/2017 11:16:54 AM • Brother... • Answered on Oct 04, 2017
2answers
Can't print
Easy solution is to download drivers from the brother website. Takes just a few minutes and you should then be up and running or printing.
8/19/2017 11:12:20 PM • Brother... • Answered on Aug 19, 2017
2answers
When turned on it says
Use bin and purchase new. Repair costs are high.
8/2/2017 6:55:27 PM • Brother... • Answered on Aug 02, 2017
Envelope printing smudges
have you thought of using avery envelope sticker sheets instead http://www.averyproducts.com.au/avery/en_au/Products/Labels you can also download templates to use in word to line up the printing to the stickers
5/31/2017 12:30:17 AM • Brother... • Answered on May 31, 2017
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
942 questions posted
Norman Weimar
Norman Weimar
k24674
View Most Popular
  • Brother Office Equipment & Supplies
Most Popular Question
mfc 240c will not print yellow despite
  • Office Equipment & Supplies
