20 Most Recent
Panasonic TH58PX600U 58 in. Plasma HDTV Questions & Answers
I purchased the tv in
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations
. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
8/16/2017 3:03:41 PM •
Panasonic...
Answered
on Aug 16, 2017
Power light blinking 7 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "
Mosaic" or "
Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
4/22/2014 4:22:47 AM •
Panasonic...
Answered
on Apr 22, 2014
No color on Panasonic plasma tv
There are so many reasons for this fault to a plasma display, and the troubleshooting is actually a skilled work indeed. It will be best to contact any service technician.
10/31/2013 3:13:18 PM •
Panasonic...
Answered
on Oct 31, 2013
Indicator flashing twice
15V SOS board is faulty. Replace it. If
you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock!
Instead, contact the nearest service center.
2/11/2013 6:34:25 PM •
Panasonic...
Answered
on Feb 11, 2013
Panasonic TH-58px600u
I have the same problem, no picture or sound, just a flashing red led. Has anyone found a solution?
12/2/2011 2:12:07 AM •
Panasonic...
Answered
on Dec 02, 2011
TV TURNS OFF EVERY 10 MINUTES, FLASHING RED LIGHT,
Hello,This issue is related to a power problem in as much as the TV turns off on it's own.The problem is consistent with overheating on the power supply board of the TV. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby making it to misbehave.The power supply board of the TV has few capacitors and IC. If any of these IC's gets short or become weak, it can cause the TV to turn off on it's own.When current passes from electric outlet to the power supply board of TV. The current also goes to the weak/faulty part, then the current stops or slow and the board overheats and TV shuts off on it's own.To solve this issue, check the power supply board and read it with a meter and continuity tester, in order to detect the faulty part and replace the faulty part on the board which is short due to which power supply boardYou can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board from www/shopjimmy.com to save you some stress.Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.If you don't have the ability to read the fault, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.I wish you the best of luck.Regards.
11/22/2011 10:21:10 PM •
Panasonic...
Answered
on Nov 22, 2011
Panasonic TH58PX60U TV comes on for 5 to 15
4 blinks Power SOS P Board
Try opening it first look for some bad connections or so if they are none use a hair drier and heat the board looking for the place that creates the 4 blinking then use the hair drier on cool to cool the place and get this time little longer.
6/2/2011 9:23:38 PM •
Panasonic...
Answered
on Jun 02, 2011
I was watching TV from
The tv power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Power supply board probally have dying capacitors parts.Dying or dead capacitors are alway bulging or puffing up on it tops.U have all the tools and understanding basic electronic also can do basic soldering?Check the power supply board carefully for dying or dead capacitors and replace it with new capacitors with same Micro ferid and the voltages higher 5 or 10 voltages higher for better heat resistance.Or try website like Ebay.com to buy a whole refurbish power supply board for the replacement.
3/26/2011 12:48:13 AM •
Panasonic...
Answered
on Mar 26, 2011
Panasonic TH58PX600U 58 in. HDTV Plasma. Image is Distorted
I could not see the image you say you included in your description. If the rectangle is black (and not just an outline) it may be the box associated with captioning or text descriptions. Use your setup menu or remote control to turn captioning/text off.
9/22/2009 2:55:59 AM •
Panasonic...
Answered
on Sep 22, 2009
Cycle SAP function to restore sound on CBS channels
Apparently the TVGOS (TV Guide On Screen) signal on CBS stations (since the 6/12 digital changeover) can cause the sound to be missing on those channels. Use the SAP button on the remote to page through the SAP options. When you return to the normal setting the sound will be restored. This problem should not occur again unless the SAP button is pressed.
