20 Most Recent
Amana ARS2661BS Side by Side Refrigerator Questions & Answers
Amana refrigerator ars2365aw refrigerator/freezer works
if your freezers back wall has a layer of frost build up on it,that means the defrost heater or thermostat that controls this heater is bad,if theres an ice buildup on the evaporator coils it cant blow cold air into the unityou need to find out whats bad as it can no longer defrost,when you shut it off for a day you are defrosting the unit,then the frost and ice again cover the coil when you plug it back in
I have an Amana side
Probably your defrost timer or the defrost element. If you take the leads off of the element and test it with an ohmmeter you'll be able to determine if it's blown.
On an Amana ARS2661BS Unit does not cool on either side
Pull it away from the wall and remove the cover the covers the compressor. Unplug and tell me if the compressor is too hot to touch or if running or any signs of life. If not running and cool I want plug it back in, and open the fresh food door and and look for a hole in the control panel where you adjust temperatures. The opening is about the size of a pencil eraser. Sometimes this hole is covered by a plastic plug. Stick a small flathead screwdriver slowly clockwise until the compressor restarts. If this works the refrigerator needs a new defrost timer. Sometimes the defrost timer will stick in defrost and stop. Let me know, Thanks Sea Breeze
Bottom vegetable/fruit drawer freezing fruit
to the left of the bottom drawer is a veg/meat slide switch.make sure it is all the way on veg.if it is on meat,it opens a small doorway to the freezer and lets the cold air in and will freeze the food in the bottom drawer.in some cases,you will need to remove the drawer and shelf and then take apart the doorway.ball up some putty and jam it it the hole to completely seal it off
Need to find water filter on my amana model
Install Water Filtration Cartridge (some
models)
a. Remove bypass cartridge from water filter head in rear
right corner of refrigerator section. Twist cartridge
counterclockwise 1/4 turn and pull down to remove.
Save bypass for use at a later date.
b. See Water Filtration System Installation and
Operating Instructions provided with water filter
cartridge for filter installation and operation.
6/20/2023 3:26:22 PM •
Amana...
Answered
on Jun 20, 2023
Afd2535des not cooling in any department, when I opened the doors, the lights work and the led temp control lights up. I hear a fan start and 5 seconds later the fan stops n leds shut off.
- Check the thermostat: Make sure the thermostat is set to a temperature that is low enough to cool the refrigerator. If the thermostat is not working properly, it may need to be replaced.
- Check the condenser coils: The condenser coils on the back of the refrigerator should be clean and free of dust and debris. If the coils are dirty, the refrigerator will not be able to cool properly. Use a vacuum cleaner or a brush to clean the coils.
- Check the fan motor: If the fan motor is not running, the refrigerator will not be able to cool properly. Check if the fan motor is receiving power and if it's spinning freely. If the fan motor is faulty, it will need to be replaced.
- Check the start relay: The start relay helps the compressor start up. If the start relay is faulty, the compressor may not start and the refrigerator will not be able to cool properly. If the start relay is faulty, it will need to be replaced.
- Check the compressor: If the compressor is not working, the refrigerator will not be able to cool properly. Check if the compressor is receiving power and if it's running. If the compressor is faulty, it will need to be replaced.
2/16/2023 2:42:10 AM •
Amana...
Answered
on Feb 16, 2023
No power to Amana ice and water dispenser. Rest of refer runs fine.
It's possible that the issue could be with a micro switch located on the ice maker cabinet that is activated when the prong on the back of the ice/auger tray is inserted. It's also possible that there could be another issue with the dispenser, such as a problem with the wiring or a malfunctioning component. I would recommend checking the wiring and testing any other micro switches or components that are related to the dispenser to see if they are functioning properly. If you are unsure how to do this, I would recommend consulting the user manual or contacting a qualified technician for further assistance.
1/14/2023 10:27:43 AM •
Amana...
Answered
on Jan 14, 2023
