Hello, it would be good to know if the Laptop has valid its guarantee and on the other hand if it receives battery charge, without making some measurements it's difficult to give an accurate diagnosis; it's possible that it's an element of the board (circuit) it's necessary to measure the voltage and other components to determine if there is a problem with the voltage delivered by the charger.
We can perform a battery reset to check and have an idea.
Your D620 probably has the Nvidia Graphics (Video) card that was a manufacturing defect well documented all over the internet. I have reflowed the video card on quite a few of these laptops. Below are some excerpts from the user manual.Solid green power light and no beep code and no video during POST
The monitor or the graphics card may be faulty or incorrectly installed.
Check the diagnostic lights to see if the specific problem is identified. See "Video and Monitor Problems."
Open the Calculator program on the laptop (in Windows or Linux).
Click on the start menu.
Type Calculator.
If your operating system doesn't support searching from the start menu then look in the application listing for Calculator..
Hi William,
You may use the below link to find the user manual:
http://dell.to/18tInOm
Input the service tag, click on the pdf hyperlink next to owner's manual.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Why should you download ASK? Ask is a dirty and trick adware and will fill your computer with advetising. People are crazy about trying to remove it! How to Remove Ask com
Double check to make sure there is nothing in any other 3.5 mm jack you can stick a q-tip that has had most of the stuffing ripped off and dipped in rubbing acohol to clean it off MUST BE OFF.
if this doesnt work the built in speakers might have broken/blown or the built in audio might have a problem. But being a laptop you cant really replace the audio processor.
Hi Lucky Siketho,
Please email me the system service tag to [email protected] along with the current operating system installed. Then I can check and help you with the right Dell Camera application.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Check all sides of the laptop for a switch to turn on the wireless, if not you look at the keyboard make sure there is not a key that has the wireless on it . If you see the wireless on the key you must hold FN key and wireless key to activate. If the problem is not wireless, and it is just networking. Go in the control panel under network and sharing, open that and look for change advanced sharing settings (usually on the right side upper corner) open that and make sure turn on network discovery is on turn on all items ..
No. Factory reset wipes all settings and will require you to enter them again to get connected. You're better off using the help function in the Network Wizard to troubleshoot the problem step by step. If it's a windows machine it might be able to repair itself through this process.
if it is the password that pops in blue as soon as u start up mate the best bet buy the cd from ebay i have one but i found it easier going to the computer shop cause they have the hardware to do that plus if u google it pay a company who remove bios passwords you WILL HAVE TO REGISTER WITH them but make up something cause they ONLY do it for commercially goodluck if you dont get anywhere tell me and i,ll help you ok.
It is unfortunate that the LCD screen has blurred. There is a possibility that the LCD screen has failed. You may want to use the below link and performing an LCD BIST:
http://dell.to/1irqbYp
Also try connecting a known good external monitor and check if that helps.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
