20 Most Recent
Sova DSV32P112 32 in. LCD Television Questions & Answers
Haier TV Power Supply Board Problem
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "
Mosaic" or "
Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis. It is best. If you wish to get some details; check the site linked here. Viewing it in "
Mosaic" or "
Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Sova LCD 32" with no Picture
since i do my stuff by trial and error, sometimes its just a matter of making sure you dont have a video cord plugged into an audio plug that is supposed to be for the tv signal to go out and not come in or that where you have the left/right audio plug is good, but the video plug is broke.
i just move from one slot to the next trying different a/v (out) spots
Power cord
If plug in cord Google or in North America try MCM electronics, if a soldered in cord they are generic.
No power getting to TV.
I have a 32'' Sova LCD tv with the same problem. The problem maybe your power supply. In my case, it was the power supply (no.# YHi 090-02180-13) it had no voltage out put, no blue light and no working fan. Remove the power supply and take it to your local repair center and check it for voltage out put. I found it difficult to locate the same power supply after the decision not to repair mine. There is an alternative I found on ebay, it doesn't look the same, but all the spec checks out. I had this power supply for two days and my tv work great so far so good.
I need replace conrol remote,
It would be really tough to get a remote for this model. Either you could buy a universal remote which could be programmed from tho TV or you need to contact the manufacturer directly. Regarding the universal remote, you could buy it from any of the nearby TV parts shop or radioshack. However,make sure that the universal remote you buy could be programmed with your TV. If you wish to contact the manufacturer for the remote, kindly note the details :-
Sova Digital Inc
17300 Dallas Pkwy
Dallas, TX 75248
Phone: (972) 818-1088
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
