20 Most Recent Kodak EASYSHARE 5300 All-In-One InkJet Printer Questions & Answers
3answers
Printer won't print
My printer will not print black ink. The color ink is very light. I replaced a new color cartlidge, cleaned the printheads and tried to callibrate, but the printer could not identify the callibration page from my scanner. Can you help me resolve my problem?
Thanks,
Carol
2/2/2022 9:38:35 PM • Kodak EASYSHARE... • Answered on Feb 02, 2022
2answers
What is the photo tray?
It is the holder for 6x4 photo paper. You will find it built into the top cover of the main A4 paper tray, on the right hand side. Mine has a transparent plastic cover. To load it, lift the cover and insert photo paper.
It is engaged by lifting the cover and sliding the tray into the printer. It is automatically recognised.
7/18/2021 8:01:49 AM • Kodak EASYSHARE... • Answered on Jul 18, 2021
The sponge strip om my kodak 5300 printer seems to be soaked in black ink can it be replaced .
EVER ASK KODAK TO ASSIST YOU ?
4/20/2021 11:14:42 AM • Kodak EASYSHARE... • Answered on Apr 20, 2021
2answers
Printer kodak 5300 says error code 6203
printer needs to be replaced
call kodak at 18004216699
3/28/2021 7:42:56 AM • Kodak EASYSHARE... • Answered on Mar 28, 2021
Why do my prints have a purple tint to them?
Most cauuses to this is dirty or failing print head.
Many people would say it was the sponge that is doing that but let me tell you if it was a full sponge you would not even see that color tint. Its the print head that is not mixing correctly due to being dirty or corrosive. Do you use refilled ink cartridges? If so you answer is iron clad your print head will need to be replaced and you need to put a stop to the refilled oslution, if not then the print head got dirty or is defective.
1. print head cleaner
2. new print head.
thanks hope this does help please do be considerate and rate and leave feedback for your free answer. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
3/28/2021 7:42:41 AM • Kodak EASYSHARE... • Answered on Mar 28, 2021
2answers
New ink cartridge put in today, printing out faded
try to remove both cartridges and put them back in. make same print. if of no use, run a Clean Printhead in your men. If still of no use, then printhead needs a replacement
3/28/2021 7:41:45 AM • Kodak EASYSHARE... • Answered on Mar 28, 2021
My kodak 5300 printer is printing with streaks
Hi
To resolve this issue you'll need to clean your printers cartridges. To clean it you'll need Q-Tip and alcohol. Turn off your printer and unplug it, now open the printer's front cover and take out the cartridges from their respective carriage. Now dip the Q-tip in alcohol and clean the cartridges with Q-tip. Also, clean the print head with Q-tip, use a paper towel if there is excessive ink inside the carriage.
Now let it dry and check if it is still giving similar issue. If yes then closely examine the print head for any kind of restiction like a piece of paper.
Daniel Scott
3/28/2021 7:41:29 AM • Kodak EASYSHARE... • Answered on Mar 28, 2021
Printhead needs replacing in my kodak 5300 printer
Hi..
Try here
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/printhead/AUR1780-9_UE_RevC.pdf
You can find illustrated instructions on how to remove the old printhead, as well as on how to put the new printhead back in place.
You can easily go to that website by going to:
www.kodak.com/go/printheadsupport
and selecting the second option "installing new printhead".
Good Luck:-)
3/28/2021 7:37:26 AM • Kodak EASYSHARE... • Answered on Mar 28, 2021
Poor print ,not dark enough.had this problem
Common problem with Kodak print heads. And since you're done with the troubleshooting and is likely very familiar with the printer and its problem, definitely the print head is going bad again.
Thanks
3/28/2021 7:34:44 AM • Kodak EASYSHARE... • Answered on Mar 28, 2021
Bypassing printer warning that stops my printer
this one is one of my favourite hate printers... but, no you cannot disabel this function easy, you can "fool" this printer by following that procedure:
1. switch off your printer, wait few sec, switch it on
2. on your computer go to "start"
3. select "control panel"
4. select "printer and faxes"
5. right click on your "kodak easyshare 5300"
6. select "properties"
7. click on tab "services"
8. select "service this device"
9. click on tab "estimated ink level" - it shows estimated ink level after restart
you can use refill (very easy to do by yourself and about 1/3 cost of original replacements). and yes, you are right, cartridges do tend to dry out. i would suggest printing at least one page per week to prevent dry out of the cartridge.
as this particular printer will not work without both cartridges present. i would suggest to insert one empty cartrdge in colour slot and keep it there. on full cartridge use any sticky tape to prevent nozzle from drying, cover breather hole on the top of cartridge as well. when you need to print, remove tape from breathing hole first and then from the nozzle. this way you will prevent or at least slow down your cartridge evaporation ratio.
3/28/2021 7:34:33 AM • Kodak EASYSHARE... • Answered on Mar 28, 2021
Kodak Easy Share 5300 Printer error Error
Error code "6203" can be resolved as follows:
First, you need to open the access door of the printer and disconnect the power adapter from it.
You then need to wait for at least 30 seconds for the printer to get reset.
As a next step, you can connect the power adapter back to the printer.
You can turn on the printer, if required. Once the printer gets powered up, a message "Printer access door open" gets displayed.
Once this message gets popped up you can close the access door of the printer. get more help for Printer Error Code 6203
Hope this helps you.
3/28/2021 7:34:18 AM • Kodak EASYSHARE... • Answered on Mar 28, 2021
What do error codes 3501 and 3502 mean?
One of the best ways to prevent Printer error code "3501" from happening is to install latest version of firmware. To update firmware manually you can place the calibration sheet over the scanner and press START button. You can then click the HELP icon and select Maintenance option. From there, select Firmware Upgrade option and follow the instructions given there to download the latest firmware version; free of cost.
3/28/2021 7:34:02 AM • Kodak EASYSHARE... • Answered on Mar 28, 2021
I am having problem on how to change the ink
hi,
following images and steps may guide you.
first know the parts.
Tear open the black ink cartridge bag at the notch and remove the ink cartridge.
IMPORTANT: Insert the ink cartridge immediately to prevent any drying of the ink.
Remove and discard the orange cap.
IMPORTANT: Handle ink cartridge carefully to avoid ink transfer.
Insert the black ink cartridge into the printhead. User's
Press down on the ink cartridge until you hear it snap into position
Tear open the color ink cartridge bag at the notch and remove the ink cartridge.
Insert the color ink cartridge into the printhead
Press down firmly on the cartridge until you hear it snap into position
Close the printer access door.
regards,
cseian
3/28/2021 7:33:49 AM • Kodak EASYSHARE... • Answered on Mar 28, 2021
2answers
I have a brand new Kodak ESP 3250. Not one drop of
Clean the gold section of the print cartridge's with a wet paper towel.
Also clean the gold surfaces where the cartridge meets the printer.
Wipe the contacts clean with a dry paper towel once you get no ink back on the wet paper towels. Allow about an hour for the printer to dry.
Reinstall the cartridges and try printing.
Hope This Helps.
Zeppelinx12
3/28/2021 7:33:35 AM • Kodak EASYSHARE... • Answered on Mar 28, 2021
After replacing the color cartridge,
You have a bad cartridge. They have chips in them. Return it.
3/28/2021 7:33:11 AM • Kodak EASYSHARE... • Answered on Mar 28, 2021
3answers
My KodakEasy Share 5300 will not print in black.
92b8b47.jpgThe Kodak AiO printers 5000 series and ESP series PRINTHEADs has orange protective cap that need to be remove to fit on the printer carriage. For the ink cartridges 7b91cbc.jpgthere is also a orange protective cap.
Issue that its not printing black and deep clean and removing the printhead and reinstalling the printhead (reseating printhead) is already done and still no black when printing. The printhead should be replace. For futher assistance call 1 800 421 6699 Kodak AiO printer support line
3/28/2021 7:30:48 AM • Kodak EASYSHARE... • Answered on Mar 28, 2021
When printing a photo has a yellow/green tint
Possibly it is running low on Blue ink - because colors are usually a mixture of inks - for example green is made from blue and yellow - if an ink runs low it will print the available colors or substitute the next available color.Probably if it prints green yellow - then it has no blue available to make the right shade.
3/28/2021 7:30:34 AM • Kodak EASYSHARE... • Answered on Mar 28, 2021
2answers
How do i remove old printhead and install new one
Replacing the printhead If your printhead is damaged or broken, you may replace it yourself.
  1. Make sure your printer is turned on.
  2. Open the printer access door by lifting from the recessed hand-holds on the sides of the unit. autourg00977009id2130369.jpg
    The printhead moves to an accessible position for handling the ink cartridges. The ink cartridges are seated in the printhead.
  3. Pinch the latch on the ink cartridge with your thumb and forefinger and lift it out of the print head. Remove both ink cartridges.
    caution.gif CAUTION:
    Insert the ink cartridges into the newly installed printhead as soon as possible to prevent any drying of the ink.
  4. Unlatch the printhead by lifting the rectangular latch on the top of the printhead.
  5. Remove the old printhead from the carriage .
  6. Remove the new printhead from its bag.
    Do not touch copper contacts on the printhead, as this may damage it.
  7. Remove and discard the black plastic casing and the orange protective cap.
  8. Place the new printhead into the carriage.
  9. Push firmly against the target label on the printhead until you hear it click into place.
  10. Re install the ink cartridges. As needed, see Replacing ink cartridges.
  11. Close the printer access door. The printer should now complete a printhead calibration to ensure that it is ready to for normal operation.
3/28/2021 7:30:15 AM • Kodak EASYSHARE... • Answered on Mar 28, 2021
PRINTER DOES NOT DETECT PAPER EDGE
Have you tried "fanning" the paper before loading it? This fixed my problem after a 6 hour battle, downloads of all firmware and restarting infinity times.
3/28/2021 7:17:46 AM • Kodak EASYSHARE... • Answered on Mar 28, 2021
10answers
How do you remove the printhead of a Kodak EasyShare 5300 printer?
Clarification: Remove tanks(cartridges)first. You see the bullseye target with a finger pointing to it.
Above the bullseye sticker, there's a rectangular button. Press it in until printhead dislodges.
2/9/2021 1:14:41 PM • Kodak EASYSHARE... • Answered on Feb 09, 2021
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
1,204 questions posted
Top Kodak Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
EasyShare Kodak
  • EasyShare Kodak
Most Popular Question
error code colour cartridge not
  • Office Equipment & Supplies
