20 Most Recent
Cingular Wireless Cingular 8525 Smartphone Questions & Answers
Unlocking cingular 8525 (HTC)
You can unlock your HTC 8525 mobile from network lock using unlock code...Once you unlocked it you can use any gsm network sim card in your mobile at any country...I found an unlocking service at here
www.unlocking4u.com and unlocked my mobile successfully.This is the online service which offer the code at reasonable cost...Through this can unlock your mobile easily...
10/8/2011 6:04:26 AM •
Cingular...
Answered
on Oct 08, 2011
My phone says i have a sim lock, so i cannot make calls.
Call your carrier tell your carrier's customer service representative that you're traveling abroad and want to use a foreign carrier's Sim card If they don't give you the code, stick by your guns and ask for a manager.
5/2/2010 10:32:41 PM •
Cingular...
Answered
on May 02, 2010
Sound
I just fixed mine. No ring or external sounds following a short drop. Found a loose internal header on the back, right side of the phone.
Remove back.
Remove battery.
Remove SIM.
Remove 4 screws (note will void warranty)
Starting from top, carefully de-attach rear plastic cover.
Inspect. Header on right side as you look at the back of the phone has black/white wire going to speaker.
Reattach.
Re-install in reverse order.
Crazy phone still works great!
R
4/17/2010 8:48:01 PM •
Cingular...
Answered
on Apr 17, 2010
How do you update phone?
no, you can just enter HTC, Dopod or iMATE website and download the ,ost update ROM image for your device.
12/20/2009 6:51:53 PM •
Cingular...
Answered
on Dec 20, 2009
Memory card is showing as not installed
possible dirty contacts in the phone where the card inserts blow it out with a computer cleaner to clean the contacts if it still dose not recongnize then the slot is damaged!
8/29/2009 8:37:35 AM •
Cingular...
Answered
on Aug 29, 2009
My htc 8525 screen keeps going white
9 times out of 10, this means that the rigid flex cable has gone bad - this is the cable that goes from the thicker part of the case (the part the battery is in) to the thinner part, which houses the LCD. If you're handy, you can purchase tools kits and replcaement cables on Ebay...but if you're not, there are also SERVICES on ebay which will do this for a fee.
5/19/2009 7:46:49 PM •
Cingular...
Answered
on May 19, 2009
Phone doesn't ring & won't record or play back messages
Not sure what solved the problem, but I went through all the windows sounds, testing each one to see if it played. After doing that, the ring tone was restored and everything back to normal. I hope this can work for someone else with the same problem.
5/13/2009 11:43:41 AM •
Cingular...
Answered
on May 13, 2009
AT&T 8525
I am having exactly the same problem with my HTC 8525. Hav eyou been able to figure out what the problem is and how to fix it?
4/16/2009 3:41:30 AM •
Cingular...
Answered
on Apr 16, 2009
8525 Keeps going from Landscape to portrait for no reason
the switch is actually caused by a magnet, automatic switching can be caused by the sliding screen becoming loose. one of the most common causes of the screen auto-switching is using a phone holder with a magnetic flap like many new holders have instead of a velcro flap.
maybe this is happening to you?
3/22/2009 10:08:43 AM •
Cingular...
Answered
on Mar 22, 2009
8525 phone
I don't think anyone here can give you a sim unlock code. Unless you want to pay for it you can buy from ebay.
http://pof.eslack.org/hermes-unlocker/
Run this unlocker on your phone. Follow the instructions exactly. Don't
unlock the CID unless you planning on installing another custom rom
other than ATT on it.
3/18/2009 4:38:16 PM •
Cingular...
Answered
on Mar 18, 2009
