20 Most Recent Polaroid 3211TLXB 32 in. LCD Television Questions & Answers
2answers
I am unable to get the dvd to play
just turn on both the dvd player and your tv set...then set your tv program into AV mode or INPUT mode,and connect the RCA cables from the output of the dvd player into the input socket of the tv system...be sure that the colors or the RCA wires must correspond to the two sockets namely the the OUTPUT adn the INPUT..you can now activate your dvd player!!!
5/24/2019 2:53:13 AM • Polaroid... • Answered on May 24, 2019
How to tunr writing off on screen
If it is closed captioning, go into the set up Menu, or "CC" button remote, and select "off" to shut off the Closed captioning.If it is menu selections from setup, navigate to "exit" option and select it, or try "OK" button, or "Menu button."
4/7/2016 9:16:51 PM • Polaroid... • Answered on Apr 07, 2016
3answers
Tv wont turn on, but have light on fornt of lcd
You are only have 5v standby circuit working, the problem can be in the main control board (not sending signal to turn on the main power supply sections) or the main power supply sections are bad.
8/20/2015 5:10:24 PM • Polaroid... • Answered on Aug 20, 2015
Polaroid 3211-TLXB solarized / negative image
Just replace the T-Con board and you dont need any soldering at all. JUst be careful for the flex connector.
1/23/2015 3:08:01 AM • Polaroid... • Answered on Jan 23, 2015
Polaroid color green
T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
8/26/2014 7:25:21 AM • Polaroid... • Answered on Aug 26, 2014
2answers
Tv was working fine will not turn on now power
Service manual here, under FLM series if that is the series you have,
http://polaroidsupport.com/polaroid/en_us-sm.html
Do you get sound but no picture? Check the power supply module.
7/8/2014 9:07:30 PM • Polaroid... • Answered on Jul 08, 2014
Shuts off after 30 seconds
check the power line... if anything unable to find what cause it was, then sent tv back where you paid for it and ask them to look into...
12/11/2013 7:14:56 PM • Polaroid... • Answered on Dec 11, 2013
Hello there i have a 32" polaroid tv TLU-43211BX,
It sounds like its back-light is not working. Check it. Check the back-light inverter board, and replace it if needy. If you're sound in electronics, and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Flip card, can be selected by the drop-down list, by the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window.
11/3/2013 10:03:19 AM • Polaroid... • Answered on Nov 03, 2013
Polaroid 3211 tlxb 32inch Not powering on (No Red/Blue light illuminating)
Check and replace its main power regulator as card basis. It comes at the center top part of the panel, looking from backside. You must ahve enough knowledge in electronics to do this work. There is no repair to this board, as the components used in the circuit will be very difficult to get from open electronic spare part market. Check this site. You'll get an idea about its working and other details. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to the latest updates. It will make search easy. There are more than 1300 posts to different brand TVs now. Pull up older posts there.
11/27/2012 9:33:43 AM • Polaroid... • Answered on Nov 27, 2012
Display fade out
replace bad inverter board for screen back light.
9/3/2012 6:43:27 AM • Polaroid... • Answered on Sep 03, 2012
Red light flashing on my tv and won't come on
replace the power supply board. You should be able to get the replacement power board from www.tvcircuitboards.com send them a email [email protected] if you dont see it listed as they only list a few of the boards they carry
3/3/2012 2:06:41 PM • Polaroid... • Answered on Mar 03, 2012
Polaroid 32
Polaroid is the other non-brand name products, made in a limited quantities and used well known logos as a bait for consumers. Those are: "element", "mag', "magnavox", and polaroid itself. the only one advantage of early "polaroid" is: display panel has been made by real Polaroid, then. what made the picture quality outstanding, compare to other "bunch". even though they use similar hardware and design. Many real Polaroids were junked few years ago, due to inability to get any product support: i.e. hardware for a reasonable price. that's why you have got into the problem: there is NO support for the product, not even "factory exchange only"! That's what we, the Repair Men, find at the 'parts distributors". Those must be sitting on direct payroll from People's Republic. They trying to price replacement parts well above the cost of new unit. Example: 52" Sharp LCD panel cost: $2,695.00 plus s&h! and that's for 5 years+ set! Make up your mind about 'support" and start to repair your set. In most cases it will be very reasonable, especially if your set was your 'baby". don't try to replace it now: closer to the date, TVs are becoming more and more "toys"! Built to break! how would you support growing economy and wealth of those "people's republics'? By robbing yourself of the daily pleasures! good luck in your discovery,thanks,Alex.
1/6/2012 3:41:55 AM • Polaroid... • Answered on Jan 06, 2012
Polaroid 3211TLXB 32 in. LCD Television Logo
121 questions posted
Top Polaroid Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Polaroid Televison & Video
Most Popular Question
red light flashing tv won 39 t come
  • Televison & Video
